1 person soft top removal? - JeepForum.com
post #1 of 19 Old 09-13-2012, 12:44 PM Thread Starter
Gomofast
Gomofast's Avatar
Ok, I'm new to JKs so forgive me if I'm being stupid. On my TJ I could put the top up or down by myself, easily. I'm having a really hard time trying to do it by myself on my 2008 unlimited. Am I doing something wrong or is it very hard to do? Any tips would be appreciated.
08 JK Unlimited X, 2" Black Diamond lift, 33's, 1.5" wheel spacers, stubby bumper mod.
98 TJ Sport, 4" Rough Country Lift, homemade discos,
35" BFG Mud Terrain T/A KM's, 4.56 gears, Detroit Truetrac
up front, factory Trac-Lok out back,Warn M8274 8000lb
winch, York OBA, rock guards, custom intake, 48" HI Lift.
Gomofast is offline
post #2 of 19 Old 09-13-2012, 12:46 PM
rlj
rlj's Avatar
It just takes practice. I do it all the time when the soft top is on. May need to move side to side a few times or get inside the jeep to lower or raise at certain points......
2011 WK2 Overland
2007 JK Sahara Unlimited
2003 TJ X
rlj is offline
post #3 of 19 Old 09-13-2012, 12:49 PM Thread Starter
Gomofast
Gomofast's Avatar
Can you describe your procedure? I can't even get the sunrider portion back by myself. I think after that I would be okay.
Gomofast is offline
post #4 of 19 Old 09-13-2012, 12:50 PM
J33PNSL33P
I have no problems taking mine down and puting it up myself. I follow the directions in the owners manual. If you do it in the right order it shouldn't be too hard. Once you do it a couple times you get a system
J33PNSL33P is offline
post #5 of 19 Old 09-13-2012, 12:55 PM
PhatJK
2009 JK Wrangler
I followed the video posted by Jeep and had no problems the first time using the softtop.
09 Unlimited Rubicon
Teraflex 2.5" spring lift kit
ORFAB tire carrier
PhatJK is offline
post #6 of 19 Old 09-13-2012, 12:58 PM Thread Starter
Gomofast
Gomofast's Avatar
What video? I don't have the owner's manual either. Every vid I've seen online shows two people doing it.
Gomofast is offline
post #7 of 19 Old 09-13-2012, 01:06 PM
PhatJK
2009 JK Wrangler
I got a DVD when I bought by 09 showing one person putting up the top. The Youtube JeepChannel has two people doing it but you can really do it with one person. My 5'6" frame had no problem with it.
ORFAB tire carrier
PhatJK is offline
post #8 of 19 Old 09-13-2012, 01:29 PM Thread Starter
Gomofast
Gomofast's Avatar
Yeah I've seen a vid for putting it up with one person, but it's taking it down that seems troublesome. I guess I'll just keep trying.
Gomofast is offline
post #9 of 19 Old 09-13-2012, 01:58 PM
paul84043
2 dr, 4 dr? Flopping it back or removing completely?
It just takes a couple times. You get the hang of it. I could flop mine back in about 30 seconds, flop it all the way back in a minute or two, and put it back on in about 2 minutes.
Completely off in about 10 minutes, and back on in under 20.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #10 of 19 Old 09-13-2012, 01:59 PM
BLK2000TJ
To lower it by yourself it helps to do it from inside the Jeep lifting from the middle front of the top. I remove the soft top all the time by myself. Once you've done it a couple times its a 3-4 minute job tops.
2010 JKU Rubicon 3.5" AEV , AEV Pintlers 35" KM2's , AEV Bumpers, AEV Hood / Snorkel
2008 JKU (Daily Driver)
2000 TJ Auto 4.5 RE Superflex ,35" MTZ 's , Warn ,Viking, LoD, RockHard,AEV, JKS, ARB's, Vanco Big Brake Kit ,Currie etc. etc.etc.
BLK2000TJ is offline
post #11 of 19 Old 09-13-2012, 02:01 PM Thread Starter
Gomofast
Gomofast's Avatar
4 door, flopping it back
it's just so flimsy that when I lift one side, the other side stays put and it feels like I'm going to tweak the metal frame if I keep pulling on it
Gomofast is offline
post #12 of 19 Old 09-13-2012, 02:02 PM Thread Starter
Gomofast
Gomofast's Avatar
Originally Posted by BLK2000TJ View Post
To lower it by yourself it helps to do it from inside the Jeep lifting from the middle front of the top...
Thanks, I'll give that a try.
Gomofast is offline
post #13 of 19 Old 09-13-2012, 03:16 PM
Green08
The original Supertop was no issue, up or down, easy.
On the NX, which I have been told is exactly like the OEM, I never have an issue lowering it, but pulling it up is another story.
The Supertop NX which has the same hardware as the OEM is tough pulling it back up. I'm not sure if it's the design of the bows or the sunroof.
Just a PITA.
Green08 is offline
post #14 of 19 Old 09-13-2012, 05:43 PM
OregonVette
I always do mine alone. Just unhook the latches, unclip the drain rails around all four doors, in hook the sail panels (back flappers.)
Here's where you do it... Stand in the middle of the backseat, and lift from front to back. Making little "W" with the folds, plop it in the back and you're done. You can take it down in 3 minutes, all by yer lonesome!
OregonVette is offline
post #15 of 19 Old 09-13-2012, 05:44 PM
Jeffro3000
2010 JK Wrangler
I've found the easiest way to put it up is to stand behind with the tailgate open. Grab the top and toss the front header bar forward. Keep 1 hand on he top as you walk to front so it doesn't fall back. Fully clip the front header. Secure rear sides, the back and side windows. With the lip on the side windows, only zip 3 or 4 inches, wrap the lip, the zip the rest. I kind of have to support the window with my right elbow while I'm starting the zipper.
2.5" OME HD lift, OME Steering Stabil, Skid Row Engine Skid, Skid Row Evap Skid, Ace Front Bumper, Ace Rock Rails, Engo 10K winch, Uniden 510 CB, 315/70R17 on Level 8 ZX
Jeffro3000 is offline
one person , soft top
Hardtop Removal/Storage Solution - One Person Operation DeepSky JK Wrangler Technical Forum 42 11-30-2011 05:42 PM
Single Person JK Hardtop Removal?? Corleone JK Wrangler Technical Forum 39 06-22-2010 02:14 AM
One Person Soft Top Operation tylerd JK Wrangler Technical Forum 12 06-12-2009 09:53 PM
One person spring removal/install Snuffster TJ Wrangler Technical Forum 21 03-15-2007 09:59 PM
soft top removal Thug Nasty TJ Wrangler Technical Forum 19 04-21-2006 03:50 PM
