1.5 leveling kit with 35s? - JeepForum.com
post #1 of 15 Old 09-04-2012, 08:59 PM Thread Starter
orestespd5
2011 JK Wrangler
I have a 2011 2door sport with a 1.5" leveling kit. My question is can I run 35s with 1.5" wheels spacers on stock wheels with stock fenders? I will not be doing any off roading with this rig.
orestespd5 is offline
post #2 of 15 Old 09-04-2012, 09:54 PM
paul84043
Probably be fine. If you were going to do any wheeling I'd say you were pushing it.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #3 of 15 Old 09-04-2012, 09:58 PM
LVCapo
2015 JK Wrangler
Edit: Daystar says their 1.75" coil spacers handle 35"s without issue. Both The Teraflex 1.5" kits I checked will handle up to a 34" tire......so no 35" for you.
LVCapo is offline
post #4 of 15 Old 09-04-2012, 10:03 PM
SubAtomicGenius
2011 JK Wrangler
Don't think you'll have any probs. Keep an eye on your rear pinch seam!
SubAtomicGenius is offline
post #5 of 15 Old 09-04-2012, 10:28 PM
ncb
Parked at the mall, yes.
With stock bump stops you risk losing a fender flare.
ncb is offline
post #6 of 15 Old 09-05-2012, 01:48 AM
222Doc
222Doc's Avatar
x2
35 12.5 need at least 3inch bump stops with stock fenders. Or you will knock them off bad advice. you can not add 3"bumps and and 1.5 puck lift you will be running on the stops.
222Doc is offline
post #7 of 15 Old 09-05-2012, 02:19 AM
MKWrangler
Is this the Teraflex leveling kit? IF so I have inquirered Teraflex about this kit and they say it will fit 35's with flat fenders.
MKWrangler is offline
post #8 of 15 Old 09-05-2012, 09:07 PM
crlickey
this is with daystar 1.75" spacers with stock shocks and stock bump stops. i havent trimed the pinch seam but i will be doing it soon, i have about 1/8" around the whole tire when its tucked.
crlickey is offline
post #9 of 15 Old 04-13-2014, 12:43 PM
poolboy93
I know old thread but does anyone think its reasonable to add 1" or 2" bump stops with the teraflex leveling kit and stock flares, I want to run 34.5 tires? Might not work but I just got the kit and saw a deal on the tires, I planned on 33s but id go for the bigger ones if people this it would be reasonable for logging and fire roads.
poolboy93 is offline
post #10 of 15 Old 04-13-2014, 08:09 PM
ncb
You'll lose 2" of total travel and won't have much down travel.
2" bump stops will keep the tires out of the flares.
ncb is offline
post #11 of 15 Old 04-13-2014, 09:31 PM
cdnroadwarrior
I would trim the fenders or buy flat fenders if you don't want to get extended bumpstops...
cdnroadwarrior is offline
post #12 of 15 Old 04-13-2014, 09:52 PM
poolboy93
I want to go with the bump stops but wasnt completely sure if it would be okay and workable, im not overly concerned with the travel, its a dd that I take on fire roads and that type of thing around my camp, no intense trails
post #13 of 15 Old 04-13-2014, 09:57 PM
poolboy93
I also may get my tires mounted before i put in the kit and then when shocks and springs are out put the wheels on to measure what i need for a bump stop
post #14 of 15 Old 04-24-2014, 10:20 AM
poolboy93
I'm running 325/65r18 with 2" bump stops and 1.5" wheel spacers and it all seems good so far.
post #15 of 15 Old 04-24-2014, 01:38 PM
cdnroadwarrior
Looking good!
Leveling kit drpericak JK Wrangler Technical Forum 22 05-02-2012 06:54 AM
leveling kit yay or nay jaspepp TJ Wrangler Technical Forum 4 08-30-2011 10:04 PM
Jk Wrangler Leveling kit or JK 1.5" Performance Leveling? BORRONGO JK Wrangler Technical Forum 5 07-03-2011 02:38 AM
Help with leveling TheGunslinger TJ Wrangler Technical Forum 5 07-20-2007 07:30 PM
Leveling my JK hogwild63 JK Wrangler Technical Forum 4 07-15-2007 07:39 AM
