09 Sahara 2WD - JeepForum.com
post #1 of 7 Old 04-28-2014, 09:06 AM Thread Starter
angelica23
2009 JK Wrangler
09 Sahara 2WD
I want to make sure I'm ordering everything I need to lift my Jeep. 35'' tires with a 4" lift, new steering stabilizer, and pitman arm. Is there anything else I need/should order?
angelica23 is offline
post #2 of 7 Old 04-28-2014, 12:26 PM
JoonHoss
2011 JK Wrangler
T-case, front diff and front driveline?
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #3 of 7 Old 04-28-2014, 12:32 PM
Bockwinkle
Hoss
well played, well played indeed
Bockwinkle is offline
post #4 of 7 Old 04-29-2014, 10:19 AM
JoonHoss
2011 JK Wrangler
As a follow-up, (and since you are new, and this is your first post)
1. Welcome to JF
2. My first post was entirely good natured...
While most here don't/won't want a 2WD jeep, i'm not about to judge.
What lift are you getting? Why 4" (more than you need for 35's)? Do you plan on regearing?
Hoss
post #5 of 7 Old 04-29-2014, 11:17 AM
222Doc
222Doc's Avatar
drop pit arms can be hard on the steering box of a jk. if you drop the pit arm then you should as well drop the mount on the trackbar. Or bump steering will be a issue. Both of these parts need to be parallel. At 4" even with 2x4 you are into a point were you need control arms that adjust, trackbars perhaps a drive line on a 2d. though i am not sure on the length of that stock compared to a 4x4 Jk.
222Doc is offline
post #6 of 7 Old 04-29-2014, 11:58 AM
Lenny7
2006 WK
I didn't think the Sahara came in 2wd only. Not basing that on anything i just thought the base sport was only one available with 2wd.
Lenny7 is offline
post #7 of 7 Old 04-29-2014, 02:05 PM
HappyTrails
HappyTrails's Avatar
A 2.5" lift is more than enough for 35" tires.
You can go with a budget boost/spacers, or a real coil-lift. The coil-lift will give the best ride.
Since this is a 2x4, and I doubt you will really take it off-road, I would look into the AEV 2.5" lift kit. It has a reputation as an excellent on-road ride. Not dissing the AEV crowd re AEV's off-road capability (except the drop brackets...not good for rock crawling). But AEV has the best rep for a street ride, hands down.
Once you go above 3", you start needing a lot more to make things work correctly.
No new steering stabilizer is necessary. As a matter of fact, many people, myself included, do not use a steering stabilizer. Save your $$$, don't buy one.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
2009 , lift , sahara
