'09 JK headlights are terrible! - Page 7 - JeepForum.com
post #91 of 107 Old 02-24-2009, 04:15 AM
y2k8jeep
The fog lights on '08 X are great, I couldn't believe how much they helped the first time I used them.
y2k8jeep is offline
post #92 of 107 Old 02-24-2009, 04:45 AM
DarnBig
DarnBig's Avatar
Can you override the fogs going off when the high beams come on? I did this on my truck and it made a huge difference. Do the fogs feed off of the power going to the lows and not the highs? I spliced in power from the parking lights to in my truck and now have fogs any time the parking lights are on. If somone will tell me how this is set up on the new JKs, I would be glad to experiment. Wire colors would be helpfull.
~Michael
~Michael
Her New Ride: 2012 4 door Rubi in Dozer Yellow/Orange - Stock for now.
DarnBig is offline
post #93 of 107 Old 02-24-2009, 06:05 AM
pm203
2009 JK Wrangler
Originally Posted by Hilldweller View Post
Phillips Visionplus +80 H13 from SUV Lights dot com.
Hilldweller,
Its a simple plug in and a nice upgrade?
Chuck45,
With the adaptors from Ford, is it just a matter of plugging one into the other?
pm203 is offline
post #94 of 107 Old 02-24-2009, 06:16 AM
b_c
Originally Posted by pm203 View Post
Hilldweller,
Chuck45,
check out the link in my sig. i did a write up on the install of the vision plus lamps (along with other mods i've done). it should be within the first 20 posts or so.
they are definitely worth the $80...
b_c
greater love hath no man than this, that a man lay down his life for his friends -john 15:13
b_c is offline
post #95 of 107 Old 02-24-2009, 06:28 AM
LMNGO
I found the stock headlight/foglight combo weak. Yesterday had them both replaced with Cat Eye HID. A bit expensive. The light is very white, and made my 130 Watt KC's appear yellow. The HID's improved up close visibility significantly, and long distance somewhat, but maybe they need to be adjusted up a bit. Although distance is where the KC's come in handy.
Cheers,
James
Just Another Day in Paradise!
LMNGO is offline
post #96 of 107 Old 02-24-2009, 06:57 AM
Hilldweller
2014 JK Wrangler
Hilldweller,
Take out old bulb, put in new bulb.
It was posted elsewhere in the thread but, a little background knowledge is always good. Read up here about automobile lighting.
http://www.danielsternlighting.com/
Take your time and go through the various categories.
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #97 of 107 Old 02-24-2009, 09:09 AM
gmd
2009 JK Wrangler
Originally Posted by 08BlueSahara View Post
Another new member of the "It's a Jeep Thing" club. Welcome!
that is funny and it is so true
----says it all----> meus veneratio est verum
Originally Posted by jsbarks View Post
pics or your making this all up
n i g h t c r e w #077
BLACK JEEP MEMBER 327
(from:friskeljr)The real test comes when all strength has fled and man must produce victory on will alone...
Courage is the mastery of fear...
rs.com/commu...mber.php?u=750
gmd is offline
post #98 of 107 Old 02-24-2009, 09:12 AM
gmd
2009 JK Wrangler
Originally Posted by versoel View Post
The lights in my JK are a lot better than the lights on my CJ !!!!
show off !!!!!!
gmd is offline
post #99 of 107 Old 05-22-2010, 11:26 AM
PlatinumOre
Just got done installing this from Susquehanna MotorSports. Install was easy, didnt know what to expect going into it. Hardest parts were taking out battery(dont have the little handle to attach to it) and putting retainer rings back on with only two hands.
Gotta wait till tonight to do a comparisons and aim them though i don't know how much if at all I will have to aim.
Routing was easy and used a few zip ties to secure everything together.
If anyone wants pictures Ill gladly take some and put them up.
PlatinumOre is offline
post #100 of 107 Old 05-23-2010, 12:50 AM
Heath
2014 JK Wrangler
Hella 002395301 - Hella Vision Plus Conversion Headlights - Overview - SummitRacing.com
Just a quick FYI here is the same kit for less than $50.
Heath is offline
post #101 of 107 Old 05-23-2010, 10:53 AM
PlatinumOre
Originally Posted by HardcoreHeath View Post
Not the same kit, your "kit" is just the housings and the bulb.
Rallyliights built relays and all the wiring to allow the new H4 bulbs to receive the power from the battery they are supposed to get rather than trying to pull H4 power through H13 wiring.
for 200$ your getting two housings two bulbs and the wiring to do it right. Now if you know how to do the wiring of the relays and harnesses etc and build it yourself and you could probably do it for cheap, I do not.
Here is some pictures of it:
And the result, (about 30-40 feet away, Think my height is good...Looks a little high but the garage sits slightly higher then the drive and the drive sits about 3 feet higher than the neighbors garage.
And who needs a campfire anymore, can roast marshmallows right on the headlights! DUAL purpose!
Very happy with the results
post #102 of 107 Old 05-23-2010, 01:56 PM
Heath
2014 JK Wrangler
Hi there. First off, it isnt "my" kit. Second, I didnt realize what all the other one came with. Glad you are happy with the result though! Thanks.
Heath is offline
post #103 of 107 Old 05-23-2010, 01:58 PM
Heath
2014 JK Wrangler
Its says not for use with DRLs. How do you go about disabling them?
Heath is offline
post #104 of 107 Old 05-23-2010, 02:07 PM
PlatinumOre
Just meant as to the kit you shown, yes very happy with them.
We don't have daytime running lights so unless you have them...
other then i do drive with my headlights and fogs on all the time,probably wont anymore with these puppies.
post #105 of 107 Old 05-23-2010, 02:12 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
I am upgrading mine to IPF4 headlights...
Project-JK.com - Jeep JK Wrangler Resource
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
Headlights are terrible jeep0867 JK Wrangler Technical Forum 6 09-26-2009 10:31 AM
Tj Braking is terrible mattyp1214 TJ Wrangler Technical Forum 134 12-30-2008 09:00 PM
Please help! Terrible Mileage! Losing Nemo TJ Wrangler Technical Forum 7 06-01-2008 09:45 PM
Help Terrible DW KevinR TJ Wrangler Technical Forum 2 05-24-2008 02:18 PM
Committing a terrible sin... glin60 TJ Wrangler Technical Forum 20 01-31-2006 12:19 PM
