'09 JK headlights are terrible! - Page 2 - JeepForum.com
post #16 of 107 Old 11-16-2008, 11:08 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by versoel View Post
The lights in my JK are a lot better than the lights on my CJ !!!!
I added relays on my CJ and the lighting is much better. Much, much better than my '08 JK
John Strenk is offline
post #17 of 107 Old 11-16-2008, 11:30 AM
WVUJeeper
I feel like my lights work good, or at least much better than my old '93 Impreza lights did; they just need to be adjusted. I got high-beam flashed 2 times per hour on a drive from Casper, WY to Dallas.
Yeah, I was bored enough to keep track.
- Fletcher: Oil Field Trash Extraordinaire
Originally Posted by VetteDriver View Post
BTW, what's with the "if you haven't driven one shut up" nonsense? How can we have a good internet fight if experience and knowledge are going to be a requirement?
'08 Rescue Green Unlimited X - Hard Top, 3.73 gears, Limited Slip, Infinity 7 speaker system, KC Slimlite Long Range, Cobra CB, Rough Country 2.5" BB, 35" BFG KM2's on ProComp 7089's. Fenderless and proud!
My build thread:
RESCUE GREEN JEEP CLUB MEMBER #25
COLORADO JEEP CLUB MEMBER # 1001
WVUJeeper is offline
post #18 of 107 Old 11-16-2008, 12:26 PM
sherghis
The factory lights on my JK sucked so I added a set of driving lights on my bumper. I tied the relay for the new lights in so when I turn on the high beams the new driving lights come on. MY fogs come on with the low beams so I can see pretty well at night. My TJ had better factory lights then my JK does.
08 JK X.Rubicon Express 2" mono shock lift, XHD front bumper, BFG M/T tires, AEV Corner Guards, RRC Side Armor rails, Mopar Rear Bumper, and bunch of little stuff.
sherghis is offline
post #19 of 107 Old 11-16-2008, 01:07 PM
Avian
My low beams were WAY off from the factory. They were aimed like high beams, and the high beams were off in the sky. I re adjusted them, and threw on a set of hells 500's on the bumper. The hellas are on all the time after dusk.
Detonator Yellow JK-X
150w windshield mount long range KC's
bumper mount Hella 500's/ 130w KC drivers
Uniden Bearcat CB/PA
Mopar bumper
Moabs/ BFG KM's
Avian is offline
post #20 of 107 Old 11-16-2008, 01:21 PM
Lammer
2011 JK Wrangler
how do you know if your lights are off set from the factory?
Just wondering how those of you know how your factory lights were offset from the factory?
I know on some of my previous cars there have been marks inside the hood to align your lights, is this where you are talking or are you just using your experience to determine if the lights are off?
just curious, as I have noticed that the lights are weak at best!
Cheers!
Lammer
Lammer is offline
post #21 of 107 Old 11-16-2008, 01:33 PM
Avian
Well, in the tech manual, theres instructions on how to create a pattern on a wall to aim your lights properly, but I just use common sense.
I took my jeep to a quiet paved road in the night, and adjusted them to where they looked the best. Low enough to where it wont blind anyone, and high enough to see at least 3-5 seconds ahead of you at highway speed. I also took into account where the high beams were aimed as well, since before I re-aimed them, whenever I turned on the high beams it looked like I turned the lights off. Thats how far in the sky they were aimed.
Mopar bumper
Moabs/ BFG KM's
Avian is offline
post #22 of 107 Old 11-16-2008, 01:51 PM
WVUJeeper
Mine were the same way...I just went out to adjust them. Will check them tonight for alignment now that I know where the screws are.
My build thread:
post #23 of 107 Old 11-16-2008, 02:44 PM
tricked919
Has anyone done the Delta conversion yet? Its one of those things I keep putting off - really waiing for reviews.
Yes, headlights on the JK are brutally awful. PIAA's were on of the 1st mods on mine
tricked919 is offline
post #24 of 107 Old 11-16-2008, 03:50 PM
Hilldweller
2014 JK Wrangler
Park your rig 25 feet from a nice wall and put a piece of masking tape 2.5 to 3 inches lower than the center height of your headlight. Your beam pattern should just hit the top of the tape.
Need to approximate your average load in the Jeep to make it accurate....
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #25 of 107 Old 11-16-2008, 05:10 PM
rjjj
how do you adjust them?
rjjj is offline
post #26 of 107 Old 11-16-2008, 05:11 PM
GunnerJK
I bumped up to Phillips Extreme Power, recently released, and the difference is definately noticeable. Not quite as good as my wife's Honda, but I'm now getting flashed consistently by oncoming traffic, which I consider a good sign. And visibility has increased dramatically. They are listed on my receipt as H13 9008. See below:
http://www.suvlights.com/index.php?cPath=81
'08 JK Rubicon, Steel Blue Metallic, Dual Tops, My Gig, everything but remote start and heater block.
GunnerJK is offline
post #27 of 107 Old 11-16-2008, 05:45 PM
chuck45
I read somewhere that the Marschal, Cibie and Hella lights wee the best - in that order - and pardon my spelling. But I can't find any good info on them or where to buy them. I don't care for my lights either - though part of it is probably my fault as I am sitting level as opposed to nose down by an inch and my lights are probably pointing skyward. I better get out and take care of that.
08 JK Unlimited Rubi, Auto, 5.13 gears, RE 3.5" SF lift w Bilstin shocks, BFG 35" KM2's, AEV Pintlers, Alloy USA CM front axles w CTM Ujoints, Superior CM rear axles, JE Reel 1350 driveshafts, RockHard Front Bumper w Warn PP w 3/8 syn rope, RockHard rear bumper and tire carrier, RockHard rocker guards and skid plates, ARB diff covers, ORE C gussets and LCA skids, Tuffy Drawer, Cobra 75, Cibie headlights, Hella 4000 Rally lights, 60" HiLift, PullPal winch anchor, Engle 45 Fridge.
chuck45 is offline
post #28 of 107 Old 11-16-2008, 06:49 PM
terrahawk
Google Daniel Stern Lighthing
terrahawk is offline
post #29 of 107 Old 11-16-2008, 07:41 PM
WVUJeeper
It's probably not a good thing you're being flashed by other people...usually that means that you're blinding them. It's not the safest thing in the world. You could cause an accident doing that. Get your lights adjusted correctly and you'll be even more satisfied.
My build thread:
post #30 of 107 Old 11-16-2008, 11:32 PM
242much
2009 JK Wrangler
adjust them down, makes a big difference. my highbeams are functional now. has anyone tried retrofitting an HID projector setup into the stock housing?
"The stoke was palpable..."
good grief, just buy the Rubicon.
242much is offline
Headlights are terrible jeep0867 JK Wrangler Technical Forum 6 09-26-2009 10:31 AM
Tj Braking is terrible mattyp1214 TJ Wrangler Technical Forum 134 12-30-2008 09:00 PM
Please help! Terrible Mileage! Losing Nemo TJ Wrangler Technical Forum 7 06-01-2008 09:45 PM
Help Terrible DW KevinR TJ Wrangler Technical Forum 2 05-24-2008 02:18 PM
Committing a terrible sin... glin60 TJ Wrangler Technical Forum 20 01-31-2006 12:19 PM
