'08 JK - Blinking red antitheft light - JeepForum.com
post #1 of 20 Old 12-06-2015, 10:59 AM Thread Starter
pwygant
Greetings,
I decided to create a new post for this one as I'm reaching out to see if any developments have transpired since I last posted about this issue. When it first started blinking it only happened once in a while but now I see it blink every 30 seconds or so and it is starting to get annoying.
I have crawled threads on all Jeep forums and I think the general idea is that it this light (See pictures) is related to some sort of short in the antitheft mechanism/short and seems pretty common.
1 - Can someone confirm this the case?
2 - Has anyone found a fuse to pull or area to check on how to remove the blinking light?
3 - If I can't find a way to pull a fuse or hunt down the short, can I legally figure out a way to open the dash/take apart and either tape over with duct tape or just pull/break the light? Are there any guides/videos on removing the dash which doesn't involve just the radio area.
'08 JK
pwygant is offline
post #2 of 20 Old 12-06-2015, 11:45 AM
JIMBOX
That is your "Sentry Key" ind.--
It's always supposed to flash at the start of the ignition, but-
If it keeps flashing, it's supposed to mean someone tried to start the engine/w wrong key---or an after MKT remote system has been installed that doesn't agree with the gREAT JEEP GOD--
May require Dealer Reflash
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #3 of 20 Old 12-06-2015, 12:34 PM
Neo1130
2015 JK Wrangler
That's not a 2008 cluster that's for sure... You haven't updated your profile... This happened a few times on my 2009 but never seen the light on my 2015...
Neo1130 is offline
post #4 of 20 Old 12-06-2015, 12:43 PM
JIMBOX
--HUH ??
That Tach/temp cluster us exactly the same as mine !
Whatever
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #5 of 20 Old 12-06-2015, 12:58 PM Thread Starter
pwygant
Hey, guys... Sentry key must be it. I read another 1 hour or so and that stuff is all over the place. To be fair to Neo1130, 1 of the pics is mine and the other I just googled the web for JK blinking light and about 2 pages of pics come up. (I stole one of those to show the light)
I can post my own I took a few years ago but might have to dig down deep in Apple photos...
'08 JK
pwygant is offline
post #6 of 20 Old 12-06-2015, 01:03 PM Thread Starter
pwygant
Here's an interesting video about the IOD/WCM. https://www.youtube.com/watch?v=-0HQ7B6mPvs
'08 JK
pwygant is offline
post #7 of 20 Old 12-06-2015, 07:06 PM
Neo1130
2015 JK Wrangler
Originally Posted by JIMBOX View Post
--HUH ??
Whatever
JIMBO
Interesting... I've never seen one before 2011 that had that cluster... They all look like this from what I've seen...
Neo1130 is offline
post #8 of 20 Old 12-06-2015, 07:10 PM
Neo1130
2015 JK Wrangler
Oh and the video above pulling the fuse is what I had to do when I was over 300 miles from home btw... That's just a temp fix...
Neo1130 is offline
post #9 of 20 Old 12-06-2015, 07:46 PM Thread Starter
pwygant
So... setting cluster confusion out of the way, this is for sure a Sentry error? In other words, there's a malfunction somewhere between the chip in the key(s) causing this error and something should be flashed by the dealer at no cost? That is it? My dealer has been confused for years and never offered to do that. Care to point to something?
'08 JK
pwygant is offline
post #10 of 20 Old 12-06-2015, 08:42 PM
JIMBOX
No, it won't be at "No Cost" and--
Did you install a remote starter, or was there one on there--have you had the JK since birth ??
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #11 of 20 Old 12-06-2015, 09:48 PM Thread Starter
pwygant
JIMBO
Remote starter came with the Jeep and we have had it since birth.
'08 JK
pwygant is offline
post #12 of 20 Old 12-06-2015, 09:58 PM
JIMBOX
Looks like Dealer "Reflash" and the Remote starter is probably causing the ECU/alert problem-
The jeep is probably over 7 years old and elex equip. has a habit of system self-destruction-over time-
Mine is over 7 years old and the FOB(Ign key) started hallucinating/fixedit !
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #13 of 20 Old 12-08-2015, 07:17 AM Thread Starter
pwygant
Thanks guys for all the help. I will inquire at the dealer with all supporting evidence/videos I have taken.
Thanks,
Pete
'08 JK
pwygant is offline
post #14 of 20 Old 12-08-2015, 11:19 AM
79cj7amc304auto
I bet the remote start module is at play here. I'd check the wiring connections. Early model modules had to splice a wire. I'm not sure what the ramifications would be because of that, but my sentry blinking light never blinked until I self-installed my remote start.
79cj7amc304auto is offline
post #15 of 20 Old 12-08-2015, 12:11 PM Thread Starter
pwygant
Do you know whereabouts the connections to check are? left/right/rear hood?
'08 JK
pwygant is offline
