07 Wrangler Squeaks when accelerating ? - Page 2 - JeepForum.com
post #16 of 23 Old 08-16-2012, 04:36 PM Thread Starter
SilenceOfDaPwnd
Ok so now I'm confused
Garage said they replaced my clutch with the stock one
They removed the one I had on there that was an after market high performance one
This coulda been the issue they said
Am I boned that I just downgraded?
What the hell is a high performance clutch ??
SilenceOfDaPwnd is offline
post #17 of 23 Old 08-18-2012, 08:17 AM Thread Starter
SilenceOfDaPwnd
Ok update
It's a cracked throttle body
That's what I'm being told
post #18 of 23 Old 08-18-2012, 10:42 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Your throttle body's on crack?
Dude that bad news..
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
post #19 of 23 Old 08-19-2012, 10:42 AM Thread Starter
SilenceOfDaPwnd
Any serious replies or comments lol
I'm stressed over this crap
post #20 of 23 Old 08-19-2012, 10:50 AM
Wavedatya
2010 JK Wrangler
A high performance clutch tends to grab WAY harder than a stock one. My dad installed a performance clutch in the bronco and I had to be very very careful on releasing the clutch. It was really hard at first to get use to. The new clutch will probably feel spongy to you now.
Also, performance clutches will provide a little more torque feeling.
I miss driving a manual suv. My car is manual but that doesn't count lol.
A throttle body shouldn't be that much to replace and should be a fairly easy fix if you have some mechanics experience. Guys on my dodge ram forum use to always talk about removing TB and cleaning it. Replacing it should be just as easy.
Good luck and keep us posted.
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #21 of 23 Old 08-21-2012, 01:35 PM Thread Starter
SilenceOfDaPwnd
Ok
So they replaced the Throttle Body
It's much better
No squealing as I accelerate
Well kinda
If I push it I can still make it squeak
Just not as loud or constant
Not sure if that's cuz it's new parts or???
I mean clearly they fixed what the issue was to a certain degree because it is much much better....
The paperwork says it may squeak due to my K&N air filter......
This true ??
Advice?
I mean it is a used jeep
65K miles
I should expect a lil noise regardless lol
Or am I wrong ?
post #22 of 23 Old 08-22-2012, 02:23 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Your K&N will allow you to hear the air going thru the throttle a bit louder than the stock air box. A little noise doesn't hurt...
post #23 of 23 Old 08-23-2012, 11:55 AM Thread Starter
SilenceOfDaPwnd
It's a squeal
Tho
Like the warning tab on my breaks
jk , noise , squeaking , wrangler
99 Wrangler making loud banging noise when accelerating srusty67 TJ Wrangler Technical Forum 1 12-16-2011 03:52 PM
99 Jeep Wrangler hiccups when accelerating, and tries to die in neutral JOMOjeep31 TJ Wrangler Technical Forum 2 07-21-2011 07:20 PM
Squeaks?! MusicMaverick TJ Wrangler Technical Forum 13 02-23-2008 09:29 PM
I got the squeaks Jakemd98 TJ Wrangler Technical Forum 6 03-05-2007 01:56 PM
I still have the squeaks??? help.. please.. Goondock TJ Wrangler Technical Forum 3 02-13-2007 10:41 AM
