07 Wrangler Squeaks when accelerating ? - JeepForum.com
post #1 of 23 Old 08-15-2012, 10:34 AM Thread Starter
SilenceOfDaPwnd
I JUST DROPPED OFF MY JEEP AT THE GARAGE BECAUSE I AM GOIGN INSANE WITH THE SQUEAKING NOISE THAT CONSTANTLY GOES AS I ACCELERATE IN MY 07 WRANGLER
I HAVE NO IDEA WHAT THIS IS.....
IT'S NOT THE CLUTCH, WHERE AS I AM NOT TOUCHING IT
ANY GEAR AS I PRESS THE GAS DOWN ABOUT 255 IT CREATES A CONSTANT NOISE THAT IS DRIVING ME INSANE......
ANY IDEAS?
SilenceOfDaPwnd is offline
post #2 of 23 Old 08-15-2012, 10:44 AM
Dynomax_Exhaust
I guess tensioner pulley....
Dynomax_Exhaust is offline
post #3 of 23 Old 08-15-2012, 10:50 AM
1AAdam
can u tell if it's coming from the engine or from the drive train?
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #4 of 23 Old 08-15-2012, 10:58 AM
Dynomax_Exhaust
If it is the tensioner pulley front of the engine.
post #5 of 23 Old 08-15-2012, 12:11 PM Thread Starter
SilenceOfDaPwnd
Problem is the noise only occurs when I press on the gas while driving......
I cant locate it as I drive :-/
Is there a way to see while its in Neutral I wonder to pinpoint the location
post #6 of 23 Old 08-15-2012, 01:49 PM
SubAtomicGenius
2011 JK Wrangler
ANY IDEAS?
Perhaps your Jeep's caps lock is stuck on...
Seriously, check it out in neutral. Does it still make the same noise while not in gear?
SubAtomicGenius is offline
post #7 of 23 Old 08-15-2012, 02:27 PM
Wavedatya
2010 JK Wrangler
Could be a belt tensioner but that will likely do it at idle. Something in te brakes. Or bad rotor. Bad wheel bearings. Loose vacuum hose. Tranny needs maintenance.
Mine does it too. But mine changes When I hit the brakes. And my jeep goes for days without moving so its prob something seizing. I suspect it's my brake booster because it changes when brake applied. Either goes away or gets louder for some reason. Until something falls off it I'm gonna drive it. I'm tired of dealers and "not being able to replicate sound" lol and than charging me 100$ to check it out
Sorry for the rant
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #8 of 23 Old 08-15-2012, 02:35 PM Thread Starter
SilenceOfDaPwnd
Well luckily I have 2 years free maintenance on the Jeep
Thats why I dropped it off
Hopefully they find it and fix it
And its still free so
Go me lol
post #9 of 23 Old 08-15-2012, 02:49 PM
Wavedatya
2010 JK Wrangler
Go me lol
Lol. I have warranty too but still couldn't be bothered lol. That's how much I dislike dealers.
post #10 of 23 Old 08-15-2012, 02:59 PM Thread Starter
SilenceOfDaPwnd
Well I just called the Garage for my update...
They hit me with the Jeep TSB:
I looked it up online and sounds about right......
Info below:
__________________________________________________ _______________
NUMBER: 06-001-08
GROUP: Clutch
DATE: June 14, 2008
SUBJECT:
Squeak-Like Sound Due To Manual Transmission Clutch Disc
MODEL:
2007 - 2008 (JK) Wrangler
NOTE: This bulletin applies to Wrangler vehicles equipped with a 3.8L engine and manual transmission (sales codes EGT and DEH respectively), built on or before June 5, 2008 (MDH 0605XX).
OVERVIEW:
This bulletin involves the replacement of the manual transmission clutch disc.
SYMPTOM/CONDITION:
The customer may experience a squeak-like sound from the transmission clutch. This sound will occur when there is a change in engine torque. The squeak-like sound can be heard most often during: clutch engagement, acceleration (tip-in), and/or deceleration maneuvers. This condition may be due to the clutch disc internal components.
post #11 of 23 Old 08-15-2012, 03:04 PM
Dynomax_Exhaust
Nice! Thanks for the follow up!
Info below:
NUMBER: 06-001-08
GROUP: Clutch
DATE: June 14, 2008
SUBJECT:
MODEL:
OVERVIEW:
SYMPTOM/CONDITION:
post #12 of 23 Old 08-15-2012, 03:50 PM
Wavedatya
2010 JK Wrangler
Awesome! Is that a Recal? Lucky you get a new clutch for free!
post #13 of 23 Old 08-15-2012, 04:12 PM
paul84043
I was going to guess "small rodent stuck under gas pedal".... Dang..
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #14 of 23 Old 08-15-2012, 04:26 PM
Wavedatya
2010 JK Wrangler
No that's under the hood! Ehhh ohhhhh!!!! Lol.
post #15 of 23 Old 08-15-2012, 05:53 PM Thread Starter
SilenceOfDaPwnd
I'm not sure if it's a recall
Just know it was a bulletin
jk , noise , squeaking , wrangler
99 Wrangler making loud banging noise when accelerating srusty67 TJ Wrangler Technical Forum 1 12-16-2011 03:52 PM
99 Jeep Wrangler hiccups when accelerating, and tries to die in neutral JOMOjeep31 TJ Wrangler Technical Forum 2 07-21-2011 07:20 PM
Squeaks?! MusicMaverick TJ Wrangler Technical Forum 13 02-23-2008 09:29 PM
I got the squeaks Jakemd98 TJ Wrangler Technical Forum 6 03-05-2007 01:56 PM
I still have the squeaks??? help.. please.. Goondock TJ Wrangler Technical Forum 3 02-13-2007 10:41 AM
