07 wrangler/ shudder - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 07 wrangler/ shudder
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 09-21-2010, 04:45 PM   #16
bkerry
Taking mine in the shop today. I will post results.
bkerry is offline   Reply With Quote
Unread 09-26-2010, 11:05 AM   #17
bkerry
Shop cound not find anything. Removed front drive shaft still had vib. Removed rear drive shaft still had vib. Should the front wheels make a clicking noise when turned by hand? Also, when driveing at 70 MPH the vibs seem to go away. Lost at this point on what to do. Please help.
Unread 09-26-2010, 03:52 PM   #18
burnout88
I thought you said there was slop/play in the ball joint? Is your Jeep lifted or stock? What's the setup on this Jeep?
07 JK 2-door, 6-speed, 2.5 Teraflex Coil Lift with Teraflex Shocks, Teraflex Swaybar disconnects, Teraflex HD Front Track Bar with Teraflex Steering Stabilizer and Teraflex HD Rear Track Bar Bracket, 35 inch MTR Kevlar on 17x9 XD Spys, Superchips programmer, Volant Cold Air Intake, MBRP Stainless Exhaust,
burnout88 is offline   Reply With Quote
Unread 09-26-2010, 03:58 PM   #19
bkerry
The jeep has a leveling kit on it. There is 1/4 in. up and down movement on the drivers side.
Unread 09-26-2010, 04:02 PM   #20
nwbronco
.25" up and down? Swap those ball joints.
nwbronco is offline   Reply With Quote
Unread 09-26-2010, 04:06 PM   #21
bkerry
Can anyone tell me what the clicking noise is when spinning the front tire?
Unread 09-26-2010, 04:13 PM   #22
nwbronco
Could be the speed sensor, or disc brakepads, or unit bearing. Also, check the ujoint at the axle end.
Unread 09-26-2010, 04:16 PM   #23
bkerry
No play in u-joints. Is the clicking noise normal?
Unread 09-26-2010, 04:50 PM   #24
burnout88
Clicking is weird, can you post a quick you tube on it?
Unread 10-10-2010, 09:07 AM   #25
bkerry
Misterious, drove the Jeep today had vibration. Later in the day drove it again and had little to no vibration. Could there be a problem in the Tranny? I'm stumped.
Unread 10-10-2010, 12:02 PM   #26
tbone616
Mine went away now that i got new rims and tires put on? I was thinking maybe my original ones threw a weight but typically the vibrationit gets worse the faster you go when your wheels aren't balanced correctly. So maybe it was my original tires or some mysterious black voodoo magic dunno, but at least it's gone.
tbone616 is offline   Reply With Quote
