07 wrangler/ shudder - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 07 wrangler/ shudder
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 09-10-2010, 04:49 AM   #1
bkerry
Still trying to figure out my low speed vibration/shudder. I have read several posts on this issue and the TSB. I have no codes. I have also had this problem come and go. Is there any way to isolate the problem? I have installed a leveling kit and replaced rear drive shaft. Balanced tires 2 times. Also, new drag link. Vibration comes in at 20 mph and shudder is intermitant at 35 to 40 mph.
bkerry is offline   Reply With Quote
Unread 09-10-2010, 10:06 AM   #2
RockyClymer
RockyClymer's Avatar
I assume you mean the front end - rear drive shaft would not affect front end and is not really needed with just a leveling kit.
1. something is loose under the front end - check all connections - check for worn parts (ball joints?)
2. something is out of alignment - caster?
3. a good shop would help diagnose problem - let them drive it and see for themselves (not dealer)
keep us posted.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 09-10-2010, 04:28 PM   #3
bkerry
I took it in and they suspect torque converter. Does this make sense and is there any way for me to diagnose that. Mean while I will inspect all front end parts.
Unread 09-10-2010, 06:03 PM   #4
RockyClymer
Not familiar with that one - I have a stick, no converter.
NRA Life member
Unread 09-11-2010, 08:00 AM   #5
Tireguy
2009 JK Wrangler
If 'they' suspect the torque converter, drive it yourself, get it to 'shudder' (where its at its absolute worst) then do two things-turn the o/d (overdrive) off...does the shudder change or disappear? And/or, quickly shift to neutral...does it still shudder while coasting or does it disappear? And if so, does it come back and/or change when shifting back to drive?
If it is a driveline issue, then, in theroy, the shudder should go away when no power is applied to the drivetrain. If the shudder remains when coasting (not under power) at the affected speeds, its time to focus on whats rolling- tires/wheels, axles (shafts, bearings, brakes too!), driveshafts, etc.
Tireguy is offline   Reply With Quote
Unread 09-11-2010, 08:58 AM   #6
bkerry
Checked ball joints, driver side loose, passenger side tight. Would that cause my vib/shudder?
Unread 09-11-2010, 09:20 AM   #7
burnout88
Yes, absolutely!! Especially at the speeds you stated.
07 JK 2-door, 6-speed, 2.5 Teraflex Coil Lift with Teraflex Shocks, Teraflex Swaybar disconnects, Teraflex HD Front Track Bar with Teraflex Steering Stabilizer and Teraflex HD Rear Track Bar Bracket, 35 inch MTR Kevlar on 17x9 XD Spys, Superchips programmer, Volant Cold Air Intake, MBRP Stainless Exhaust,
burnout88 is offline   Reply With Quote
Unread 09-11-2010, 10:29 AM   #8
bkerry
Thanks for the help. Do I need special tools to replace them?
Unread 09-11-2010, 11:09 AM   #9
burnout88
Yeah ball joints sometimes require a press and torch to install/remove them or special tools to get them in or out and alot of time. Generally not an easy job, the parts are not that expensive but they are labor intensive.
Unread 09-11-2010, 02:58 PM   #10
Dronac
Out of balance drive shaft perhaps?
2008 Jeep JK X: auto trans, 3.73 gears, D44 rear, D30 front
Mods: 2'' Rusty's coil lift, Superchips 93 octane tune, Cobra 75 CB radio, 33'' Duratrac's, onboard air compressor
My Build Thread! ---> http://www.jeepforum.com/forum/f96/dronacs-build-thread-1104134/
Dronac is offline   Reply With Quote
Unread 09-19-2010, 05:41 AM   #11
bkerry
Replaced torque converter. Shudder gone. Still have low speed vib. starts at 15 mph. I can feel it through the steering wheel and gas pedal. driver side ball joints are a little loose. would the ball joints cause a vib at those speeds?
Unread 09-19-2010, 07:06 AM   #12
Warlord2
yup
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline   Reply With Quote
Unread 09-19-2010, 07:40 AM   #13
LarryGrant
I thought that the gas pedel was electronic control? How would you feel it there? Not trying to be a smarty pants just hoping someone who does know can tell me this.
LarryGrant is offline   Reply With Quote
Unread 09-21-2010, 04:05 PM   #14
bkerry
Would the rear drive shaft cause vibrations starting at 15 MPH?
Unread 09-21-2010, 04:38 PM   #15
tbone616
I'm having a similar problem with my 08 Rubicon. Interested to see how you fix it. Gonna try to get it into the shop in the next few weeks and see what they say as it's still under waranty.
tbone616 is offline   Reply With Quote
