07' Rubicon vs 10' sport - JeepForum.com
post #1 of 18 Old 07-12-2013, 11:50 PM Thread Starter
Habber
Hi guys,
Looking at both models. Both have same miles and Rubi has a/c. Sport has 2" lift. Any input would help.
Jeep TJ 2001 4.0 5MT
Habber is offline
post #2 of 18 Old 07-13-2013, 04:02 AM
Rtone1583
2009 JK Wrangler
What is the mileage and what is the price? How do you plan to use it?
Rtone1583 is offline
post #3 of 18 Old 07-13-2013, 07:29 AM Thread Starter
Habber
20k miles and its my 2nd car (not DD). Plan to mix 80% city 20% snow/light trail. 07' Rubicon is $14500 and Sport lifted is $16k
Habber is offline
post #4 of 18 Old 07-13-2013, 09:17 AM
Rtone1583
2009 JK Wrangler
Man, that's a tough call.
I would go for the Rubicon. It's probably overkill for what you intend to do on the trail but at $1500 less and the same mileage you'd be hard pressed to find a better deal for what you're looking at.
post #5 of 18 Old 07-13-2013, 09:36 AM
brianjw
And it doesn't have what is probably a low budget lift.
brianjw is offline
post #6 of 18 Old 07-13-2013, 09:56 AM
suicideking
How many miles on each?
Go with the Rubi if you plan on wheeling it and using the lockers. The transfer case is also lower and better for crawling. The front D44 is also better if you're going to put 35" or larger wheels on.
Figure the axles run about $3K each new and the transfer case is about $1500 or so. Only necessary if you're going to use them though.
suicideking is offline
post #7 of 18 Old 07-13-2013, 03:45 PM Thread Starter
Habber
It's tough since I don't trail that much HOWEVER it will be my winter car and I will be upgrading to 35's (sport already has been geared up and comes already with pro comp 35's while Rubi has stock wheels)
Habber is offline
post #8 of 18 Old 07-13-2013, 08:35 PM
marmotmb
35's on a sports D30. Could get sketchy quick with any off roading.
Go ruby buy 35's and steel rims
Pro Comp - Hypertech Programmer / 2.5" Teraflex coil lift & 1" M.O.R.E Body Lift / 315/75R16 Pro Comp Mt. Extremes / 16" x 8" Pro Comp Series 52 (Black) / Pro Comp steering stabalizer / Air Raid Cold air intake / Ace Enginnering and Fab Front stubby with bull bar / OR Fab Rear tire carrier / 2 Blitz Jerry Can / HI lift jack / Cherry Bomb 2.5" Exhaust and Custom Tail pipe / KC Daylighter 6" 130 Watt with Driving lense / Shifter boot trim ring bolt mod / Rear Bumper gap mod / Mirror drill hole mod
marmotmb is offline
post #9 of 18 Old 07-13-2013, 08:43 PM
pentastarguy
2015 JK Wrangler
are you saying the rubi doesn't have air?
pentastarguy is offline
post #10 of 18 Old 07-13-2013, 08:43 PM Thread Starter
Habber
Even if the Sport has been regeared?
Habber is offline
post #11 of 18 Old 07-13-2013, 08:44 PM Thread Starter
Habber
Rubi has air
Sport no air
Habber is offline
post #12 of 18 Old 07-13-2013, 09:08 PM
jrmars07
2010 JK Wrangler
Regearing doesn't matter for the strength of the D30, actually the higher the gear the weaker it is as far as breaking.
The thing that will help the D30 is sleeve/gusset or truss and stronger axle shafts. But the gears/R&P will always be weaker in the D30 than the D44 of the rubicon.
Personally I'd go with the Rubicon. Lockers will make your off roading experience a lot better.
2010 2dr Wrangler
2.5" ProComp Lift, Front Adj Trackbar, JKS Disco's
Fox Shocks
Tera Front Lower Controls Arms, Rear Upper Control Arms, Synergy HD Balljoints
Tom Woods 1310 Driveshafts
33" KM2's on ProComp 7069 16x8's
Superchips Flashpaq
AEV Premium Front Bumper, IPF 900XSD Lights, Warn 9.5ti w/ Synthetic Line
AEV Rear Bumper, Tuffy Security Deck
D30 Front Sleeved and Gusseted, RCV's, ARB Locked
4.88 G2 Gears
D44 Rear ARB Locked, Chromoly Shafts
jrmars07 is offline
post #13 of 18 Old 07-13-2013, 09:14 PM Thread Starter
Habber
Sorry guys, I'm a bit of a newbie. Please explain when I would need locking diff. Also if someone can explain difference between sport and Rubi I'd really appreciate it.
Habber is offline
post #14 of 18 Old 07-13-2013, 10:19 PM
Rtone1583
2009 JK Wrangler
Assuming that by geared up you are talking about the lift kit and tires already in place on the Sport.
The $1500 saved on the Rubicon will make a decent dent in the cost of tires and a 2" lift kit to better fit them plus the 4.10 gears in the Rubicon will be better able to compensate for the 35's (driveability wise) and the Dana 44 axles in the Rubicon are simply more robust (mechanically) than the axles in the Sport.
post #15 of 18 Old 07-13-2013, 10:27 PM
oldstyle
By the time we talk it to death, they'll both be sold. I'd buy the 07 Rubi for the lesser price. It won't depreciate much more.
2006 LJ 4.0 auto and A/C.... Life after CJs isn't so bad.
oldstyle is offline
