07' Rubicon Power Steering Dilema - JeepForum.com
post #1 of 1 Old 08-15-2012, 05:00 PM Thread Starter
crewguy987
Got stuck, not a big surprise. But as soon as I got out my power steering was non existent. No whining pump, just grunt force power applied to steering wheel to turn. My problem is I don't know wether to replace to power steering gear box or the pump. I have removed the pump and opened it up, resevoir was full, pump and fluid had no signs of debris or metal shavings or anything broken, from a lamens eye perspective. I don't want to purchase the wrong thing and be out a few hundred more dollars. To complicate matters no parts stores seem to carry the 07-11 power steering pumps because they redesigned the part in 2012 using a different pump with a larger pully shaft. I'm not even sure if I could bolt up a 2012 pump to mine if I wanted to.
So...How do I figure out what I need to replace, and what do I replace it with? I'm at a stalemate. PLEASE HELP!
crewguy987 is offline
power steering box , power steering gearbox , power steering pump , rubicon , steering
LJ Rubicon Power steering vs. Non-Rubi wepeterson47 TJ Wrangler Technical Forum 2 10-30-2011 07:14 PM
97 wrangler with manual steering, need donor info for power steering. anarchyfor2 TJ Wrangler Technical Forum 7 01-12-2009 07:12 AM
Steering suddenly shudders @ low speed...power steering pump? Please help pinpoint! captndiltz TJ Wrangler Technical Forum 2 08-20-2008 03:23 PM
Rubicon Express Lift Kit Dilema method84 TJ Wrangler Technical Forum 33 12-30-2005 04:22 PM
Power steering pressure line/ power steering belt Ryanjeeper YJ Wrangler Technical Forum 4 11-10-2005 06:10 PM
