07 JK drive train vibration - Page 2 - JeepForum.com
post #16 of 19 Old 08-19-2010, 10:57 AM Thread Starter
bkerry
The vib. starts at 20mph. The drive shaft on the rear is new. Could It still be out of balance. I will remove it and drive in 4 wheel and see if the vib. goes away. Also, could a shock cause this type of vib. I've heard a little about torgue converter issues, what's your thoughts?
bkerry is offline
post #17 of 19 Old 10-11-2010, 05:56 PM Thread Starter
bkerry
Still chasing my vib. problem. I put the jeep on jacks, put it in for high and at an idle with wheels straight forward and turning no sounds, when I turn the wheels to the left I get a clunking noise in the transfer case. I hope this isnt normal. Could there be something bound in the front diff, or a u-joint on the axle?
bkerry is offline
post #18 of 19 Old 10-11-2010, 10:16 PM
Warlord2
so you turned the wheels left and there was a noise in the transfer case? Guess I dont understand what you mean by that...
Did you ever try removing the rear/front driveshaft and see if the vib is still there? It really sounds like a pinion angle issue to me.....
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #19 of 19 Old 10-24-2010, 02:34 PM Thread Starter
bkerry
Today I removed rear drive shaft. Drove in 4 wheel drive. No vibrations. Drive shaft is a double cardan, the angle on the pinion is about 2 degrees. Need help on how to fix. My jeep is only lifted 1 inch. on the rear and 2 inch. on the front.
bkerry is offline
drive line vibration , drive shaft , JK Wrangler , pinion seal , vibration , wrangler
drive train help bohicajay YJ Wrangler Technical Forum 1 05-26-2010 11:19 PM
drive train vibration jefffoxsr TJ Wrangler Technical Forum 11 04-18-2010 05:04 PM
What should i do for the drive train? 89Redyj YJ Wrangler Technical Forum 1 01-10-2010 02:23 PM
Drive train Iquois YJ Wrangler Technical Forum 3 01-30-2007 05:37 AM
Drive Train Q's EricS TJ Wrangler Technical Forum 3 07-14-2003 10:56 PM
