Temperature inside tire - JeepForum.com
post #1 of 5 Old 04-23-2006, 07:14 AM Thread Starter
mjeselskis
I am doing a senior project building a pressure sensor and its going inside the tire but i need to know the temperature inside the tire in order to choose a sensor that will be able to handle the temperature. So does anyone have any idea how hot it gets on the inside of the tire?
1989 black YJ, 2.5L 5speed
SOA on stock springs with add a leaf in rear, Welded D30, Posi-Locked, traction bar, Rear 5/8" Boomerang Shackles, OBA, Ditched Front and Rear Trac Bar, 34x10.5 LTB TSL Swampers on 15x8 M/T Classics, Ramsey Pro Plus 9000
mjeselskis is offline
post #2 of 5 Old 04-23-2006, 11:39 AM
Black Hills TJ
Black Hills TJ's Avatar
might want to try GD
Originally Posted by Allenwr
My mouth still has funky taste in it, so I am doin alright.
Originally Posted by ImSuck
damnit i wish i could get bigger quicker
Check out
Black Hills TJ is offline
post #3 of 5 Old 04-23-2006, 08:16 PM Thread Starter
mjeselskis
Thanks, I just posted there. I thought I posted this one there, whoops.
post #4 of 5 Old 06-04-2006, 06:06 AM
WOLFSTER
When I changed tires I put a thermometer in one of them...damned if I can read the thing now...
WOLFSTER is offline
post #5 of 5 Old 06-07-2006, 08:25 AM
Ocelotzin
Indirect mesurement
You can try to measure it in your own car. Just take the pressure of the tire and ambient temperature early in the morning; then take your car to a 0.5 or 1 hour highway trip and measure the pressure immediately. Then, the temperature inside the tire will be approximately
T2 = T1*P2/P1
Where T1 is the temperature in the morning, P1 the pressure at the same time and P2 the pressure after the trip.
After that, you can add a safety factor because every kind of tire will reach a different temperature
Ocelotzin is offline
what temperature do you keep your residence? MC_NickP General Discussion 54 01-20-2010 09:08 PM
Home with a 104 Temperature ArrizX General Discussion 22 05-21-2009 12:41 AM
temperature poll woody-77 General Discussion 31 07-12-2006 05:21 PM
Temperature inside tire mjeselskis General Discussion 15 04-24-2006 03:43 PM
Temperature Question? 2ksportNY General Discussion 8 07-15-2003 05:36 PM
