Parking for extream dummies - Page 2 - JeepForum.com
post #16 of 77 Old 06-07-2011, 05:36 PM
Andywear
put a brick behind the front wheel and in front of the back wheel.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #17 of 77 Old 06-07-2011, 06:36 PM
MudWrangler
Originally Posted by bikerdude View Post
personally i always just put it in first gear while holding the brake down and the clutch to the floor, shut off the key and wait til the motor has completely stopped, let out the clutch and then let off the brake. Then you can set the e-brake. You can do it the other way but with the motor not spinning you need to make sure it goes all the way into first. Sometimes it can bind because the syncronizers in the tranny are not turning.
x2
MudWrangler is offline
post #18 of 77 Old 06-07-2011, 07:15 PM
Jax89Jeeper
Originally Posted by lifewalk
I just use a prius or smart car as a tire wedge
I'll have to try that sometime. Lol
Jax89Jeeper is offline
post #19 of 77 Old 06-07-2011, 10:38 PM
firefighter315
Originally Posted by ErikJordan View Post
You guys are thinking waaaay too much into this.
The sequence is of no matter.. Get it turned off and leave it in first gear. Hit the e-brake and walk away.
Simple.
My YJ Build Thread
firefighter315 is offline
post #20 of 77 Old 06-07-2011, 11:27 PM
buckedgabers1
Can't belive this thread has 2 pages worth of commen sense
My junk is bigger than your junk
buckedgabers1 is offline
post #21 of 77 Old 06-08-2011, 07:03 AM
Andywear
Wait tell we make it a 4pager!
Another option:
Go in to the parking spot at an angle pop one wheel over the parking bumper and leave one on the other side. causing the wheels to be locked in.
This also keeps other weak non-AWESOME vech's. from parking close to your Jeep.
Andywear is offline
post #22 of 77 Old 06-08-2011, 08:07 AM
raynmaker
Page 3?
I usually put it in first or rev then turn it off and if i'm on an incline i set the brake. And if it still rolls I hold the brake and wait for the wife to hook up the tow strap rofl.
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
post #23 of 77 Old 06-08-2011, 09:32 AM
tdewit
Makes you think of Seinfeld. All about nothing.
tdewit is offline
post #24 of 77 Old 06-08-2011, 10:01 AM
backwoodsbrown
Newbie to Newbie - I feel for you.
Just bought my Jeep last July and had never driven a stick shift before. My ride home was a 120 mi crash coarse.
There are a lot of little tricks that experienced stick drivers don't even think about, but are new discoveries for us newbies.
My parking brake doesn't work so I keep a piece of rubber wedge in the Jeep and put it behind the tire if I park on a slope; if parking flat I just throw it into gear.
http://wegotmud.com/
backwoodsbrown is offline
post #25 of 77 Old 06-08-2011, 02:01 PM
Selafane
Good news to anyone with a faulty parking break, theres a recall to get it fixed as it was prone to disengaging. If the recall hasn't been, taken it in to get it fixed for free!
I can't remember if it was just for a certain year but worth ****ing out
Selafane is offline
post #26 of 77 Old 06-08-2011, 02:05 PM
justanotherjpr
Originally Posted by icenikka View Post
This isn't meant as a joke...
I taught myself how to drive stick, and I need some info on the subtleties associated with driving a manual jeep. If i want to park, should I go into neutral, hold down the brakes, then turn the car off, AND then switch it into first, or is it okay to leave it in first while I turn the car off?
Yes - this is correct.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #27 of 77 Old 06-08-2011, 02:16 PM
giggityjeeper
will they still do it if I cut all the lines off when I ddi the SOA.... cant be bothered with an Ebarke... ever put one on in -45 weather.....
your truck will stay where it is till SPRING....
useless things ever, turn the tire toward the curb throw it in first gear and see ya.....
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #28 of 77 Old 06-08-2011, 02:17 PM
buckedgabers1
Tricks Realy people have been driving sticks sense Henry Ford made his first car just turn the da$$ thong off set the e-brake and get out why is this hard? Also my budys drive way has a slight slope to it and he leaned against it and it poped out of gear over his rubber wedge and into the street the rubber wedge did not help they are designed to be used on fairly flat ground if this i sloped at all I would not trust it sense a lot of us here wrench with future jeepers present . (BE SAFE)
post #29 of 77 Old 06-08-2011, 02:46 PM
Andywear
we on page 4 of ways to park your jeep yet?
here's another: look for a ditch in the area your needing to be and drive and park in there. it will stay put in the bottom of a ditch and then you get to use your 4x4 to get out.
Andywear is offline
post #30 of 77 Old 06-08-2011, 02:49 PM
Jeff88
If you take your jack out from a stock YJ, underneath it you will find a brick, you should wedge this under the tire to be extra sure.
If you add larger tires, you have to make sure to upgrade the brick too.
Jeff88 is offline
parking break problem, i need my parking brake ClassicRiderhp TJ Wrangler Technical Forum 2 04-21-2010 10:21 AM
Extream 4x4 RabidUmpaLumpa Wrangler General Discussion 14 03-01-2009 11:46 PM
4WD for Dummies? usarmyavn TJ Wrangler Technical Forum 10 07-24-2007 05:55 PM
ESP for dummies laurachippewa JK Wrangler Technical Forum 10 05-28-2007 10:08 AM
Maintenance how-to for dummies...like me! Blankman TJ Wrangler Technical Forum 5 05-28-2004 05:35 PM
