Non conventional uses for recovery straps - JeepForum.com
post #1 of 13 Old 04-16-2011, 02:17 PM Thread Starter
99goldxj
What have you used your recovery strap for that is not recovering a vehicle.
Here is mine.
Had to change the oil in the push mower so I used a ratchet strap on the front and the recovery strap on the back.
1999 Jeep Cherokee Classic
201k miles
4.5" IRO Lift kit, 31" MTR Kevlar's, Custom bumpers
99goldxj is offline
post #2 of 13 Old 04-16-2011, 03:41 PM
Mickey_D
I used two of them to lift the cab off the frame on my Chevy Luv.
Got my riding lawnmower stuck in the mud. No way I was going to get anything close to it to pull it out. Used an old clothesline to extend the strap. Tied the clothesline to a tree and one loop on the tow strap. Looped the other end of the strap around the rear tire not getting traction and it became a winch line.
Used mine for winching a fallen tree back off the roof of the garage.
Lots of others. Seated a tire on the bead by cinching a strap down that was wrapped around the tread.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 13 Old 04-25-2011, 12:32 PM
tritt007
hangin deer and elk
tritt007 is offline
post #4 of 13 Old 04-25-2011, 12:36 PM
jeepinhokie
pulling out 4 wheelers from some urban wheeling. pulling out tree stumps.
HOKIES UNITED!
jeepinhokie is offline
post #5 of 13 Old 04-25-2011, 08:31 PM
srdart67
I hit a 60 pound raccoon and pushed in the lower core support on my old daily driver pretty good. I wrapped the tow strap around the lower beam and the other end to a tree and gave her hell in reverse. not a tow strap but i drilled a head bolt into a stud in my garage and used a ratchet strap to pull out the quarter panel of my 65 new yorker during restoration
srdart67 is offline
post #6 of 13 Old 05-02-2011, 12:53 PM
tritt007
A 60 POUND RACOON?????????????????????????????????????:confus ed::confus ed:
tritt007 is offline
post #7 of 13 Old 05-04-2011, 03:22 PM
Kuestey
Lol wait what?
- OlllllllO life -
XJ w/ 4" Rusty's and 33" KM2's -she be green and mean
Kuestey is offline
post #8 of 13 Old 05-04-2011, 10:24 PM
Country Boy
Bovi-sapiens
Country Boy's Avatar
Here is mine.
There's a much easier way to do that. Run engine 2-3 min to warm up oil. Remove oil fill plug/dipstick. Tip mower on side with dipstick down and drain oil into catch pan. While its tipped to the side, remove and sharpen the blade. Replace blade, tip mower back up, refill with oil, replace spark plug, clean or replace air filter, and start unit. I can tune up a push mower at work in under 15 min. You'll find on the newer push mower engines that there isn't a drain plug on the bottom anymore. With all the self propel drive systems, mulch domes, etc on the bottom, its pretty much impossible to reach them without disassembling half the mower anyway.
2000 WJ Grand Cherokee Limited, 4.7l V8, Quadra-drive
Farming is easy when your plow is a pencil and you are a thousand miles from the cornfield. -Dwight D. Eisenhower
Don't curse the farmer with your mouth full.
Ah, cows. A thousand roast beef sandwiches wrapped in a gorgeous leather coat.
Country Boy is offline
post #9 of 13 Old 05-06-2011, 01:10 PM
nj666z
Landscaping: Small tree and shrubbery removal.
nj666z is offline
post #10 of 13 Old 05-06-2011, 01:30 PM
MONSooNmonkey
????:confu sed:
Sadface :(
MONSooNmonkey is offline
post #11 of 13 Old 12-01-2011, 04:27 PM
gsaxe
not recovery but ratchet...used to true (pull into square) the walls of a prefab buidling four walls were up and made a trapezoid insetad of square used the ratchets to pull in opposing corners until square
never build alone........
AKA Catfish
gsaxe is offline
post #12 of 13 Old 12-01-2011, 05:02 PM
DKJEEPTJ1
My buddy just hit a racoon and it snapped the entire plastic molding from his pontiac
DKJEEPTJ1 is offline
post #13 of 13 Old 01-14-2012, 09:56 PM
SLATEGOAT
Them Mama raccoons can get big...... hit one at night..... came around the bend and it stood up .... wack on the front diff...... dented the cover in......
SLATEGOAT is offline
Recovery Straps SHeadrick General Discussion 30 04-01-2009 08:58 AM
Working out, recovery time vs. no recovery. sitdwnandhngon General Discussion 13 02-15-2009 09:19 PM
recovery straps JeepMKcomin General Discussion 7 01-31-2008 08:15 AM
Tie down straps learfxr Trailers & Towing 6 11-29-2006 02:38 PM
synthetic, or conventional oil in your jeep? skp84 General Discussion 4 11-30-2003 07:51 PM
