Just how much do the stock leaf spring sag over the years? - JeepForum.com
post #1 of 14 Old 11-16-2013, 02:12 PM Thread Starter
Mambo_Dave
I'm wondering since the stock leaf springs are relatively cheap, and since I seem to appreciate it close to the height it is, but wouldn't mind a little more lift without entering the realm of the eventual SYE even with a 2.5" lift
Mambo_Dave is offline
post #2 of 14 Old 11-16-2013, 03:06 PM
roadyrob
1987 YJ Wrangler
stock yj springs are close to flat when new so unless your springs are really worn your probably loosing about an inch. a good way to check is measure your rocker panel, it should be 18" with stock tires.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 14 Old 11-16-2013, 04:10 PM Thread Starter
Mambo_Dave
Somebody still runs around with stock sized tires on 20 year old Jeeps?
post #4 of 14 Old 11-16-2013, 05:49 PM
KG7IL
I bought my '91 YJ a couple of years ago. With 31", I was reshaping the fenders, providing more clearance everytime I went out.
When I installed the 2.5 lift kit I got almost 6" of lift over what I believed were sagged springs.
My main reason for the lift was a broken rear spring 7 miles into the ride
I think they sag . . alot
My other 4WD is a Kubota
KG7IL is offline
post #5 of 14 Old 11-16-2013, 06:32 PM
superj
I just changed my stock springs a month ago. Mine were not negatively arched when I took them off and they rode very nicely. The only reason I took them off is I got a great deal on 2.5" ome springs and shocks.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #6 of 14 Old 11-16-2013, 07:13 PM Thread Starter
Mambo_Dave
I feel like you stopped typing before you wanted to.
So did the YJ body end up 2.5 inches higher, or more than that?
...I think they sag . . alot
Which kit was this?
post #7 of 14 Old 11-16-2013, 07:19 PM
superj
More. About 3.5" higher then previously. But I love old man emu springs so I can live with the extra lift. I really wasn't looking to lift but ome springs ride so nice
superj is offline
post #8 of 14 Old 11-16-2013, 07:43 PM Thread Starter
Mambo_Dave
Transfer case drop or SYE?
post #9 of 14 Old 11-16-2013, 08:05 PM
superj
T-casr drop that is not getting rid of the vibes. Shakes at 65+. Still working that issue so if get a set, try the sye
superj is offline
post #10 of 14 Old 11-27-2013, 08:38 PM
KG7IL
Originally Posted by Mambo_Dave View Post
Which kit was this?
Here was my review on the ProComp 2.5 lift
Product: 2.5 Inch Lift Kit with ES3000 Shocks by Explorer Pro Comp
Submitted at: 4 Wheel Drive Hardware
Complete Kit - Installation Clear
by Glenn from On the road in Parker Arizona. on 3/31/2013
Pros:
Improves Handling, Parts Fit, Complete kit, Easy To Install, Comfortable Ride
Best Uses:
Maintains Roadability
I had broken a spring on my 91 YJ and needed to get it back on the trails (and road).
4wd representative was VERY helpful in getting me to an affordable kit that would replace worn and broken parts.
Two 5 hour days were required.
I had two jack stands, and two small jacks. Normal tools.
I did need to remove the front stabilizer to gain BFH access to remove the stabilizer links. Pickle fork would have been helpful.
I also had to ream the lower hole of the rear stabilizer extension. This was done by fastening the extension in place and running a full size drill through the slightly misaligned holes.
All of this was done while RV'ing in a RV park.
Nice Kit, Affordable and Straight Forward Installation.
I am not a professional, but do have experience in Auto-mechanics and other mechanical skills.
KG7IL is offline
post #11 of 14 Old 11-27-2013, 09:46 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
My 89 is still stock and it's 24 years old, I will not buy a lifted rig. I rather buy something stock and modify it myself so I know it is done right But soon as I have all the money for new springs, shocks, high steer, perches, u bolts, brakelines, driveshaft, 35's , gears, and rear axle I will be goin SOA
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #12 of 14 Old 11-28-2013, 12:15 AM Thread Starter
Mambo_Dave
LOL, I just about did the same.
Everything on the jeep, save for the wheels and 31" tires, is still pretty stock.
So I have the lift kit choices to make, SYE's to consider, etc.
post #13 of 14 Old 11-28-2013, 06:29 AM
superj
I guess to help with a pic
Stock
Old man emu 2.5"
And I will have to get pics now that the lift has been on a month or so to out up
superj is offline
post #14 of 14 Old 11-28-2013, 07:52 PM
Rproject
1987 YJ Wrangler
When I got mine, it had stock springs and a 3" body lift. I dropped the body lift to 1.5" and put on OME's 2.5" lift so I "should" have gotten 1" of overall lift. I ended up with 3.5" of lift and a great ride.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
