-40, trapped in a culvert, frozen to the riverbed, 1am, no help for miles... - JeepForum.com
post #1 of 10 Old 08-21-2006, 03:45 PM Thread Starter
KIROUAC228
KIROUAC228's Avatar
So one evening in Northern Alberta, in the dead of winter we decided to head down to this tiny rivervalley that meanders through this larger river valley for something to do. It's -40 celsius, and about 8pm, dark and there's 3 of us in a soft top Suzuki Samurai. We're alone.
We head down this cliff embankment and realize we wont be able to come out that way. It's pure ice and we roost off the edge onto the river (which is frozen solid and covered with 3 " of snow) So we figure we'll just cruize along the river and find a less steep way out. NO. NO LESS STEEP WAYS OUT ANYWHERE. We have a winch, but the nearest trees are at the top and WAY past our line limit. We drive for about 8 miles winding along this river totally smoothe. At this point my feet (in steel toes) are frozen solid (barely any heat in Samurais). Suddenly we come up on this massive set of culverts under some train tracks routing the river under the tracks (big enough to drive through easy) but there's huge beaver damm frozen into the river right before it. We rammed the **** out of the sami trying to get over this damm and it took us forever to get up the the upper ledge of the frozen water but we made it. So we're right in front of the culvert and so we start driving though it. I started thinking, ok, water still runs under this ice, that means it goes through this culvert, that means......SNAP!!! Our front right breaks through and we're teetering on 2 wheels. Buddy gets out and there's running water under the front right but a huge space between the top layer of ice and the bottom of the culvert. Meaning NO TRACTION. Ok, so let's back up right? NO, the rear right breaks through and again NO TRACTION. Now keep in mind, the exhaust is steaming up the culvert completely (that we can't see the other end of) and it's black in there except for truck lights. So the sami is completely on it's right side and the right wheels arn't even touching the bottom of the culvert there's so much water. Nowhere to winch to, nowhere to get traction and we can barely open our doors. We slam it in reverse, slam it in 1st, slam it in reverse, ect and all that does is mangle the **** out of my shackles on the 3 inch thick layer of ice. Great. So me and buddy wait in the truck (still running) and we send out the warmest dressed guy to START WALKIN! Everytime you put your foot on the bottom, it's immediately soaked and starts to freeze to the bottom. A real treat. Now we're in northern alberta. That means people don't just put up houses ever 3 acres, that means he's walkin all night.
So we wait probably only 1 hour (shutting of sami and starting to save gas) and wholey ****, we see headlights at the opposite end of the tunnel!!!! It's our buddy with a quad! (the only other thing that could fit in the culvert) But what do you do in a ****ing culvert with nothing to winch to or tie to or anything? We snatchblocked the quad to the opposite end of the culvert edge and used both winch lines to get maximum length. We started winching and we broke all 4 ******* tires through. AWSOME, it is now resting on the exhaust and axels.
We then snatchblock the quad to the end we came in, and managed to winch it backwards using just the quad winch (thank god the sami is only 1500lbs). So that's great and all, but we're still not out of the river valley. We had to snatchblock the **** out of the quad to every tree we could to get it up the valley. We wrapped the quad around 4 or 5 trees to keep it anchored while realing the lines in.
Bla bla bla, we did make it out at about 2:30AM with only 11 frozen black toes and fingers, and smashed leafs and shackles. I'm not even going to talk about the guy's backyard wooden walking bridge we had to go over to get out.
Oh yah, and when I get home I see that my axels and brakes and everything are completely engulfed in ice. You can't even see the components. I took it to an indoor pressure washer (because it ain't going to melt for at least 3 more months of winter) and spent $40 just letting the water spray on the solid blocks of ice. Wow, I had brakes again!
NEVER WANT TO SEE A CULVERT AGAIN.
This was the samurai:
KIROUAC228 is offline
post #2 of 10 Old 08-21-2006, 07:41 PM
ImSuck
ImSuck's Avatar
1997
wow thats one hell of a story man to bad you didnt have any pics of it while u were there
-Andrew
Low Output 4 Cylinder Jeep Club member #59
Originally Posted by Grewe02
No such thing. Eat **** and die.
lifted with some extra's
......sold
ImSuck is offline
post #3 of 10 Old 08-22-2006, 12:24 PM
HawkeyeWJ
HawkeyeWJ's Avatar
Wow... I literally am COLD after reading that story... Glad you made it out! I woulda been ****ing!!!
- Jeep Encyclopedia
2002 WJ 4.7 Limited
Onyx Green Pearl
HawkeyeWJ is offline
post #4 of 10 Old 08-23-2006, 12:11 AM
Awshux
Cynical Bastard
Awshux's Avatar
That's a great story! Makes me glad I live in the desert!
You live and learn. At any rate, you live.
-Douglas Adams
Awshux is offline
post #5 of 10 Old 08-23-2006, 12:46 AM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
Good story. Although stressful, I bet you guys had a lot of fun.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #6 of 10 Old 08-26-2006, 10:33 PM
bvjeep
Bet you don't take that rout again. Unless you have someone else along with another rig too. Oh and you can have that extreme cold stuff too. Glad to hear you are ok though.
BV Jeep
99 TJ Red 4" Tomken Lift 35x12.50x15 BFG Mudders
Skyjacker 8000 Nitro Shocks
Remember: It Aint Perdy Till It's Dirty!!!!!
Colorado Jeep Member #1999
bvjeep is offline
post #7 of 10 Old 08-29-2006, 09:24 AM
Benjamin Dover
Crossbones
Benjamin Dover's Avatar
I know what you are talking about. Here in southern Alberta it can get that chilly, especially when we get into the mountains. 300' climbs to get out of a waterway in the winter can be a challenge, and it becomes worse when the winch-cable is only 100' long.
I normally carry a few extra snatch-straps along that I can tie together to get the extra length required to get to the top, if I am lucky
Glad you got out ok, and that we could read it in your own words instead of the writings of a reporter for a local newspaper.
Burn rubber, not your soul
Benjamin Dover is offline
post #8 of 10 Old 09-12-2006, 05:08 PM Thread Starter
KIROUAC228
KIROUAC228's Avatar
Thanks guys, yeah anyone from Alberta knows what I'm talking about when I mean cold. I'm from the Yukon and the wind in Alberta hands down beats the -50 celcius up there. That, and even if there WERE trees to winch to, pretty much all trees in Alberta are only about 6" in diameter MAX for some reason. That makes for interesting 4x4 trips along the way.
post #9 of 10 Old 09-12-2006, 11:42 PM
Jeepin_Al
Just taking it easy!
know the cool thing about -40 C? It is the same as -40 F. Interesting things you learn living in Alaska. I have a much better understanding of how dangerous a situation you where in. You are really really lucky. Glad to hear you made it out.
"rejected by the signature police"
Jeepin_Al is offline
post #10 of 10 Old 09-13-2006, 09:21 PM
jtpaintball70
jtpaintball70's Avatar
I am now even more glad I live in the desert :P
Nathan
KD5QHI
NREMT-I/85
jtpaintball70 is offline
Tank trapped Reelm n Rubi Jeep Carnage & Wrecks 9 02-06-2010 01:19 PM
Trapped by fire XJ2Timer General Discussion 7 12-31-2008 01:01 PM
Trapped in an elevator. JakeDS General Discussion 9 04-23-2008 06:19 PM
R Kelly's trapped in the closet lrsmithwhaley General Discussion 5 07-29-2007 06:53 PM
Ever Trapped A Skunk...? thejafe General Discussion 29 08-07-2006 06:51 PM
