zone lift installed. Do I need this piece? also alignment question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > zone lift installed. Do I need this piece? also alignment question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 08-29-2015, 07:36 AM   #1
DraykenK
I noticed they gave me all my old parts, once I got home. I noticed this plate. Does this plate normally stay off???
Second, as u can see from my alignment paper, my caster is off. What would I need to do to fix this? They apparently installed the align cam kit, but don't see a change.
I didn't get to talk to anyone really, I picked my jeep up at closing time.
DraykenK is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 09:35 AM   #2
TJDaveX
Fail rated
TJDaveX's Avatar
That plate is the transmission skid for 2003 and newer TJ'S. After lifting, the front driveshaft will contact that skid. I took mine off a long time ago.
Your options are to modify it to fit, get another aftermarket transmission/engine skid, or leave it off.
No help with the alignment printout. I've never had one. I just set the toe, and adjusted pinion angles with my adjustable control arms. Double adjustable makes it easy.
TJDaveX is online now   Reply With Quote Quick reply to this message
Unread 08-29-2015, 10:39 AM   #3
joe_jeep
For a lifted wrangler, your caster is pretty good.
If your front shaft has no issue with it, then its fine.
The trans skid wont work with a lift.
Leave it off.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 12:19 PM   #4
TheBoogieman
The Hills have Eyes
TheBoogieman's Avatar
Caster is fine and nothing can be adjusted other than the toe. I notched out my skids on my two 03' autos.You can just leave it off if you're not planning on hitting any rocks.
If you can tolerate the Bilsteins, that will invalidate any discussion you and I may have from now on.They are quite possibly the most annoying damper I've ever used.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 08:20 PM   #5
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Really?
Were adjustable lower front control arm cam bolts installed?
Did they install adjustable control arms?
Filling-in your profile would help with future questions...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 08:40 PM   #6
deputyjason
THe front driveshaft will hit the left "arm" of the skid.
Cut it off and reinstall it. I did and mine has taken a beating, and anything is better than nothing protecting the thin sheetmetal trans pan.
deputyjason is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 08:53 PM   #7
TheBoogieman
The Hills have Eyes
Originally Posted by Knuckelhead View Post
Really?
Yup.
Nope.
Unread 08-29-2015, 10:26 PM   #8
Knuckelhead
AFSOC Retired
As the OP hasn't responded yet,
Yup.
Nope.
Nope.
Yep...
Unread Yesterday, 07:49 PM   #9
gmiller0737
I wouldn't worry about Caster Readings Like Those My TJ Has simular Caster Readings & Handles Fiine,Caster will not cause Tire Wear.
gmiller0737 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:08 PM   #10
DraykenK
"Did they install adjustable control arms?"
No. And sorry for not coming back to the post sooner. And I'll just leave the skid plate off for now. I don't offroad.
Unread Yesterday, 09:40 PM   #11
Knuckelhead
AFSOC Retired
And what about the cam bolts?...
