zone 4" lift - JeepForum.com
post #1 of 26 Old 02-19-2012, 05:28 PM Thread Starter
mattdieseltech
zone 4" lift
i am thinking about buying a zone lift for my 97 tj i have 2" pro comp with 33/12.5 tires just need info will this kit work with out a sye for a little while I am little worried about vibs it is not my daily driver just a toy never seen snow
mattdieseltech is offline
post #2 of 26 Old 02-20-2012, 08:58 AM
sdptrey
I installed a 4" zone couldn't be happier. Little vibe but it could be my tires too. I don't plan on getting the sye or ds anytime soon. I do plan on installing a motor mount lift and using washers for the transfercase drop. Its a good affordable lift
sdptrey is offline
post #3 of 26 Old 03-03-2012, 07:56 PM Thread Starter
mattdieseltech
zone
i went with a zone lift kit nice kit took out 2" pro comp lift kit easy to install went ahead put a new re 1600 front track bar in and a crown tie rod assembly you will need new brake lines if you disconnect track bar over all good kit shocks a litte cheap i upgraded to nitro shocks just finshed putting heater core in went real good easy to install go to aut zone to buy heater core tried 3 from o reillys looked cheap would not fit in air box lines were bent wrong
post #4 of 26 Old 03-03-2012, 08:10 PM
LiveAndLearn
love my zone lift
LiveAndLearn is offline
post #5 of 26 Old 03-03-2012, 08:42 PM
04rockymnttj
I did the zone combo lift its great I love it. mml and bl correct the vib problems
Lets go UK!
04rockymnttj is offline
post #6 of 26 Old 03-03-2012, 09:01 PM
Cuder
I installed the Zone Combo lift also. I had to run the 3/4" transfer case drop and 4 washers to get rid of most of the vibes, also had the MML installed.
I just installed a SYE/CV driveshaft and it is smooth now. It also has better throttle response at high speeds and I don't have to downshift when I'm going up hills. I can get it up to 65 mph pretty quick when getting on the highway also.
There is no way I would ever put a lift on another Jeep over 2" without having a SYE installed first. You can see what I installed in my build thread below.
My Build Thread:
Cuder is offline
post #7 of 26 Old 03-15-2012, 05:55 PM Thread Starter
mattdieseltech
bad vibs at 60mph and up need help
just installed 4 zone lift tc drop new tc mount newer u-joints ck drive line angle pinon 8 drive shaft is 15 and 8 at tc geting a vibration at 60mph and up in the rear only under load clutch in goes away it's really not a constant vib around 3sec between vids varies with speed and rpm will a sye fix this i thought a drive live vid would be all the time or at lower speed any thoughts
post #8 of 26 Old 03-15-2012, 06:32 PM
STIFLER
what's this? not nutswingers and it has been almost an hour since the OP posted?!?!?!?! Zone is a great mid level kit
0311/2531 USMC YUT
STIFLER is offline
post #9 of 26 Old 03-15-2012, 06:55 PM
kashoggio
Wtf...
2004 TJ RUBICON~ LIME GREEN
"Some desire is necessary to keep life in motion."
kashoggio is offline
post #10 of 26 Old 03-15-2012, 07:29 PM Thread Starter
mattdieseltech
zone is good kit great customer service they tried to help spent a lot of time on the phone could just be my jeep if i had to over again i might have went with re kit with free sye i think in comes with all 4 upper control arms from group4x4 would have been cheaper in the long run and less of a headach
post #11 of 26 Old 03-15-2012, 07:55 PM
Cuder
Originally Posted by kashoggio View Post
Wtf...
Just what I'm thinking
Dude, really!!! Slow down and type so people can understand what you are trying to say, please!!
My Build Thread:
Cuder is offline
post #12 of 26 Old 03-15-2012, 09:37 PM
Photog2000
Ask your girlfriend about punctuation..............
Photog2000 is offline
post #13 of 26 Old 03-16-2012, 12:54 AM
TheBoogieman
Jeepaholic
TheBoogieman's Avatar
You'll need more than new brake lines if you disconnect your track bar.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #14 of 26 Old 03-16-2012, 04:32 AM
STIFLER
LMFAO! You will need new underwear if you disconnect the trac bar! fo sho!
0311/2531 USMC YUT
STIFLER is offline
post #15 of 26 Old 03-16-2012, 05:16 AM
gyastine
Installed the Zone 3 inch lift recently. Have the kits TC drop with 2 additional washers on each bolt. Have vibs under hard acceleration still. Trying to decide between a MML or SYE and double cardan rear drive shaft. If I go the DC drive shaft route will I need anything other than adjustable UC arms?
gyastine is offline
Zone 4" lift vs Rough Country 4" lift?? JUPITERSAHARA TJ Wrangler Technical Forum 52 11-15-2013 07:50 PM
Zone off road 3" lift -vs- RC's 2.5" DISCUSS CCJ TJ Wrangler Technical Forum 36 11-06-2011 08:04 PM
4.25" Zone Lift Q's T's '97TJ TJ Wrangler Technical Forum 9 07-11-2011 12:18 AM
Zone 3" Lift DstroyrOfWrldz TJ Wrangler Technical Forum 41 12-15-2010 04:00 PM
Zone 3" Lift On "Grass Hopper" fan45acp JK Wrangler Technical Forum 21 06-13-2010 11:20 AM
