Zone 3" Lift - Page 2 - JeepForum.com
post #16 of 42 Old 08-13-2010, 03:46 PM
abelltj
i got the zone 3in kit...i love it. install went extremely smooth when i put it in like 2 months ago. no need for extended brake lines (at least on my jeep) the only thing i recommend is that you use strut compressors that you can rent from a local auto parts store. the ride is smooth and it seems to be made of quality parts. i'd say go for it its a quality lift. here is a pic.
abelltj is offline
post #17 of 42 Old 08-13-2010, 05:42 PM
jerseyjeep22
RC is what you would expect for the price. If at all possible, spend the money on the zone. I run an RC, and being an 18 year old kid, I worked with what I had. I like my set up, but obviously if I had had the money/choice, I would have went a different direction.
jerseyjeep22 is offline
post #18 of 42 Old 08-13-2010, 09:01 PM Thread Starter
DstroyrOfWrldz
definitely possible...for the RC kit I'd be looking at $299 for the suspension and another $115+ for body lift since the BL in the RC 3.25 kit isn't compatible with the 6 speed. Then I'd be getting an $18 rear track bar bracket. So I'd have $432 into the lift and still not have the extended sway bar links and bump stop extensions that come with the $459 Zone lift.
EDIT: I didn't consider the Jeepforum discount on the RC in those figures but still, the difference to me is worth it if I'm getting a better lift.
Not to mention I would save the install time for the body lift since I should be able to clear 33's with the Zone by itself.
So really, for me it makes sense.
Joe
2005 Wrangler Unlimited (Sold)
DstroyrOfWrldz is offline
post #19 of 42 Old 08-13-2010, 09:53 PM
jerseyjeep22
You should be good with 33's on 3 inches. let us know how it works out
post #20 of 42 Old 08-13-2010, 10:03 PM Thread Starter
DstroyrOfWrldz
yeah now I just gotta decide what tires and wheels I want.
I planned on Soft 8s with 4" backspacing and 33x12.5 duratracs but I really prefer the narrower tire look from 33x10.5 or 32x11.5, and duratracs don't come that size. i like the duratracs because they're more aggressive than most ATs but aren't so aggressive as to make a hellacious racket like an M/T.
I just need to look at more pictures I guess. I just dont want to have too much of the monster truck affect where the tires stick out way too far from the body.
Joe
post #21 of 42 Old 08-14-2010, 09:08 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I'm not sure if you are aware of this, but Zone also has a 4.25" combo kit that includes their 3" suspension lift, a 1.25" body lift, and a motor mount lift.
You can clear 33s with just the 3" lift, but I think it looks and works a little better with the body lift too.
Wheelin98TJ is offline
post #22 of 42 Old 08-14-2010, 10:23 AM
GroceryGetter01
I have run my zone lift for about 6 months and I love it!
Yellow Jeep Club Member #802
Originally Posted by JLC08JK View Post
Load up all the recovery gear!!!!
We're goin' to the "MALL"
-Jason
GroceryGetter01 is offline
post #23 of 42 Old 08-14-2010, 12:35 PM
Rino1425
When i do my lift, this is what i plan on getting.
Rino1425 is offline
post #24 of 42 Old 08-14-2010, 12:53 PM Thread Starter
DstroyrOfWrldz
i agree it looks better, and I'll definitely do it, but I'll probably just wait and do it separately after a few months.
The LJ needs new tires pretty bad so I don't want to wait any longer than I have to, and I want to keep some money around for a new exhaust and a dyno tune on the Harley before I jump back into modding the Jeep again.
Joe
post #25 of 42 Old 08-14-2010, 09:33 PM
aspjeepguy
2016 JK Wrangler
Here are pictures of my 3" BDS with a 1.25" JKS BL
Oh and I am running the 255x85R16's on my stock moabs. They are 33" exactly.
aspjeepguy is offline
post #26 of 42 Old 10-21-2010, 04:16 PM Thread Starter
DstroyrOfWrldz
finally got around to ordering the Zone 3" lift. Will order an adjustable front track bar too before installing, and probably drive around on the stock 30" tires for a week before installing the 33x10.5 KM2's.
Joe
post #27 of 42 Old 10-21-2010, 04:54 PM
drewtj05
Just to clairify Zone is NOT made by BDS Suspension they are different divisions of Truckmaster. They are however engineered by the same people, therefore the quality of BDS and Zone is pretty similar.
drewtj05 is offline
post #28 of 42 Old 10-21-2010, 05:02 PM
SOLIDJP44
if i knew what i know now i would have gotten 3" aev progressve coils and outffited all four corners with oem nitrochargers like what im doing now.
-00 Mildly Modified Wrangler SporT-Sold
2011 GMC ALL/Terrain Sierra z71-Current
SILVER JEEP CLUB MEMBER #55
SOLIDJP44 is offline
post #29 of 42 Old 10-21-2010, 05:09 PM
drewtj05
AEV is one of the best companies in the business but their coils are a bit pricey at about 350 for a set, not including anything else, but like I said they are one of the best.
drewtj05 is offline
post #30 of 42 Old 12-04-2010, 11:14 PM Thread Starter
DstroyrOfWrldz
finally got around to installing the lift.
Somehow I ended up with fine thread 10mm nuts for the stud on the top of the front shocks, but the thread on the stud is 3/8"-24. At first I thought it was the paint galling up in the threads but I ran a die over the them to clean them up and the nuts still wouldn't go on so I made a run to the parts store.
Everything else with the kit worked out, though my Jeep didn't wish to cooperate. The upper stud on the old front shocks had to be cut off with an acetylene torch, and three of the four upper shock mount bolts in the rear broke off. Tomorrows task is breaking the tack welds on the nuts, cutting an access hole in the floor and installing new nuts and bolts to mount it. Then probably mount my Currie front track bar and do a garage alignment.
Here it is with the stock tires. Hopefully I'll be able to get the tires mounted next week.
Joe
suspension lift , zone , 3"
Zone 4" lift vs Rough Country 4" lift?? JUPITERSAHARA TJ Wrangler Technical Forum 52 11-15-2013 08:50 PM
Zone off road 3" lift -vs- RC's 2.5" DISCUSS CCJ TJ Wrangler Technical Forum 36 11-06-2011 09:04 PM
Zone 3" Lift On "Grass Hopper" fan45acp JK Wrangler Technical Forum 21 06-13-2010 12:20 PM
Zone 4" lift kit DRZ2752 TJ Wrangler Technical Forum 3 09-20-2008 11:51 AM
Zone Off Road 2" lift. CreepJeep JK Wrangler Technical Forum 6 06-20-2008 03:40 PM
