Quantcast Zone 3" Lift - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Zone 3" Lift
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 07-31-2010, 01:08 PM   #1
DstroyrOfWrldz
Zone 3" Lift
3" TJ Suspension System
searched this place for a couple weeks and seen a few recommendations based on Zone being made by the same folks as BDS but haven't found a lot of people that actually have installed one and have anything to say about it.
Complicating the situation is this is my first Jeep and the amount of info on this forum is almost overwhelming. Not totally clear on what extras I'll need on top of what's in the kit, like brake lines, adjustable track bars, etc. Then I read about track bars hitting diff covers.
Joe
2005 Wrangler Unlimited
DstroyrOfWrldz is offline   Reply With Quote
Old 07-31-2010, 01:46 PM   #2
SugarBear
1969 CJ5
Go with a Rough Country 3" Lift. It'll be cheaper than that, and you'll have a JF discount. You won't need tracbars or brakelines, just a TC drop and MML if you have any vibes.
1969 CJ5
2.5" Rancho Kit/Shocks/Steering Stabilizer, 2" Shackles, Koenig PTO Winch, 31x10.5x15 Cooper STT's
SugarBear is offline   Reply With Quote
Old 07-31-2010, 01:58 PM   #3
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
That's a complete kit with extended sway bar end links and all.I'd still do an MML and less t case drop(if needed).I always go with RC,but might try that in the future to compare the two.Just for reference.RC 3.25" lift/1" BL/MML(with 35's).Rear track bar relocation bracket($18),redrilled the front track bar hole(instead of buying an adjustable front track bar).You don't need extended brake lines and front disconnects are inexpensive at RC.
TheBoogieman is offline   Reply With Quote
Old 07-31-2010, 02:11 PM   #4
stevefarling
Junior Member
stevefarling's Avatar
I'm new and dumb! What's an MML?
stevefarling is offline   Reply With Quote
Old 07-31-2010, 02:13 PM   #5
TheBoogieman
Demonic Jeep Freak!
You're learning,not dumb.It's a motor mount lift that does almost the same as a t case drop that comes with most lift kits.It lifts the motor that tilts the driveshaft downward and almost equals dropping the transfer case to align the driveshafts and stop vibrations that mess up your U-joints.
Old 07-31-2010, 02:15 PM   #6
SugarBear
1969 CJ5
Motor Mount Lift. When you get a lift, it changes the angle of the driveshafts, and a MML will fix that
1969 CJ5
Old 07-31-2010, 02:25 PM   #7
SOLIDJP44
motor mount lift around 1 inch
-00 Mildly Modified Wrangler SporT-Sold
SILVER JEEP CLUB MEMBER #55
SOLIDJP44 is offline   Reply With Quote
Old 07-31-2010, 04:33 PM   #8
DstroyrOfWrldz
there doesn't appear to be one that's 3" even...you talking about the 2.5" suspension with 1.25" body lift or the 2.5" springs with the 3/4" spring spacers? The one with the body lift says it doesn't fit 05-06 models with 6 speed manual trans, doesn't tell me why though.
Eventually I'll do a MML but for the time being I'll just use the included t-case drop.
Joe
Old 07-31-2010, 04:48 PM   #9
DstroyrOfWrldz
oh and the idea is to fit 33" x 12.50R15 Duratracs on wheels with 4" backspacing.
I suppose I could do one of the folowing:
RC 3.25 spring/spacer combo for $369.
RC 2.5" suspension lift, sway disconnects, and 1-1/4" BL from another manufacturer for about $500.
Anybody know why RC says their 1.25" BL won't work on 6 speed manual TJ's but they have 2" and 3" kits that do? What's different about their kit that other companies kits seem to work?
Joe
Old 07-31-2010, 05:59 PM   #10
Whobeme
I'm running the Zone 4" lift kit. It came with everything needed to lift my LJ. I've had two BDS lifts and now the Zone. The Zone kit is just as nice and rides just as good. I'll be buying another Zone kit for my wife's Jeep when the time comes.
Whobeme is offline   Reply With Quote
Old 08-01-2010, 07:12 AM   #11
aspjeepguy
I almost bought the Zone Lift but I ended up getting the 3" BDS. The last time I cheaped out on on a lift I regretted it for 4 years. My 3" BDS which is probably very similar to the 3" Zone rides like a dream.
Johnny
aspjeepguy is offline   Reply With Quote
Old 08-13-2010, 01:04 PM   #12
srlbotanical
Johnny
Zone is made by BDS... They are both based out of Coldwater, MI.
Two Trackers 4WD Club
www.twotrackers.org
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline   Reply With Quote
Old 08-13-2010, 01:09 PM   #13
2006_Sport
Cheaper isn't always better. Zone and BDS are way better quality than RC.
OP: The Zone 3 inch is a good kit. PM grocerygetter01 on here about it, he runs it with a set of 32s.
SUPPORT THE TROOPS
2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear
-Zach
2006_Sport is offline   Reply With Quote
Old 08-13-2010, 01:36 PM   #14
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I helped a friend put a 3" Zone kit on his TJ 3-4 months ago and it turned out pretty nice.
It rides great.
Zone and BDS have common ownership.
The manufacturers of their parts are the same in some cases, and in other cases they are different.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 08-13-2010, 02:31 PM   #15
SOLIDJP44
boogie, where did you get your jeepaholics windshield banner at????? i like it much!
suspension lift, zone, 3"
Glock Forum
