Zone 3 Inch Lift Combo Kit - JeepForum.com
post #1 of 7 Old 10-08-2011, 08:19 PM Thread Starter
rwilson93
So after a lot of research and discussion I am ordering the Zone 3 inch lift combo kit with the 1.25" BL and 1" MML. I am getting adjustable front and rear track bars, steering stabilizer, and quicker disconnects. I am getting 33x12.5's to go with it. Please advise what else I will need to get this rolling straight and smooth. Thanks for the help.
rwilson93 is offline
post #2 of 7 Old 10-09-2011, 11:42 AM
NAlbertaTJ
I've been using this lift for a year. I'm just ordering the MML and BL now. I also just ordered the 8 Cyrrie/Savvy control arms
NAlbertaTJ is offline
post #3 of 7 Old 10-27-2011, 10:29 PM Thread Starter
rwilson93
Did you put in the xfer case drop? Was that good enough with all stock control arms to get rid of any drive line vibes? I am putting in the 3" lift this weekend but not the BL/MML. I did buy front & rear track bars... I can't afford a whole set of control arms right now. Are you running 33's?
post #4 of 7 Old 10-27-2011, 11:15 PM
Lucille92
I put on there 4" lift in March and so far so good, no death wobble or anything. I still need to get adjustable control arms and a SYE instead of my transfer case drop though. Just make sure you tell them your a jeep forum member and you get free shipping. I also got the Rough Country quick disconnects which work alright, there just a pain to put on and take off, i don't think ive ever done it with out using a rubber mallet at least once.
Lucille92 is online now
post #5 of 7 Old 10-28-2011, 03:54 AM
rikkards
rikkards's Avatar
I had a BL and MML (JKS and Brown Dog respectively) from before. I don't have vibes with the hard top on and sometimes it seems like I may have a bit with it off intermittently depending on how I drive however I do not have the TC drop on. Thinking I am going to do an SYE anyways next year.
rikkards is offline
post #6 of 7 Old 10-28-2011, 04:24 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
I ran that combo lift with 3/4" spacers up front to level it out.I had 35's.Smooth ride and no vibes at all.
TheBoogieman is offline
post #7 of 7 Old 10-28-2011, 10:26 AM
jjmd
I have the exact lift, except I opted for Brown Dog MML (just my choice) and got almost 5" total lift, I have a hardtop, but no heavy bumpers or winches. I did not do a TC drop, and do not get any vibrations (probably just lucky). I still will install a SYE at some point, when coins pile up a little more. Also put on Currie Rock Ribz but they don't increase weight much. I also put JKS quick connect sway bars. Very happy with results.
Dr J
jjmd is offline
advice help , zone 3" lift
Zone 4.25'' Combo Lift! Th1rt33n TJ Wrangler Technical Forum 227 01-01-2014 05:15 PM
3 inch zone suspension lift 04rockymnttj TJ Wrangler Technical Forum 55 01-17-2013 05:42 AM
3 inch zone lift jeepguner TJ Wrangler Technical Forum 15 03-08-2012 04:59 AM
Zone 4.25 combo lift dudleydoright15 TJ Wrangler Technical Forum 3 06-29-2011 05:57 PM
4 inch ZONE lift kit jeepNB JK Wrangler Technical Forum 3 04-20-2010 06:37 AM
