ZJ tie-rod swap - JeepForum.com
post #1 of 3 Old 08-01-2010, 11:17 AM Thread Starter
cwdrlove
Which Stabilizer with ZJ tie-rod swap?
I'm doing the swap today to the heavy duty Moog parts. I am also replacing my factory steering stabilizer with a Rancho 5000. What I'm wondering is, am I right that I need to get the SS for the ZJ? They have different part numbers, RS-5401 for the ZJ and RS-5407 for the TJ.
ΜΟΛΩΝ ΛΑΒΕ!
cwdrlove is offline
post #2 of 3 Old 08-01-2010, 12:16 PM
cpleasant
cpleasant's Avatar
Your ss doesn't hook to the tie rod, it hooks to the drag link. Nothing is changed with the drag link setup. The ss should be the same. I have a ZJ tie rod with the stock ss.
Originally Posted by liredneck View Post
I know your rite I seid the dealer seid the same thing as you and that I don't want them there , but I was asking another qeustin as in what do I do about the slots in the brackets couse if I just put a bolt in there it will slide back and fourth but again thank you all knowing and powerfull jeep god sorry us lesser jeep peeons might have some more qeustins in the future , so please if there to much for you sit back relax go to the next post
cpleasant is offline
post #3 of 3 Old 08-01-2010, 12:26 PM Thread Starter
cwdrlove
Right you are, thanks for getting me back in line! It must have been the dang warning message that popped up on Advance Auto's website when I was checking parts availability. "Warning, this part will not fit your 1998 Jeep Grand"...etc, etc.
ΜΟΛΩΝ ΛΑΒΕ!
cwdrlove is offline
zj , tie rod , swap
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Rubi swap / Axle swap (merged) tjmike TJ Wrangler Technical Forum 5 06-10-2010 01:04 PM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
