ZJ Tie rod or Crown Rough trail HD tie rod? - JeepForum.com
post #1 of 44 Old 03-02-2011, 05:07 PM Thread Starter
trailinAZ2MI
Ok going to be swapping out the tie rod and these look like two good and cost efficient options. ZJ has to be the V8 version, and uses the stock drag link. The Crown HD RT looks pretty good and beefy, but its hard to find info on. Let me know what you guys think... Opinions, observations, and knowlegde welcomed and appreciated.
trailinAZ2MI is offline
post #2 of 44 Old 03-02-2011, 05:40 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Crown HD steering = ZJ V8 steering.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 44 Old 03-02-2011, 05:41 PM
munroejp
I just did the ZJ upgrade. It was really easy to do, got the parts from NAPA. Really like it.
What are your plans? If lots of offroading in the future, many reccomend the Currie HD upgrade.
munroejp is offline
post #4 of 44 Old 03-02-2011, 05:57 PM
chadsmeltzer
chadsmeltzer's Avatar
You can get the ZJ tierod from Autozone for $66. I like mine and it's held up great so far.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #5 of 44 Old 03-02-2011, 06:14 PM
noise_maker
thing about it this way - The ZJ rod cheep, easy to find a replacement or new ends for if in the middle of no where if you do manage to bend it or toast an end and in my experience its been fairly durable
I've been running a moog ZJ TR for a few years now and for my jeep on 33s it works great. Not that I recommend it but I have actually gotten hung up twice were the front end was support by just the tie rod sitting on a rock and had no lasting ill affects
noise_maker is offline
post #6 of 44 Old 03-02-2011, 06:17 PM
Neeco
MOOG ZJ swap.
"Before he shed any tears for the destruction of civilization and the death of man, he should discover whether civilization was destroyed and whether man was dead" ~ Earth Abides
"When you wake someone up with one hand on their throat and a blade in their mouth they become very compliant." ~ Cause
"You can't get us all"......."That's a fact, but you're first and he's second, do you care what happens after that?" Last stand at Saber River
Neeco is offline
post #7 of 44 Old 03-02-2011, 06:35 PM Thread Starter
trailinAZ2MI
Does it matter where you get the ZJ TR? Autozone, Moog, napa, checkers etc? and you use your stock drag link right?
I am thinkin i will go with this one
http://rustysoffroad.com/product/RS-TR125-UV.html
post #8 of 44 Old 03-02-2011, 07:17 PM
Unlimited04
why spend money on a super beefy tie-rod that uses stock ends?
the ZJ TR uses ~35% larger ends...and its cheaper...
Useful Write-Ups:
Funny:
post #9 of 44 Old 03-02-2011, 07:23 PM Thread Starter
trailinAZ2MI
35% bigger sounds good to me! and they fit with no modification?
post #10 of 44 Old 03-02-2011, 07:24 PM
Neeco
Exactly
Neeco is offline
post #11 of 44 Old 03-02-2011, 07:33 PM
AJeep
I did the ZJ upgrade it was very easy. I looked other options over, and they all used the original TR Ends and that is what I wanted to get away from. Now, the only other way I would, and will go one day is the Currie Steering.
Yesterday A jeep next to mine had it and it is twice the solid metal the ZJ upgrade is. Now its just another reason I need more mulla>
ZJ or Currie, depending on your budget
"I'm a great believer in luck and I find the harder I work, the more I have of it" (Thomas Jefferson)
BLACK JEEP SOCIETY
AJeep is offline
post #12 of 44 Old 03-02-2011, 07:35 PM Thread Starter
trailinAZ2MI
Sweet, thanks. So just go to napa or autozone? or dealership? or online? whats the best place?
post #13 of 44 Old 03-02-2011, 07:46 PM
Neeco
I got MOOG online for 127.00 with a discount. I got the Tie Rod, tr end, sleeve, and a can of PB blaster. Had it installed, and a STU OFFroad alignment done on an hour flat.
Neeco is offline
post #14 of 44 Old 03-02-2011, 09:04 PM Thread Starter
trailinAZ2MI
Alright thanks hopefully I can get this done next week. What tools are needed to do this? anything special?
post #15 of 44 Old 03-02-2011, 09:24 PM
chadsmeltzer
Autozone for $66.
You might want to rent a tie rod separator too, not always needed but helpful.
Will Crown Vic springs fit my 97 TJ SemperTJ TJ Wrangler Technical Forum 3 11-22-2010 01:25 PM
Anyone have experience with Rough Trail lifts by Crown Automotive Zackb911 TJ Wrangler Technical Forum 3 05-27-2010 08:27 AM
Crown SYE Commando81 TJ Wrangler Technical Forum 1 12-22-2009 08:11 PM
Crown Automotive phillies4752 TJ Wrangler Technical Forum 4 10-25-2009 03:25 PM
Crown Vic 8.8 MooseMarine YJ Wrangler Technical Forum 42 08-01-2009 09:17 AM
