ZJ spring install write up - JeepForum.com
post #1 of 12 Old 10-27-2007, 02:13 AM Thread Starter
badoosh27
badoosh27's Avatar
i've had a lot of requests for the write up, so here goes. you'll need the coils from a ZJ (Grand Cherokee) that was 4x4 and had a V-8 that was from the 90's i believe, not sure on the years that this works with. clean and spray paint them if you want to, i did mine blue.
chock the opposite set of tires or put the jeep in 4lo and in gear, so it doesn't roll. measure the height from the floor to a common point on all four corners so you can see how much lift you actually get out of it.
start with the front by unbolting the sway-bar at the axle on both sides, uses a torx wrench, so make sure you have the right one. unbolt the shocks at the top from inside the engine bay, works best in my opinion.
on some jeeps the coils are held in place by a retainer with a small bolt on the axle end of the coil, so undo that if you do have it.
get a jack that can go really high and put it under the frame on one side, i used a block of wood on top of my floor jack. jack it up until the coil is loose inside the perches (round things on the axle and frame that the coil sits in). now pull out the stock spring and replace with the front ZJ spring. don't stick your head between the wheel well and the tire while pulling the spring out b/c if it falls off the jack, theres no spring to keep the jeep from smashing your head on the tire, and then there'd be a funeral and no one likes those...
lower it back down and do the same thing to the other side.
leaving everything unbolted, move to the back and undo the shocks at the bottom(easier) and undo the sway-bar. jack up the same way as the front on the frame on either side in the back until the springs are loose. then replace with either the rear spring from the ZJ or your stock front coil. do the same to the other side.
bolt everything back together and check again that everything is good to go.
now measure your spots again to see how much it went up and give it a test drive, taking it out of 4lo of course.
this is just a recommendation of how to do this and i accept no responsibility if you hurt yourself or your jeep or anything else. also, if you don't think you can handle it, get someone to help you or have a shop do it. BE CAREFUL!!! and good luck. post pics of before and after if you got em.
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
badoosh27 is offline
post #2 of 12 Old 10-27-2007, 04:43 AM
Nikos
"i used a block of wood on top of my floor jack"
bad advice. jack stands are cheap and safe. don't use the floor jack as a jack stand.
good write up, thanks.
2000 tj 2.5l 4.56 dana 30 aussie locker /super35 ARB, 35s maxxis crawlers, RE3.5sf, RE monotubes, 1"BL, currie anti-rock, currie steering, or-fab cage,ARB bull bar, warn m8000
Nikos is offline
post #3 of 12 Old 10-27-2007, 09:27 AM
Mayfair_Jeeper
Mayfair_Jeeper's Avatar
How much lift did you actually get?
2006 Jeep TJ X Modded with toys
2008 Jeep Liberty Sport Stock
1987 Cherokee 4.0 Renix...Build in Process
Mayfair_Jeeper is offline
post #4 of 12 Old 10-27-2007, 11:29 AM Thread Starter
badoosh27
badoosh27's Avatar
i didnt use the jack and block of wood as a jackstand, i just needed a little extra height to get my jeep high enough to get the spring out...
i got roughly 2" out of it. if i park next to a stocker with my 32's, its about 3-3 1/2 inches higher.
post #5 of 12 Old 10-27-2007, 02:47 PM
Mayfair_Jeeper
hmmm....do you think you would be ablew to get 33's under there?
post #6 of 12 Old 10-27-2007, 03:08 PM
DBLJ
DBLJ's Avatar
With a bl you should be good to go for 33's.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #7 of 12 Old 10-27-2007, 03:24 PM
ErnieG
ErnieG's Avatar
did you guys get the springs from a junk yard or something and roughly how much did you spend? and also i herd only to use the front zj springs is that ture?
98 tj nothing special im too poor :(
ErnieG is offline
post #8 of 12 Old 10-27-2007, 10:59 PM Thread Starter
badoosh27
badoosh27's Avatar
i think i could fit 33's on there, but you'd have to get different wheels with diff. back spacing.
I bought mine off of eBay for 40 bucks
post #9 of 12 Old 10-29-2007, 06:43 PM
wahooz04jeep
what did you search for on ebay. I tried that and couldn't find any.
2007 Jeep Patriot Sport
OlllllllO
I wave
wahooz04jeep is offline
post #10 of 12 Old 10-30-2007, 12:25 AM
ErnieG
ErnieG's Avatar
same here no luck on v8 zj stock springs on ebay..... it might just be one of those things you gotta keep your eye on for a while before you actually find it
ErnieG is offline
post #11 of 12 Old 10-30-2007, 12:47 AM Thread Starter
badoosh27
badoosh27's Avatar
when i searched, there was only one set on all of ebay, so just keep an eye out. don't type in ZJ, write Grand Cherokee instead.
post #12 of 12 Old 10-30-2007, 07:06 PM
ErnieG
ErnieG's Avatar
can you use all four springs?
ErnieG is offline
Is there a write up on how do install a TT? cb19950 TJ Wrangler Technical Forum 23 08-04-2007 08:59 PM
Clock Spring write-up REDPILL TJ Wrangler Technical Forum 2 01-18-2007 06:47 AM
Good Write UP for RE 4.5 install? BigPeters TJ Wrangler Technical Forum 3 01-25-2006 04:33 PM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 11:10 PM
