Zerex G-05 Question - Page 2 - JeepForum.com
post #16 of 28 Old 11-05-2011, 08:22 PM
chris142
Originally Posted by J03_TJ View Post
Hey Chris,
What's your thoughts on this prestone stuff? I flushed and refilled my '03 with it about 3 years ago. Life-wise it claims up to 150,000 miles/5 years. Is there anything in the '03 block/cooling areas that wouldn't play nice with this stuff? Thanks if your still following this.
Okay, back to the original topic.
That's a Dexclone.I don't recomend that it be used in a system that does not have a pressurized overflow bottle.
chris142 is offline
post #17 of 28 Old 11-05-2011, 08:24 PM
Patrick H
Except that Prestone is green, not Dex-Cool orange.
'01 TJ
'48 CJ2A
Patrick H is offline
post #18 of 28 Old 11-05-2011, 09:07 PM
J03_TJ
EEk, I put that stuff in my jeep, now I find this out. Do you think it hurt anything? Okay so what would you recommend I replace it with. I thought it was the universal green stuff, it was green if I recall. Thanks for the info!
J03_TJ is offline
post #19 of 28 Old 11-05-2011, 09:21 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
check the radiator...here's what dexcool does...
http://www.jeepforum.com/forum/f9/wh...9/#post9555179
flush it quick....
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #20 of 28 Old 11-05-2011, 10:34 PM
J03_TJ
flush it quick....
Not sure there will be anything quick about it since it's been in there over 2 years.
So this Zerex G-05 is the ticket from what you stated in the link you provided. Now, have to see what they have at Napa, maybe even Walmart tomorrow.
J03_TJ is offline
post #21 of 28 Old 11-05-2011, 10:54 PM
JeephtimS
Zerex G-05 seems to be the best. I've seen what dexcool (orange) and the pink stuff does. And always use distilled water, never ever never use tap water or faucet water!!!!!!
97 TJ Sport, 2.5" front 1.5" rear lift, 31x11.5 15 Trxus STS on 15x10 Eagle Alloy 118s
JeephtimS is offline
post #22 of 28 Old 11-06-2011, 05:30 AM
BYuen
BYuen's Avatar
Are you guys sure you aren't getting confused between the two different types of Prestone coolant?
Here's the Dex-Cool version:
http://www.prestone.com/products/ant...st#product-411
And here's the regular Prestone (what I've been using after flushing my coolant system completely):
http://www.prestone.com/products/ant...st#product-378
It also says it meets the Chrysler specs (scroll down a bit):
http://www.prestone.com/learn_more/f...elect_region=1
If I recall correctly from the bottle, the non Dex-Cool Prestone is ethylene glycol based. I've been using that coolant for over 70,000 miles now with my original radiator and there is no abnormal corrosion at all. I still have the original radiator in my TJ with over 160,000 miles.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #23 of 28 Old 11-06-2011, 07:17 AM
Unlimited04
All coolant....HOAT, OAT and IAT...is ethylene glycol based....here's the MSDS for Prestone Dex-Cool - clicky
the chemistry problem arises due to the anti-corrosion additives. mixing the different types of additives is what leads to the contamination issues. the only stuff thats not ethylene glycol based is low-toxicity coolant, which is propylene glycol based (this chemical is also in toothpaste). the color is just a dye and has no relevance.
Here's an application chart - http://www.valvoline.com/pdf/Zerex_CoolantChart.pdf and http://www.englefieldoil.com/PDF/Zerex_chart.pdf
Useful Write-Ups:
Funny:
post #24 of 28 Old 11-06-2011, 07:17 AM
J03_TJ
http://www.prestone.com/products/antifreeze_coolant/product_list#product-411
http://www.prestone.com/products/antifreeze_coolant/product_list#product-378
http://www.prestone.com/learn_more/frequently_asked_questions?select_region=1
Any comments on this ^? I am not using the Dex-cool, I am using the yellow bottle stuff in the pic below.
this
vs.
this
J03_TJ is offline
post #25 of 28 Old 11-06-2011, 09:31 AM
TJJP77
TJJP77's Avatar
I would be wary of the Prestone stuff - they may claim they meet Chrysler's specs, but the reason why Chrysler uses a specific HOAT coolant is because of certain materials (such as solder) present in the cooling system that don't work well with OAT formulas...Best to stick with the Zerex G05 or the Mopar stuff.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #26 of 28 Old 11-06-2011, 12:47 PM
BYuen
BYuen's Avatar
this
vs.
this
After some searching it appears that all of Prestone's coolant is OAT based, but they say it's compatible with Chrysler's HOAT. I wouldn't mix the two. Just pick one or the other. It would be safest to go with HOAT, but if you've already flushed your system and switched to Prestone and have run it for a long time like I have, I wouldn't worry about it. Approaching 200,000 miles, I won't be too upset if it clogs or eats through my oem radiator. I check the coolant in my radiator often so if there's any abnormalities I should catch it early.
2001 White TJ Sport
BYuen is offline
post #27 of 28 Old 05-12-2016, 08:53 PM
rbnden
yes, the factory Mopar HOAT coolant is a pinkish-orange color. the OP asked if Zerex G-05 is orange, and it's not.
yes, any coolant turns bad over time. Any coolant that is neglected loses it's corrosion protection properties, and the entire system is subject to damage. There is no issue with HOAT if you change it every 100k as directed, but classic old green won't make it anywhere near 100k...so I don't see why you think HOAT causes more damage...
The HOAT will cause damage if not changed out as directed, because the silicates will drop out of solution and become abrasive.
rbnden is offline
post #28 of 28 Old 05-14-2016, 04:22 AM
hapbob
Zerex G-05
I just flushed the green for Zerex G-05 . It looked almost clear as far as color ? I just bought this jeep and the radiator was new. I was working on trans line leak and noticed green dripping out of radiator??? So I don't know what was in this jeep for its life but now it has Zerex G-05 if it matters at this point 105K miles.
Hap
hapbob is offline
coolant , dex-cool , prestone
where can i get Zerex G-05 natedawg87317 Wrangler General Discussion 4 11-13-2009 03:34 PM
Where to buy Zerex G05 or Mopar Coolant? WittSmall TJ Wrangler Technical Forum 1 10-29-2008 12:33 PM
zerex coolant? kllrbee TJ Wrangler Technical Forum 5 07-29-2008 11:20 AM
Zerex G-05 fitzz47 TJ Wrangler Technical Forum 2 08-05-2007 08:45 AM
Zerex G-05 question Jeeper X TJ Wrangler Technical Forum 4 09-03-2006 01:20 PM
