Zerex G-05 Question - JeepForum.com
post #1 of 28 Old 11-04-2011, 07:21 PM Thread Starter
Trendsetter75
2010 JK Wrangler
Zerex G-05 Question
I wanted to know if the Zerex G-05 is orange and if its corrosive to gaskets and seals.
2010 JKU (6-spd)
Trendsetter75 is offline
post #2 of 28 Old 11-04-2011, 07:27 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
no, its not orange, and no its not corrosive to gaskets or seals.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 28 Old 11-04-2011, 07:57 PM
chris142
Mine was PinkishOrange when my Jeep was new. I'm still not happy with the Long Life coolants. Ford was having tons of problems with their factory fill G-O5 and just this year switched over to Dexcool...........Which I hate more than G-O5.
Any coolant will turn Acidic if not changed out on time. It seems that the LL coolants do more damage than the old Green stuff did if neglected.
chris142 is offline
post #4 of 28 Old 11-04-2011, 08:04 PM
Unlimited04
yes, the factory Mopar HOAT coolant is a pinkish-orange color. the OP asked if Zerex G-05 is orange, and it's not.
yes, any coolant turns bad over time. Any coolant that is neglected loses it's corrosion protection properties, and the entire system is subject to damage. There is no issue with HOAT if you change it every 100k as directed, but classic old green won't make it anywhere near 100k...so I don't see why you think HOAT causes more damage...
Useful Write-Ups:
Funny:
post #5 of 28 Old 11-04-2011, 08:09 PM
chris142
.so I don't see how HOAT causes more damage than green when neglected for the same time period.
When Green goes bad you get rust which isn't good but most of it will flush out.
When LL goes bad it eats everything! It eats Aluminum, Metal, Gaskets and hoses. And it makes a sludgy mess. Often LL coolants don't make it to 100K.
Thats my take on what I've seen at work. I've never seen a Silicated coolant(old style) do the damage that a LL can do in a short time. YMMV.
Just posting what I've seen.
chris142 is offline
post #6 of 28 Old 11-05-2011, 02:48 PM Thread Starter
Trendsetter75
2010 JK Wrangler
If the coolant runs low should I add coolant itself or just you a little distilled water to it?
2010 JKU (6-spd)
post #7 of 28 Old 11-05-2011, 03:04 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If your 50:50 mix of coolant gets low, you add more 50:50 coolant.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #8 of 28 Old 11-05-2011, 03:11 PM Thread Starter
Trendsetter75
2010 JK Wrangler
My coolant is not the 50/50 mix its straight coolant
2010 JKU (6-spd)
post #9 of 28 Old 11-05-2011, 03:22 PM
Jerry Bransford
Administrator
I hope you're not really running straight coolant, I hope it's really 50:50 that you just didn't need to add water to. Straight coolant is a poor coolant, it needs water to cool as efficiently as your engine requires. Straight coolant does not cool nearly as well as 50:50 coolant/water does.
Getting
post #10 of 28 Old 11-05-2011, 03:38 PM
chris142
I'm assuming that he means that he has a gallon of pure coolant.He can either mix up a little with distilled water or add coolant this time and distilled water next time.That's how I do it.
chris142 is offline
post #11 of 28 Old 11-05-2011, 03:39 PM
Unlimited04
Mix up one Zerex container with 50/50 coolant, and label it as such for that purpose.
well thats a problem.
Useful Write-Ups:
Funny:
post #12 of 28 Old 11-05-2011, 06:55 PM Thread Starter
Trendsetter75
2010 JK Wrangler
Zerex comes in straight coolant and 50/50 mix, I have the straight coolant. It doesn't mean I just add straight coolant with no distilled water.
2010 JKU (6-spd)
post #13 of 28 Old 11-05-2011, 06:59 PM
Jerry Bransford
Administrator
That was totally confusing. Are you saying your coolant was never mixed with water and it's not the pre-mixed 50:50 stuff either? That you are running straight coolant with no water? If so, that isn't how you're supposed to run it... straight coolant without water does not cool well, it is supposed to be mixed with water.
Getting
post #14 of 28 Old 11-05-2011, 07:52 PM Thread Starter
Trendsetter75
2010 JK Wrangler
My original post is getting way off the topic here. My answer was answered!
2010 JKU (6-spd)
post #15 of 28 Old 11-05-2011, 08:07 PM
J03_TJ
Hey Chris,
What's your thoughts on this prestone stuff? I flushed and refilled my '03 with it about 3 years ago. Life-wise it claims up to 150,000 miles/5 years. Is there anything in the '03 block/cooling areas that wouldn't play nice with this stuff? Thanks if your still following this.
Okay, back to the original topic.
J03_TJ is offline
coolant , dex-cool , prestone
where can i get Zerex G-05 natedawg87317 Wrangler General Discussion 4 11-13-2009 03:34 PM
Where to buy Zerex G05 or Mopar Coolant? WittSmall TJ Wrangler Technical Forum 1 10-29-2008 12:33 PM
zerex coolant? kllrbee TJ Wrangler Technical Forum 5 07-29-2008 11:20 AM
Zerex G-05 fitzz47 TJ Wrangler Technical Forum 2 08-05-2007 08:45 AM
Zerex G-05 question Jeeper X TJ Wrangler Technical Forum 4 09-03-2006 01:20 PM
