Yukon 4.56 gears - JeepForum.com
post #1 of 13 Old 06-16-2008, 11:15 AM Thread Starter
BucketOKarma
Yukon 4.56 gears
I was wondering if anyone has any experience with Yukon gears. Good/Bad? what should I expect to pay for them on a Dana 30/35? NOT INSTALLED.
2000 2.5L 5spd 4.88, HP D30 w/OX, D35 open, 3" "FrAnKeNLiFt" with some stuff... LOOKING FOR Willys Edition TJ rear seat! to match the fronts.
BucketOKarma is offline
post #2 of 13 Old 06-16-2008, 11:34 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
going from 4:10s (that you have now) to 4:56 wont be worth the time/money/effort, just go 4:88s and 33s
RnEmOvr is offline
post #3 of 13 Old 06-16-2008, 11:58 AM Thread Starter
BucketOKarma
The biggest I plan on going for tires is 32"s, and that won't be for a bit, and my "Bucket" dogs bad enough with 31"s that I plan on regearing long before going with 32"s. As I understand, 4.56 will be a great help for the 4cyl with 31"-32" tires without making me over rev on the highway as much as 4.88s.... So again, I'm wondering if Yukon is good or bad, and how much should I be looking to spend just for the gears, without installation???
post #4 of 13 Old 06-16-2008, 11:59 AM
bigV
bigV's Avatar
yukon a friend of mine has broken 3 ring gears - altho he has a V-8 powered ZJ running 4.88s in his D30 - I'd go with Spicer, Superior, or Alloy USA (Precision Gear)
good shops around here charge about $500 just for labor - front and rear
High Desert 4 Wheelers
bigV is offline
post #5 of 13 Old 06-16-2008, 12:03 PM
bigV
bigV's Avatar
oops you asked NOT Installed - just saw that
check www.northridge4x4.com for prices
don't forget the master install kits
bigV is offline
post #6 of 13 Old 06-16-2008, 12:07 PM
never monday
about 500 for gears and install kits
mine have been fine
never monday is offline
post #7 of 13 Old 06-16-2008, 12:35 PM Thread Starter
BucketOKarma
The reason I'm asking, is because I was "cut a deal" by a friend of a friend. He says 4.56 gears for $250 (both front and rear) shipped....I was wondering if it would be worth it. Thats why I'm wondering how good yukon is. I know that spicer is the crowd favorite, but also considerably more. Is it worth it?
post #8 of 13 Old 06-16-2008, 02:07 PM
never monday
not a bad deal
post #9 of 13 Old 06-16-2008, 05:43 PM Thread Starter
BucketOKarma
Evening crowd, anything?
post #10 of 13 Old 06-16-2008, 06:29 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Unless you are able to install your own gears, don't buy them on your own to give to the installer in order to save a few bucks. By giving the parts to the installer to install, if something goes wrong the installation you will be stuck in the middle as the installer and gear dealer points their fingers at each other. The dealer will blame the installer and the installer will say the gears were bad and you'll be stuck trying to get a new set under warranty which will be like pulling teeth. And then even if you got new gears under warranty, the installer will want you to pay for his services again since he, remember, blamed the gears... not his installation skills.
Instead, have the installer provide all parts so if something goes wrong, he has no choice but to take care of the problem whether it's from bad parts or his bad installation technique which is the more common reason for a problem. Just tell him what prices you can buy them for online and push him to at least be competive which worked for me when I last had new gears installed. The installer pretty well matched the gear pricing I had found because he was looking more forward to the profit from the labor to install them.
Jerry Bransford is offline
post #11 of 13 Old 06-16-2008, 06:36 PM
PhulesAu
48K on a set of yukon's NOT A HITCH. people that keep breaking them, didn't install them properly.
PhulesAu is offline
post #12 of 13 Old 06-16-2008, 08:09 PM
Dogman
Dogman's Avatar
Dogman is offline
post #13 of 13 Old 06-17-2008, 07:54 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
Almost 2 years on my Yukon 4.56s now. Not the slightest problem from day 1
Proper installation is likely more important than gear brand.
Whybu1 is offline
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 08:19 PM
are Yukon gears any good jeepy-chan TJ Wrangler Technical Forum 11 04-15-2009 12:14 AM
To those with Yukon gears BamaLonghorn TJ Wrangler Technical Forum 7 11-14-2008 08:55 AM
4.56 Yukon Gears for D30 SteelBlueTJ TJ Wrangler Technical Forum 2 05-04-2006 03:24 PM
Yukon Gears Jeepdrivinmid TJ Wrangler Technical Forum 6 11-03-2005 04:33 PM
