Your thoughts on the D35 Chromoly 27 Spline Axle kits - All insights needed
| The Original 3/8" Ruffstuff Diff Cover! | Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Give me your insights, opinions (no matter how biased), stories,
technical facts, etc. I have done a fair amount of reading in the forums but think there may be enough info out there for some to really contribute to the adventure I am on. Background: I'm considering the D35 Chromoly 27 Spline Axle kit as a slight precaution. I would probably do fine w/o it, but a "little" peace of mind is what I am aiming at. I don't have any desire to get rid of my Truetrac as I love the way it handles on slippery pavement while still affording some decent off road behavior. I would call my wheeling mild (no rock crawling, just mud, snow, trails). I currently have the following set up on my 2000 TJ Sahara: D35 w/ Truetrac 33" BFG's 2" budget lift on stock springs 4L I6 stock engine 5 speed manual trans just added a hand throttle to get rid of gas peddle bounce I have found 2 sites with the kit for sale. I have not been able to determine who actually manufactures it. The Quadratec site lists "Crown" but I can't seem to find any viable info. http://www.quadratec.com/products/52403_200_07.htm http://www.************************.com/oscommerce/product_info.php?products_id=3250 A local guy says he can get a kit made by Alloy USA. However, Alloy USA's pdf catalog doesn't list a 27 spline product for the D35.
#2 |
You might want to look at the new Superior C-clip eliminator too if you just want a little extra protection.
http://www.4wd.com/productdetails.aspx?partID=41125 Says 30 spline, but I'm 99% sure that's an error and it's really 27 spline.
Texas, the only State to Have Ever Kicked Another Country's Butt |
#4 | ||
as far as the 27 spline shafts go its not a bad idea if you dont want to change the carrier. the true trac only comes in 27 spline for the D35 so that would be the only choice if you go that route.
Currently seeking employment in the automotive field or fabrication. PM me for resume and list of qualifications. |
#5 | |
chromo's seem like a viable option for my level of wheeling. But I really think that other people's experiences count so I have opened up the floor to y'all's experience, ideas, etc. An aside, I also like the idea of the c-clip eliminator but don't actually know how that could/would play into the setup I propose for myself. I've "heard" the eliminator has it's own set of problems like more leaks. Though I don't actually know how that works. |
#6 |
I ran my factory dana 35 axles on 35's with a tru-trac and 4.10 gears for quite a while and never had problem you'll be fine.
#7 |
Running Secretly Amok!
It's only a matter of time for that tru trac in the D35 too bust an axle with those 33s! Even with chromoly, which are more expensive anyway to replace then stock 27 spline! You might want to reconsider... building up that 35? Maybe save for an alternative D44 with a tru trac! Good luck!
#8 | ||
there are 27 spline locker choices for the D35. normally the lunchbox style lockers come in either 27 or 30 spline. i dont know about full case lockers though. from what ive read i dont remember seeing a 27 spline case locker.
#9 | ||
#10 |
hold on Jeepster
were talking about two totally different axles here. A 35 with a Trutrac and 27 spline 1.16 dia axles is weaker than a 44jr (S35). I have to agree with Golen on this one. If the OP is set on using a Trutrac then he should look to upgrading to a TJ44 with a Trutrac. If the OP was into getting a real locker the the 44jr kit is an option.
Get Savvy |
#11 |
My brother has the yukon 27 spline axles and true trac with 35s.Im amazed at what the d35 has taken from him and still rolls.lol i think you would be ok with your 33s and true trac .just my 2.
#12 | |
ok maybe i got ahead of myself then lol.
but i think the chromo 27 spline shafts would be strong enough for a true trac in a D35.
#13 |
Sorry, your right, I don't care for the D35! It's a week link with a locker or LSD with larger tires! I have snapped 2 axles and bent a 3rd with a tru trac! So yes I'm a little biased over the D35! I'm just saying it is only a matter of time! Yes I have done some hard core wheeling myself! This is why I can make this decision on D35 versus D44 locked! And as far as making that D35 as strong as a D44... I'm not buying what your selling! Sorry!
#14 |
Just too add on those 3 axles I tore up,,, they were Superior Chromoly!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
