You never know until you run out. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > You never know until you run out.
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectDan's 15% Birthday Sale!USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4
Unread 07-28-2015, 02:12 PM   #1
72andsunny
I drove my 99 TJ way below the E this morning, but was only able to fit 16 gallons in it. The gauge went well above the F, but as usual, it dropped below the F after about 20 miles.
Question for the group: Did I likely have another 3 gallons in reserve, or have I been unable to completely fill the tank?
72andsunny is online now   Reply With Quote Quick reply to this message
Unread 07-28-2015, 02:40 PM   #2
Jeepsr4me
What does your build sheet say you have for a tank?
if 19 then yes you had more in there.. If 15,...... well you was about sucked dry
get build sheet here
http://jeep.custhelp.com/app/jeep/e...WGxOMmc2T2w%3D
Jeepsr4me is online now   Reply With Quote Quick reply to this message
Unread 07-28-2015, 03:25 PM   #3
jjvw
jjvw's Avatar
You had 3 more gallons.
'03 Rubicon
jjvw is offline   Reply With Quote Quick reply to this message
Unread 07-28-2015, 04:30 PM   #4
72andsunny
I've got a 19 gallon tank. (Though the 16 gallons today is the most I've been able to fit in it.) It is painful to fill up. I was planning on buying an electric car, and the Jeep was supposed to be my beach car, but I'm not making enough money this year to claim the electric tax credit, so the Jeep is my daily driver until at least January.
Unread 07-28-2015, 05:20 PM   #5
emcee5000
The early TJ's 97 to 99 (maybe more) were built with the same gas tank, although 19 gallon was an "option". I cut the vent tube inside the tank and turned my 15 gallon into a 19 gallon. That trick was all the rage back in the early 2000's
emcee5000 is offline   Reply With Quote Quick reply to this message
Unread 07-28-2015, 10:45 PM   #6
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Did the fuel light come on?
When my fuel light comes on I have 2 gallons left in the gas tank. Almost all TJ's have different results.
The 15 gallon tank was only an option on the 2.5L equipped TJ... IIRC
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 07-29-2015, 06:12 AM   #7
GringoLoco
I've never run out of gas, and I've really pushed it out of curiosity on nice days when I had time to kill and wouldn't mind a little walk. If I fill it when the light comes on it takes about 15 to 16 gallons. The most I've put in there was 18 gallons. Usually when my gas light comes on I know I can wait until the way home from work the next day if I'm lazy (13 miles each way). My light seems to be more conservative than others, but it's never let me down.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline   Reply With Quote Quick reply to this message
Unread 07-29-2015, 07:23 AM   #8
Denzien
Denzien's Avatar
Maybe the OP has a 19ga tank with a 15ga sensor? Is that possible?
2006 LJ
2013 MINI Cooper S Convertible, Highgate Edition
2014 Honda Odyssey Touring
Denzien is offline   Reply With Quote Quick reply to this message
Unread 07-29-2015, 07:50 AM   #9
UTWeezul
I've run mine a lot with the light on and the most I've ever put in has been 16.5 gallons. But my light comes on really early. The TJ gas gauge is very inaccurate.
35" MTR Kevlars
TNT Phantom Fenders
PSC full corners w/ 3" flares
HP30 and 8.8 w/ lockers
UTWeezul is offline   Reply With Quote Quick reply to this message
Unread 07-29-2015, 07:58 AM   #10
Jeepsr4me
Just so ya know, the fuel pump is cooled by FUEL.... so when you running low the pump is not being cooled as well.
Why they say always keep it 1/2 full if you can.
Shortens the life of the pump... By how much I dont know.. Mythbusters would have to figure it out.
Unread 07-29-2015, 09:13 AM   #11
biffgnar
biffgnar's Avatar
The pump is cooled primarily by the fuel going through the pump more than the fuel outside the pump. There will be fuel going through the pump until it is empty and the pump will stop. This concern gets over exaggerated.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 07-29-2015, 09:27 AM   #12
Jeepsr4me
the exchange of heat happens both ways... A fluid transfer is greater than air transfer.
So when exposed to the air in tank the pump will be hotter than if it was under a fluid.
Unread 07-29-2015, 06:52 PM   #13
Knuckelhead
AFSOC Retired
Who is they? and can you show any reference to this in the OEM owners manual or FSM?...
Unread 07-30-2015, 07:29 AM   #14
Jeepsr4me
do a search on the net... There is a lot of THEY...
I am not qualified to say why or why not, I just say it seems logical and go with it.
Unread 07-30-2015, 12:11 PM   #15
Jeepsr4me
consumer reports was one THEY..
http://www.consumerreports.org/cro/n...stly/index.htm
