YJ to TJ transfer case swap - JeepForum.com
post #1 of 14 Old 07-06-2010, 01:47 PM Thread Starter
motobob
I was wondering if anyone knew what the differences were between the yj model np231 transfer case and the tj np231 transfer case. I ask this because I am in the process of putting in a yj np 231 into my tj. The differences I see so far are that the shifter arm is up instead of down, and that the yj transfer case is not fully open in neutral like the tj transfer case is. I am trying not to have to open these cases up. I am putting in this older model np 231 because it has a tera low kit installed in it. Thanks for the help.
motobob is offline
post #2 of 14 Old 07-06-2010, 02:29 PM Thread Starter
motobob
I did some more research and found that the tj 231's have a true neutral, but the yj transfer cases do not have a true neutral. Do you guys think this will pose a problem being flat towed. Will I have to do anything differently now?
I still am trying to figure out how to connect the linkage though. any help would be great
motobob is offline
post #3 of 14 Old 07-06-2010, 02:37 PM
NorCalCon
BigSquat has a build thread were he put a Rubicon Case in his YJ.
NorCalCon is offline
post #4 of 14 Old 07-06-2010, 02:44 PM
NorCalCon
post #5 of 14 Old 07-06-2010, 02:58 PM
NotURMailman
NotURMailman's Avatar
Yes, if you flat tow with the YJ t-case you will have to disconnect the rear drive shaft.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #6 of 14 Old 07-06-2010, 03:28 PM
SHAKEnBLAKE
subscribed. I just installed a t-case with an SYE in my TJ, and I'm having problems. I looked at the tag, and it says it's a 1996 t-case, so I'm not sure if it's a YJ or TJ case...
Ohio4x4.com
SHAKEnBLAKE is offline
post #7 of 14 Old 07-06-2010, 03:36 PM Thread Starter
motobob
Is this because I dont have a vacuum disconnect in my front axle? If you flat tow a regular yj you do not have to disconnect the driveline correct?
Thanks for the links guys but I am trying to go the other way from a tj to a yj transfer case. I switched all of the electrical but I am still trying to figure out the linkage. I just spoke to teraflex and he said that the linkage arm on the tj transfer case is clocked in a different position. I will try this when I get home. Any other input would be great.
motobob is offline
post #8 of 14 Old 07-06-2010, 03:46 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
the YJs use an internal slip yoke, while the TJs use an external slip yoke. better add a new YJ style slip yoke to your project list.
if it were me, i would pull the gets from the YJ case and install them into the TJ case, and also add a SYE at the same time. this way you do it all at once, you know it fits without screwing around with different linkages, and it will be a learning experience at the same time.
do it right the first time.
Mail crawling.
MisfitSeven is offline
post #9 of 14 Old 07-06-2010, 04:46 PM Thread Starter
motobob
Both t-cases have slip yoke eliminators already. I probably should remove the tera low and put it in my tj t-case. I am the one who originally installed it in the yj t-case so I already know how to do it. I was just trying to avoid it.
motobob is offline
post #10 of 14 Old 03-11-2011, 05:54 PM
aerojeeptj
Sorry to wake up a dead thread. I'm in a similar situation. My 2004 TJ t-case has some issues and I'm pressed for time/money and a buddy of mine offered me a 1995 Cherokee t-case for pretty cheap. I was gonna do an SYE to it and just swap t-cases. Will I have any issues (vaccum?, electrical?) going from an '04 to a '95?
aerojeeptj is offline
post #11 of 14 Old 03-12-2011, 10:31 AM Thread Starter
motobob
I think the elctrical will be the same. If I remember correctly the vacuum is different. If you can use the back half of your tj transfer case. Also use the shifter arm that goes into the transfer case from your tj. Another reason to use your tj inners is that a tj case has a true neutral where a yj case does not. In neutral on a yj case it spins both drivelines at the same speed.
This is all dependent on an xj case being the same as a yj.
98 jeep wrangler sport, 4' Fabtech lift, Skyjacker tummy tuck, Curried upper control arms(lengthened), Dana 30 with ARB and 4.88's, Rubi 44 with 4.88's, Rokmen corner guards, Tera Low transfer case kit, SYE, Much more......
motobob is offline
post #12 of 14 Old 03-12-2011, 11:11 AM
Luv-My-TJ
Works for me. I put a vacuum operated YJ t-case with a SYE in my TJ with no problems... direct fit other than the electrical connection swapped out where the vacuum was.
"I'm a TJ owner, I dont go waving like a retard who lost his helmet everytime i see a jeep. If you like to wave so be it, I have better things to do like running over boxes of puppies while driving drunk and texting from the other side of the highway." - KKiowaTJ
Luv-My-TJ is offline
post #13 of 14 Old 03-13-2011, 09:37 PM Thread Starter
motobob
Yes it is a direct fit but the internal are absolutely different. The yj doesnt have a true neutral. The tj does. It is better for flat towing to have a true neutral. Also the arm that shifts that transfer case is clocked 180 degrees off.
motobob is offline
post #14 of 14 Old 03-13-2011, 09:45 PM
dcioffjeep
If you decide to still put that 231 in the tj out of the yj hit me up with a pm, I would be willing to sell you the stock output shaft for cheap as I recently installed a sye so it is just sitting collecting dust.
Dave
My Jeep: 3in full traction lift, with front and rear upper and lower adjustable rock krawler control arms, front sway bar discos, and 33x12.5 Maxxis big horn tires, advanced adaptors sye with tom woods drive shaft. Hp 30 with 4.88 gears soon to come.
my build thread here: www.jeepforum.com/forum/f22/rocky-wrangler-1141329/
dcioffjeep is offline
transfer case , swap , np231 , TJ
88 4 cyl swap transfer case swap to 89 6 cylinder ? YjShane YJ Wrangler Technical Forum 1 03-26-2010 04:11 PM
Swap transfer case xinys JK Wrangler Technical Forum 4 06-23-2009 07:00 AM
transfer case swap gabulldogs YJ Wrangler Technical Forum 3 03-04-2009 10:51 AM
NP-231 transfer case swap BBCAT YJ Wrangler Technical Forum 2 12-09-2008 11:19 AM
transfer case swap ? saharajeepman YJ Wrangler Technical Forum 1 06-25-2007 07:16 PM
