YJ NP231J in TJ - JeepForum.com
post #1 of 9 Old 04-05-2013, 07:35 PM Thread Starter
Line58
YJ NP231J in TJ
Has anyone here installed a YJ transfercase in a TJ? If so, what did you do about the tcase shift linkage? Can the YJ linkage be used (nice and simple) on a TJ? Can the TJ linkage
be modified to accommodate the YJ case?
In using a 1994 YJ case that came with the AX15 I'm swapping in.
Line58 is offline
post #2 of 9 Old 04-05-2013, 11:59 PM Thread Starter
Line58
I now have the transmission and tcase in. The YJ linkage isn't going to work. Is their a way to modify the TJ trans shifter? Would a cable shifter fix this?
Line58 is offline
post #3 of 9 Old 04-08-2013, 10:31 PM
alloutbmx
I'm running one. Pretty sure we took all the yj shift lever off and just hooked the tj stuff right to it. I don't remember any issues
97 TJ, 4cyl 5spd, custom snorkel, 231sye kit, adams driveshaft shafts, 4.10, dana30 front, 8.8 ls rear. 6" front, 5" rear, 1"body, adj. track bars and front control arms, rock crawler steering, 35"s and much more
alloutbmx is offline
post #4 of 9 Old 04-08-2013, 11:13 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Pre 1995 YJ NP231 transfer cases don't have a true neutral:
http://www.pirate4x4.com/forum/jeep-...-np231-tj.html
" '94-and-earlier NP231s don't have a true Neutral position for trouble-free towing. When in Neutral, the input gear of the 231 separates from the front and rear output shafts, but the shafts are still connected. A special sector (available from JB Conversions) solves this problem. With a true-Neutral kit, the rear driveshaft spins independently of the rest of the drivetrain. Since the T-case oil pump is driven by the rear output shaft, lubrication of the T-case isn't a problem."
http://www.jpmagazine.com/howto/5449/index.html
Knuckelhead is offline
post #5 of 9 Old 04-08-2013, 11:35 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I have a TJ case in my Yj and sold my Yj case to a guy with a TJ.
Luck Favours The Prepared
Anticanman is offline
post #6 of 9 Old 04-09-2013, 02:54 PM Thread Starter
Line58
As I don't tow the Jeep that shouldn't be a problem. That said, when/if I ever pull the case apart for a HD conversion I'll have to install one of those.
Line58 is offline
post #7 of 9 Old 04-09-2013, 02:59 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
the input shaft spline geometry on the 94 & earlier is different than the 95 & up. the input shaft depth is also different IIRC. call JB conversions for more info...pretty sure you'd need to swap to the new-model input shaft.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 9 Old 04-09-2013, 03:06 PM Thread Starter
Line58
Thank you for that input, I didn't know that!
I'm doing a AX5 -> AX15 conversion using the Dakota bellhousing and YJ AX15/NP231J. As the trans and tcase are both from the same vehicle I should be fine. That said, I'm finding plenty of other areas where things don't seem to add up (tcase shifter, 4x4 indicator, speedo plug, trans support not lining up with skid plate, etc).
Line58 is offline
post #9 of 9 Old 04-09-2013, 04:29 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The indicator is easy enough. All the info you need is right here:
http://www.jeepforum.com/forum/f12/t...80/?highlight=
Just pick and choose which pieces you need to install. You may also run into a problem with the speedometer but I think that's been mentioned. Electric vs manual cable.
Edit: Nevermind on the speedo, its the same more or less.
