yj hood, grill and fenders on lj? - Page 2 - JeepForum.com
post #16 of 18 Old 07-11-2010, 06:46 AM
crusher242
Theres a guy running around my neighbor hood with a YJ front end on his TJ. I asked him about it and he kinda gave me a blank stare.
Hold onto something... Quick!!!
crusher242 is offline
post #17 of 18 Old 08-20-2010, 10:32 AM
sprowley
It should be pretty easy. The fenders and grille will *almost* bolt right up. The grille should. The fenders might have to have new holes drilled but they should be about the same dimensions.
The hood as others have stated is the issue. a YJ hood will fit the TJ grille fine, and vice versa, so no worries there. The YJ and TJ cowl curves are different so the hoods don't look great on the opposite model. This does mean though that you could use a TJ hood with the YJ fenders and grille with little to no issue.
92 YJ Islander Sold!
97 TJ Sport black on black with MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
sprowley is offline
post #18 of 18 Old 08-20-2010, 11:18 AM
TeeJay00
Originally Posted by Benderff View Post
The time space continuum will fall apart if you build such an abomination.
TeeJay00 is offline
yj , lj , wrangler , hood , fender , grill , swap , fit , install
tj hood and grill on a yj spring28 YJ Wrangler Technical Forum 9 03-04-2008 08:09 AM
Grill to hood seal- does your hood shake on the hwy? P35A JK Wrangler Technical Forum 7 07-23-2007 08:46 AM
Where can I get this grill/fenders Poseidon17 TJ Wrangler Technical Forum 15 03-28-2006 01:55 PM
hood/grill/fenders? bugeater YJ Wrangler Technical Forum 4 08-29-2003 09:10 AM
