yj hood, grill and fenders on lj? - JeepForum.com
post #1 of 18 Old 07-10-2010, 08:22 PM Thread Starter
8nine-sahara
im in the process of buying a lj with front end damage,
(it needs a whole new front clip)
and i have a yj grill, hood, and tube fenders sitting in my garage.
what i was wondering was if i could make it work with the lj.
would the hood line up with the rest of the tub?
i figure i could save some money and use what i have instead of spending money on tj parts
any input would be appreciated,
thanks
89 yj
06 lj
8nine-sahara is offline
post #2 of 18 Old 07-10-2010, 08:42 PM
Benderff
Benderff's Avatar
The time space continuum will fall apart if you build such an abomination.
Benderff is offline
post #3 of 18 Old 07-10-2010, 08:44 PM Thread Starter
8nine-sahara
well, if u give me a tj grill and hood,
ill gladly drop the idea haha
im just trying to use what i have,
and use the money for other things.
89 yj
06 lj
post #4 of 18 Old 07-10-2010, 08:52 PM
Benderff
Benderff's Avatar
I have seen some threads about grill swaps. Cj to YJ or TJ and TJ to YJ. They looked pretty easy. You might have some gaps here and there, but I think it would work ok. Try looking at the other swaps for a ideas.
Edit for some links to get you started. Since you have the hood and fenders also I think it would be fairly easy if you don't mind some problem solving.
http://www.jeepforum.com/forum/f12/c...l-swap-539404/
http://www.jeepforum.com/forum/f12/t...stion-1055475/
http://www.jeepforum.com/forum/f12/c...-model-183945/
http://www.jeepforum.com/forum/f12/c...s-pics-431224/
http://www.jeepforum.com/forum/f176/yj-grill-tj-961049/
Benderff is offline
post #5 of 18 Old 07-10-2010, 08:52 PM
USAFRecon
I would like to see how this works out
USAFRecon is offline
post #6 of 18 Old 07-10-2010, 09:07 PM Thread Starter
8nine-sahara
thanks for the links
i know people swap tj grills to yjs,
but since i have all the yj stuff, why spend more money? haha
i figured since i have everything it would work,
but i wasnt sure if the hood was the same shape as the tjs.
i figured it would deffinately be a head turner if you saw it driving down the road hahah
89 yj
06 lj
post #7 of 18 Old 07-10-2010, 10:30 PM
jjeeper
i say do it! then tell everyone u have a sick streched yj...
-Jordan
2003 Wrangler SE
jjeeper is offline
post #8 of 18 Old 07-10-2010, 10:35 PM Thread Starter
8nine-sahara
thats what i planned on
and ill even say i did a coil conversion too haha
89 yj
06 lj
post #9 of 18 Old 07-10-2010, 11:10 PM
jjeeper
and u didnt like the yj interior so u made the tj stuff fit... its a perfect plan, and then u will have something different than most of us.
-Jordan
2003 Wrangler SE
jjeeper is offline
post #10 of 18 Old 07-10-2010, 11:12 PM
never monday
I know the hood hinges are in different places, that's all I got
never monday is offline
post #11 of 18 Old 07-10-2010, 11:27 PM Thread Starter
8nine-sahara
thats actually exactly the kind of info i needed never monday, thanks.
i just needed to know the little things,
just to know what im getting myself into
89 yj
06 lj
post #12 of 18 Old 07-11-2010, 04:58 AM
jscherb
No, the hood won't line up with the body very well. The rear edge of the YJ hood won't match the the TJ/LJ cowl. The curve on the sides of the YJ hood is a larger radius than the curve on the TJ's cowl, so there will be gaps. Also the YJ hood is more or less flat across the top but the TJ cowl has a raised portion in the center, so there will be gaps there too.
If you want to use some of the YJ parts, using the YJ grille and fenders with a TJ hood would fit a lot better than using the YJ hood.
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #13 of 18 Old 07-11-2010, 06:27 AM
extsp2
the two that i have seen used tj hoods. looked killer.
extsp2 is offline
post #14 of 18 Old 07-11-2010, 06:38 AM Thread Starter
8nine-sahara
that's depressing, but I'm still determined to make it work.
thanks for the info, I figured the hoods were different, just didn't know how different.
89 yj
06 lj
post #15 of 18 Old 07-11-2010, 06:46 AM
BTNefler
From what I've been told the body lines on the side won't match up either. I have a friend wanting to do the same thing with a cj front clip but he is planning on cutting the body and welding it all back so all the body lines match up and everything.
BTNefler is offline
yj , lj , wrangler , hood , fender , grill , swap , fit , install
tj hood and grill on a yj spring28 YJ Wrangler Technical Forum 9 03-04-2008 08:09 AM
Grill to hood seal- does your hood shake on the hwy? P35A JK Wrangler Technical Forum 7 07-23-2007 08:46 AM
Where can I get this grill/fenders Poseidon17 TJ Wrangler Technical Forum 15 03-28-2006 01:55 PM
hood/grill/fenders? bugeater YJ Wrangler Technical Forum 4 08-29-2003 09:10 AM
