Quantcast Yey another in-cab winch controller install - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Yey another in-cab winch controller install
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 01-24-2006, 01:41 PM   #1
crgrissom
Master of Reality
crgrissom's Avatar
Yet another in-cab winch controller install
I just finished installing my RoadlessGear in cab winch controller, but I have a new variation on the installation location so I thought I'd share some pictures.
The controller has its own switch panel:
but I didn't really like any of the install locations I had seen. I decided to just take the switches and install them directly into the knee panel on the left side of the steering wheel.
First I popped out the panel and drilled holes to mount the switches in a vertical configuration, with the "arming" switch on top, and the momentary toggle below it:
Then I put the switches in:
I also ended up putting quick disconnects on the switch wires so I could take that panel out easily when needed, and I had to buy more wire at Ace hardware in order to have enough to get to the winch. I ended up buying 12 feet of wire and that was plenty. The 8 feet that came with the kit was not nearly enough.
Here is the "test fit" before I connected the wires:
I ran the wires to the winch through the firewall by drilling a hole in the clutch block-off panel (I have an auto tranny) and using a tight grommet:
I ran the wire (in wire loom) across the firewall to the passenger side, then to the winch following the main winch wires. Then I just had to connect the wires to the winch solenoids following the instructions:
Here's the finished product, with the "arm" switch off:
...and here is it "armed" ...
...works like a champ.
The arming switch needs a power source, so I used one of the ignition-switched leads from my Painless 7-circuit fuse box (I'll do a separate write-up for that) so that it is only functional with the ignition on. Of course the regular plug-in wired remote controller still works as usual.
I like having it on the left side of the wheel so no doofus passengers start playing with it. Also, I don't really like the switch plate that came with it (though I did have a black one). I think putting the switches in directly almost gives it a factory look.
Of course, there are no labels for the switches, but it is easy to remember. You "pull" the toggle switch down to pull the cable in, and everything else is obvious from there.
Chuck
Chuck Grissom
Black Jeep Society Member
My Jeep
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline   Reply With Quote
Old 01-24-2006, 01:51 PM   #2
SaharaJeep
Nice install
SaharaJeep is offline   Reply With Quote
Old 01-24-2006, 02:00 PM   #3
o3bluetj
Very clean,i like that!
o3bluetj is offline   Reply With Quote
Old 02-06-2007, 03:14 PM   #4
newbs
Jeepaholic
No picture yet but I bought mine and it interfaces with your cruise control, so when your off road (or any time you want) you can just control the winch with the cruise on one side and the other side to control your idle speed.
newbs is offline   Reply With Quote
Old 02-06-2007, 04:49 PM   #5
R. Potts
That looks real nice. Good job.
R. Potts is offline   Reply With Quote
Old 02-06-2007, 06:21 PM   #6
95BadBoy
crgrissom
Looks good! Clean install & nice pics.
95BadBoy is offline   Reply With Quote
Old 02-06-2007, 06:37 PM   #7
Rule303
Nice work!
Rule303 is offline   Reply With Quote
Old 02-06-2007, 07:16 PM   #8
GIJOE
GIJOE's Avatar
This is exactly what I have been looking for ever since I was out just cruisin' around not planning on doing any offroading. I left the remote at home and got buried big time. Now this upgrade is #1 on my list when the weather gets a little warmer. Or maybe sooner now that you have walked me thru it! Many thanks!!! Joe
GIJOE is offline   Reply With Quote
Old 02-06-2007, 07:45 PM   #9
Zoom By You
nice and neat....
2001 TJ Sport Amber Fire, Dual Tops/Dual Doors, 4.0, Banks Ram-Air, Banks S.S. Monster exhaust, five speed, NV3550, A.A. SYE/Tom Woods, 4:56 D30/D35, Detroit Truetrac at both ends, Solid diff covers, 4.5 R.E. Super Flex W/3.5 springs, adjustable upper and lower control arms, adjustable front and rear R.E. track bars, TeraFlex shock relocation brackets, R.E. Mono tube shocks, R.E. front stabilizer, R.E. 3/4" front spacer, 33 X 12.5 TrXus STS, M/T Classic-locks, ShrockWorks Rock Rails, Hanson 52" front bumper, EPi9.0 Superwinch with wireless control, Olympic rear bumper, Olympic Mountaineer rack, Bushwacker 6" Pocket Flares, Optima yellow top, IPF headlights W/ Fatboys, upgraded relay/wiring harness, KC Slims, Bosch rear lights, Garmin c550 GPS, Garmin 76S GPS, Cobra CB 148GTL W/Astatic Mic, Pioneer Sound, 3A Racing fire extinguishers. Manhattan Rated....
Zoom By You is offline   Reply With Quote
Old 02-06-2007, 07:47 PM   #10
Mattism78
Looks nice, I'm just not a fan of those long toggles. Seems like it would be easy to break off.
This is going to get expensive
Mattism78 is offline   Reply With Quote
Old 02-06-2007, 08:12 PM   #11
Michael_K
Good job!
Just realized, 98s have the headlight switch right there. Must install on the otherside!! Thanks for the great idea.
Michael K.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline   Reply With Quote
Old 02-06-2007, 08:35 PM   #12
Grubbi
I made my own controller using these directions. Click here.
Sorry for the bad picture, but you get the idea.
'99 TJ 4.0, 3" Rusty's Lift, 1" Tera Body Lift, 33"s on Cragar Soft 8's
Warn XD9000i
My Jeep
Terrain Stompers Jeep Club Cincinnati, Ohio
Grubbi is offline   Reply With Quote
Old 02-07-2007, 12:09 PM   #13
BlueFlame
The same thing but with one of the red shielded "arming switch" type of switches would be great. Keep from from hitting it with your knee.
BlueFlame is offline   Reply With Quote
Glock Forum
