XtrmTJ IS THE 2010 TJ of THE YEAR!! - JeepForum.com
post #1 of 88 Old 12-21-2010, 10:42 AM Thread Starter
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Big congrats to XtrmTJ, the 2010 TJ of the Year!!!!
Can a mod please sticky this thread.
XtrmTJ, along with BRICKTOP2 and flatlander757 have won one year premium memberships courtesy of Keith. If you would like to donate them to someone else, please notify me and I will tell Keith.
The top 5 winners; XtrmTJ, BRICKTOP2, flatlander757, cmoore, and Hendrix have also won a Bushwacker t-shirt. Please PM me to receive your prize.
Thanks to everyone who was in the contest, who voted, or who participated in any form this month and throughout this year. I was amazed at the amount of participation for the TJoTY poll, and I hope that enthusiasm carries into next year. Thank you for a great year, and I will be posting info on the calendars as soon as I figure it out.
Here is XtrmTJ, your 2010 TJ of the Year!!!
Username : XtrmTJ
Mods :
SPEC SHEET: 1997 Jeep TJ / Sahara
1. 1979 HP/D44, full width front axle with 5:38 Yukon gears, Detroit Locker, Yukon inner and outer axle shafts. Warn locking hubs, Rock Crusher diff cover, QA1 3/4” Hiem jointed tie rod that is 1 1/2” X .310 walled DOM, flipped on top the knuckles for a little extra clearance. Custom bridge work to locate the custom 3 link/Wishbone system.
2. 1978 Ford 9”, full width rear axle with 5:43 Yukon gears. Yukon Spool and 31 splined Yukon axle shafts. A Randy’s Ring & Pinion experimental (thick/beefy) third member. A ” thick DIY yoke/u-joint skid plate. A 3/8” thick steel skid plate welded to the bottom of axle. A 3/8” steel plate molded/welded on back cover to protect the ring and pinion. Custom bridge work to locate the custom 3 link/Wishbone system.
3. MPFI 4.0L inline 6 cylinder. (Just turned 39,000 miles) new factory “flex” header, K&N air filter, custom exhaust with a series 50 Flow Master muffler. Jet one inch TBI spacer. The OBA is a 1979 Ford A/C pump plumbed onto the factory A/C stand. A Summit Racing electric radiator fan. M.O.R.E. two inch raised motor mounts. Custom oil pan skid plate. Battery and Engine block warmers (Canadian model) Dual Optima red top batteries in an M.O.R.E. dual battery tray. Custom made (PVC pipe) radiator overflow and window washing fluid tanks.
4. TF 999 automatic transmission with a Currie deep oil pan (prevents fluid starvation at extreme angles) and a custom oil pan skid plate. Summit add on transmission oil cooler.
5. NP 231 transfer case. TeraFlex SYE kit, TeraLow 4:1 kit, mounted on a custom reinforced Teraflex “belly-up” skid plate.
6. Custom front and rear drive shafts, made from 2” X .250 walled DOM. Tom Woods long splined / long travel slip yokes with gold band1310 u-joints.
7. Front axle is moved forward 5.5” and is located by a custom “Wish Bone” three link system, using 1.75” X .250 walled DOM, the lower arms are 48” long X 1.75” X .250 walled DOM sheathed with schedule 80 pipe. All Hiem joints are QA1’s of ”” and 1 3/4” sizes. The front rides on a pair of 14 inch Sway Away Race Runner coil over’s with dual rated springs (10” 150 lbs over 14” 300 lbs) and 6” tender coils. The front brake lines are extra long and steel braided. Steering is controlled by a 2 X 8 inch hydraulic ram, with an add on electric fan cooled oil cooler, and a high volume PS pump with a smaller Power Pulley.
8. The rear axle was moved 9” backwards for a 109 inch wheel base, and is located by a custom “Wish Bone” 3 link system, using 1.75” X .250 walled DOM, the lower arms are 48” long X 1.75” X .250 walled DOM sheathed with schedule 80 pipe. All Hiem joints are QA1’s of ” and 1 3/4 “sizes. The rear rides on 5.5” over stock, Rubicon Express rear coils. The rear coils are captured on top and free at the bottom. The rear axle was clocked upwards for a perfect drive shaft angle. The rear shocks are Gas charged Les Schwab Mountain Rider Extremes, angle inboard for better articulation.
9. A two (2) inch “Bod-i-Lift” was installed to accommodate the Terraflex belly-up / skid pan. The rear of the frame was cut off and 3X4X3/8 inch tubing was added to extend the wheel base and attach the Rubicon Express rear coils. The stock fuel tank was removed and a custom, 16 gallon fuel cell was placed in the cargo area. The entire tub of the Jeep was coated with Hurcaliner bed liner. A Toys by Troy cage was welded in with extra support members (5 in all). A Grant steering wheel with a quick release system. Passenger side Air Bag was removed. KC Rock and off road lighting. A hood lift system. A pair of recovery shackles front and rear. 40 channel CB. Dual Air horns. Fire extinguisher.
10. Custom armor plating includes Avalanche Rocker Knockers w/custom nerf bars added and Compitition cut rear Crusher corners. The tail gate was removed and replaced with ” plate steel. A Blue Torch Fab front hoop and stinger combo. A custom made winch mount. A Warn HS9500I winch. Custom made “flat” front fenders. Front and rear LED turn/stop signals.
11. All this rides on 15X39.5X15 Super Swamper TSL’s mounted on 12X15 steel rock crawler rims with DIY 24 bolt custom bead locks.
12. Recent mods, Rear Bumperetts, Military tail/turn lights, Military door safety straps, Drivers fender blackout light, MB side and corner handles, Pioneer gear mounted (axe/shovel), .50 Cal ammo can used as a center console (lockable), MB side/rear view round mirror, Hand grenade (pineapple style) shifter knob. 20MM ammo can in rear as tool/gear storage, MB style hood latches. Everything painted Green, with Military markings painted Flat Black.
Story :
Eugene is a 1997 Jeep TJ. Eugene started out life as my wife’s daily driver and grocery getter. A mild 1.5” puck lift and 31” Super Swampers were all he got. He was given to me in May of 1999 and work began on him in June of 1999. After countless hours researching the web, talking to other Jeepers, looking, learning, figuring out the geometry, trials and errors, after many, many, … many,….. “ MANY” modifications, he now is ready to attack anything that gets in his way!
It was small little steps at first, trial and error stuff really. Then it happened, I was afflicted, a sickness my wife says, Eugene went from mild to wild ! From 29’s to 39’s, from factory OEM to one off custom everything. I have been wheeling Jeeps for over 20 years and finally built one that does it all, looks cool cruzing the strip on Saturday night and can negotiate the nastiest terrain in North America. Looks, Form, Function, I wouldn’t change anything, I know every nut, every bolt, every scratch, every dent, every noise he makes is music to my ears. Eugene is perfection in motion!
Pics:
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #2 of 88 Old 12-21-2010, 10:46 AM
Idaho-Jeep
CONGRATS!!!!! Really nice, well built amazing rig.
Idaho-Jeep Build =
Idaho-Jeep is offline
post #3 of 88 Old 12-21-2010, 10:57 AM
MO2500
Congrats on the win! Very well built rig
Instagram: @omsmike
MO2500 is offline
post #4 of 88 Old 12-21-2010, 10:58 AM
TJLover99
Nice Jeep!
If it were easy, everyone would do it
TJLover99 is offline
post #5 of 88 Old 12-21-2010, 11:04 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Congrats!
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #6 of 88 Old 12-21-2010, 11:28 AM
Chiles
Sweet deal, congrats!
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
Chiles is offline
post #7 of 88 Old 12-21-2010, 11:33 AM
sherminator866
very deserving. sweetest jeep ive ever seen. congrats man, nice nice rig
sherminator866 is offline
post #8 of 88 Old 12-21-2010, 11:59 AM
RickyR
Congratulations..
Great looking jeep...
Ricky
RickyR is offline
post #9 of 88 Old 12-21-2010, 12:05 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Congrats on a well-deserved win!
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #10 of 88 Old 12-21-2010, 02:28 PM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
Congratulations! Nice Rig! Well Built! And Very Cool Theme!
It's Your Jeep, Only Better. |
For quotes or customer service
Lots and Lots of Videos:
matsonian is offline
post #11 of 88 Old 12-21-2010, 02:34 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
I didn't vote but would have voted for this one! Really Cool!
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #12 of 88 Old 12-21-2010, 03:06 PM
BRICKTOP2
Unhingd PigFeedng Gangstr
BRICKTOP2's Avatar
Congratulations on the win man!
"Tightening the nut behind the wheel is the most cost effective way to improve the performance of any vehicle."
JK Build Thread
TJ Tub Trailer
BRICKTOP2 is offline
post #13 of 88 Old 12-21-2010, 03:17 PM
element54
element54's Avatar
Awesome rig and great build. I have always wondered though, where did you find a tank big enough to hold the green paint so you could dip that thing in it?
Seriously though, Congrats!
Why is there so much space down here?
element54 is offline
post #14 of 88 Old 12-21-2010, 03:43 PM
NOBLACKTOP
Very Nice!..Congrats!
NOBLACKTOP is offline
post #15 of 88 Old 12-21-2010, 04:14 PM
Gunkel
Gunkel's Avatar
Congratulations!! You did an awesome job on the build, you should be proud!!
Gunkel is offline
TJ of the year contest 2010!! Vote now!! The contest has started!! EugeneTheTJ TJ Wrangler Technical Forum 279 12-31-2010 12:01 PM
AUGUST TJ of THE MONTH!! XtrmTJ IS THE WINNER!! EugeneTheTJ TJ Wrangler Technical Forum 41 10-05-2010 01:38 AM
what year is a good donar year for jeep cherokee cwbymt1973 YJ Wrangler Technical Forum 6 11-19-2009 11:51 AM
"...little change through model year 2010..." otizzy JK Wrangler Technical Forum 17 03-29-2007 02:04 PM
