XJ/TJ/ZJ Front Knuckle Repair - Brake Pad Grooves - Page 2 - JeepForum.com
 4Likes
post #16 of 62 Old 04-05-2010, 05:50 PM
99TJtommy
What kind of wire did you use? All I have is what came with my welder.
99TJtommy is offline
post #17 of 62 Old 04-05-2010, 06:14 PM Thread Starter
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
030 flux-core....
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #18 of 62 Old 02-02-2011, 01:03 AM
btn
Just out of curiosity, why wouldn't one be able to simply file the divots flat to match the rest of the ear surface? Of course, the divots would form again, but it would be better than doing nothing. I understand the welding adds hardness, is that the reason?
btn is offline
post #19 of 62 Old 02-02-2011, 06:48 AM Thread Starter
Unlimited04
no the reason you weld/fill the divot instead of grinding it flat is to retain the same clearancing between the caliper and the rotor. if you file the divots down flat you'll screw up the distance between the rotor, pad, caliper & hub....without changing the caliper mounting points, the pads will get less support and still slide uneven.
Useful Write-Ups:
Funny:
post #20 of 62 Old 02-22-2011, 07:21 PM
242TJ
How common of a problem is this for Jeeps? I am about to do the brakes on my TJ for the first time and hope I don't run into this.
ll,ll,
lL_l--OlllllllO-
)_)-()_)--)_)
242TJ is offline
post #21 of 62 Old 02-22-2011, 08:13 PM Thread Starter
Unlimited04
very common as I understand it...some jeeps get divots at 20k miles... its a bit of a design flaw...so basically they all do it sooner or later if you use the brakes...
Useful Write-Ups:
Funny:
post #22 of 62 Old 06-01-2011, 03:23 PM
freeskier93
Anybody try this with a stick welder? I of course have these grooves, not as bad as in the pics, but still there. I'm trying to fix a squeak problem coming from my right front wheel and I'm slowly overhauling the front brakes trying to fix the problem. I'm probably going to have to put this on the list.
freeskier93 is online now
post #23 of 62 Old 06-01-2011, 03:32 PM
Boodyrider
Another answer might be to fill the divot and then use a replaceable slider cap as Ford does on the 8.8 axles. In that case, one might be able to fill the divot using an alternate filler such as JB Weld or epoxy.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #24 of 62 Old 06-01-2011, 06:34 PM
rchase559
I thought about this as an option as well but it would require a cap the same size and contour as the stock knuckle. One would have to ensure that they ground the knuckle down evenly in order to get the cap to sit straight and flat.
rchase559 is offline
post #25 of 62 Old 06-01-2011, 06:58 PM
TJJP77
TJJP77's Avatar
I'll second the desire for a slider cap - When I did the brakes on my Dad's '96 Explorer last summer I was jealous of how well those caps held up and of course the undamaged cast iron underneath. This seems like a logical need that the aftermarket should step in to fill the gap.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #26 of 62 Old 08-05-2011, 10:28 PM
neonhomer
Would a 115V mig welder work for this? I have a Lincoln WeldPak 3200HD, and I have .035" flux core wire in it. It can do up to 1/4" steel, output of 90A @ 19V @ 20% duty cycle.
I have a 96 ZJ with the same issues on BOTH knuckles. My friend has a 94 with the same problem, and his wife has a 95 with the same problem. This would make ALL of our lives better!!!
Thing that sucks is I can't weld! I would have to get my friend to lay the welds for me, and then do the dress work myself....
Yeah yeah... I own a welder and can't use it... LOL
NeonHomer
Mid-Florida Jeep Club - Member
1996 Jeep Grand Cherokee, 4.0L/42RE/242 - Rebuilt motor w/ Comp cam (4/12), 3.5" Junkyard F>R lift, 31x10.5.x15 M/T's, Spartan Locked D44a, TC & tank skids, F&R adj trackbars, V8 steering arms
Galaxy DX99V CB, 102" SS Whip, Yaesu FT-2900R 2m, Larsen 1/4w mag mount, Sony HU, Massive 3way - F Door, Pioneer 3way - R Doors, MB Quart ONX304 Subs (x2), Lanzar 1600w amp.
"No Matter Where You Go... There You Are."
"Oh me oh my a lovely day is dawning. Oh what a joy I didn't wake up dead. So I can go to work and then resume my yawning, and get my sleep on site instead of in my bed" - Daria Morgendorffer (with my twist)
neonhomer is offline
post #27 of 62 Old 08-05-2011, 10:36 PM Thread Starter
Unlimited04
I used a 120V Hobart Handler 140....
Useful Write-Ups:
Funny:
post #28 of 62 Old 08-05-2011, 10:49 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It's a great aftermarket idea. So great that I had about 20 sets built, but they are expensive in small lots, or about 2 bucks each. And lest we forget, we have to machine the slots in the ends of the brake pads larger so they will slide and that adds to the overall cost.
When I finished up with the costs and added it all up, it was something near 15 bucks cost added to a set of pads with slider caps.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #29 of 62 Old 08-05-2011, 10:55 PM
freeskier93
Def. something I would buy. Still have the grooves that I haven't and probably will never get around to fixing.
post #30 of 62 Old 04-13-2012, 09:27 PM
predawn
what about steering pull?
Could dragging pads be the result of these divots and would it be noticeable right after new pads, calipers, and rotors in the front? i would imagine they'd have to wear down a bit before the travel distance would be affected by the divot, or is it the other way around?
predawn is offline
Stripped Brake Caliper Bolt at the knuckle JeepRocks86 TJ Wrangler Technical Forum 19 05-08-2010 06:59 PM
Steering knuckle divot repair clemul TJ Wrangler Technical Forum 15 05-04-2010 03:16 PM
Vanco Big Brake - Knuckle question tkki1230 TJ Wrangler Technical Forum 4 12-02-2008 12:12 AM
Size of helicoil for caliper bolt/stripped knuckle repair? Alheim YJ Wrangler Technical Forum 8 05-23-2007 05:46 AM
Brake Pads worn into steering knuckle 1992 renagade YJ Wrangler Technical Forum 6 05-07-2007 07:15 PM
