XJ starter work in a TJ? - JeepForum.com
post #1 of 10 Old 04-20-2009, 06:05 PM Thread Starter
mike68
i made a post yesterday about my starter crapping out, and instead of shelling out 150 bucks on a new one, i thought i might take a chance and go to the pull apart here in Columbia. there aren't any wranglers in the yard, but there is like 10 Cherokee's. would an XJ starter bolt right up into my TJ? both have straight 6's so it should be very similar if not the same right?? its only 11 bucks at the pull apart
check out my club!
yellow jeeps club member #68
./l ,[_\_\ ],
l---L ()lllllll()-
()_) ()_)--o-)_)
mike68 is offline
post #2 of 10 Old 04-20-2009, 06:11 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
from what i found on advanced autos site no, the 99 TJ will cross with a 99 XJ but not the 04 TJ to an XJ
RnEmOvr is offline
post #3 of 10 Old 04-20-2009, 06:12 PM Thread Starter
mike68
maaan, cant seem to catch a break... what would be the difference? flywheels are different??
check out my club!
./l ,[_\_\ ],
l---L ()lllllll()-
()_) ()_)--o-)_)
mike68 is offline
post #4 of 10 Old 04-20-2009, 06:16 PM
RnEmOvr
RnEmOvr's Avatar
dunno, it just shows part numer 17689 for the <01 XJ (last year) and 17408/17404 for your 04 TJ
RnEmOvr is offline
post #5 of 10 Old 04-20-2009, 11:03 PM
LJameson
^It could be that Chrysler just got them from a different parts vendor.
1990 YJ
LJameson is offline
post #6 of 10 Old 04-21-2009, 03:24 AM
RnEmOvr
RnEmOvr's Avatar
i have a feeling its the wiring side, cause 99-01XJs fit the 99 TJs
RnEmOvr is offline
post #7 of 10 Old 04-21-2009, 12:40 PM Thread Starter
mike68
i might bring my starter to the pull apart today and compare to one on an XJ, see if anything differs between the two.
check out my club!
./l ,[_\_\ ],
l---L ()lllllll()-
()_) ()_)--o-)_)
mike68 is offline
post #8 of 10 Old 04-21-2009, 01:09 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
You might want to talk to a local electrical rebuilder. I can get rebuilt starters or alternators for $50 all day long for my Chevys and about $60 for my Jeeps. They come with life-time warranty - as long as I can keep the mud out of them
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #9 of 10 Old 04-21-2009, 01:28 PM
Dean O
Dean O's Avatar
I just changed the starter on my '00 XJ a few weeks ago and I compared it to the starter on my '97 TJ and they were slightly different for sure. I don't mind taking a peak underneath maybe even snapping a few pics of them for you if that'll help.
2000 4-dr Sport XJ- RED 3" lift, moabs and 31" MTs
'97 TJ Sport- BLACK-2" lift and 32"s
Dean O is offline
post #10 of 10 Old 04-21-2009, 02:07 PM
RnEmOvr
RnEmOvr's Avatar
it was starting in 02 that that part number changed on the TJ
RnEmOvr is offline
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 09:22 AM
will starter for a 4 cyl. work/fit in a 6 cyl.? peebody YJ Wrangler Technical Forum 4 03-03-2009 07:22 PM
Should the starter work when.... daaaaaan YJ Wrangler Technical Forum 1 03-31-2007 10:43 PM
Will a TJ starter work? BudmanV6 YJ Wrangler Technical Forum 1 04-19-2006 07:31 PM
How do you get the Starter to work without pressing the clutch? rshrimp TJ Wrangler Technical Forum 38 01-31-2004 11:00 PM
