XJ front shaft for TJ rear shaft. Couple ?'s - JeepForum.com
post #1 of 6 Old 07-21-2009, 10:10 PM Thread Starter
TJ311
I'm getting ready to do an SYE soon and am planning on using the XJ front drive shaft to cut down and use as my CV rear drive shaft but have a couple questions. I tried searching around but couldn't find an answer. What year XJ's do I look for? I did find that an automatic shaft is the better option but am also curious, for those that have used that drive shaft, on what lengths they had them cut down to. I should be at almost 4" of total lift and we'll say a TT at some point too.
Thanks in advance!
TJ311 is offline
post #2 of 6 Old 07-22-2009, 06:58 AM
cgmrdc
1988 MJ Comanche
it doesnt matter what year... they are going to cut a lot off. I have the Tear SS and and 8.8 and my with a tummy tuck and 2.5" lift and my xj front shaft was cut down to 23"
most xj front drive shafts only vary a couple inches and are similar in length to your tj front shaft so just get what ever is available... what is better about the auto ds?
when i did mine i took it to a local ds shop on a friday, did the swap on a sat, called and left a message with the correct length and it was ready monday afternoon... i would suggest putting in new joints and a new cv ball before you take it to them. total cost for cut and balance was 80 bucks...
most likely you will be fine with the same ds for the tummy tuck. we build a lot local and no one has ever had to buy a new one bc of length...
cgmrdc is offline
post #3 of 6 Old 07-22-2009, 07:31 AM
Dogman
Dogman's Avatar
You can also use the front shaft out of a Ford Explorer. They just happened to be more plentiful when I did mine.
John 3:17
Dogman is offline
post #4 of 6 Old 07-22-2009, 08:09 PM Thread Starter
TJ311
Any idea on years for the Explorer shafts?
The only thing I've read that stated auto Cherokee driveshafts were a better choice was because of the length. Apparently, they're slightly longer to give you more to work with but if you're having it cut down it doesn't really make sense to me.
TJ311 is offline
post #5 of 6 Old 07-22-2009, 08:39 PM
Dogman
Dogman's Avatar
I'm not sure, I just made sure it had 1310 u-joints and they were in ok shape. They are so much longer that you don't have to worry about it.
John 3:17
Dogman is offline
post #6 of 6 Old 12-09-2009, 03:48 PM
Nelg7654
1997 XJ Cherokee
now can a XJ front shaft be used as TJ front shaft?
WTB: JK front seats, 35x12.50 TSL's or SSR's
Originally Posted by KINGJB View Post
well the most definite water proofing for your seats is to put the doors back on.
Nelg7654 is offline
Non-Rubicon driveshaft U-joints. Front shaft and rear shaft use the same? BWFBezerk TJ Wrangler Technical Forum 8 01-15-2010 06:23 AM
xj front drive shaft for yj rear teejmcd YJ Wrangler Technical Forum 1 01-26-2009 04:30 PM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
No front d-shaft-no problem...w/ d-shaft-death wobble and can't get to 50mph...help gadawgz71 TJ Wrangler Technical Forum 5 08-06-2008 03:12 PM
Front XJ shaft for Rear TJ - What years? Dogman TJ Wrangler Technical Forum 7 12-07-2007 11:01 AM
