XJ front and rear diffs in a TJ? - JeepForum.com
post #1 of 3 Old 08-01-2010, 05:24 PM Thread Starter
sgarhaereanh
I was wondering if i could put XJ rears on my tj. thanks
Eagle Scout Jeeper #57
sgarhaereanh is offline
post #2 of 3 Old 08-01-2010, 05:27 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The front axle is a bolt-in but the rear axle would require major modifications since the XJ's rear axle is set up for a leaf spring suspension and the TJ uses a totally different coil spring suspension design back there.
Jerry Bransford is offline
post #3 of 3 Old 08-01-2010, 05:41 PM Thread Starter
sgarhaereanh
alright cool thanks for the quick responce
xj to tj , axle , swap
Bent rear diff and cracked transfer case, what diffs and case will bolt into my 87 YJ hillside250 YJ Wrangler Technical Forum 9 01-08-2009 01:45 AM
New Front and Rear Diffs Dudewayne TJ Wrangler Technical Forum 9 04-18-2008 09:05 PM
Front & Rear diffs..? petej200 TJ Wrangler Technical Forum 3 03-27-2008 10:54 PM
REMOVE front and rear diffs? Wallace TJ Wrangler Technical Forum 18 02-12-2007 09:05 PM
Fluid Type Front/Rear Diffs Chest_Rockwell TJ Wrangler Technical Forum 2 10-09-2005 10:35 AM
