XJ brake and clutch assembly in a TJ? - JeepForum.com
post #1 of 2 Old 07-19-2008, 04:36 PM Thread Starter
jeepwrangler97
I have a TJ with a 2.5L and an automatic. I am going to put in a 4.0 (soon to be a 4.6) and an ax15 out of a cherokee. Can I use the brake and clutch pedals(the whole assembly) from the XJ?
jeepwrangler97 is offline
post #2 of 2 Old 07-20-2008, 10:25 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
non of it is a direct bolt in so you would have to make it work
RnEmOvr is offline
Squeaking in clutch assembly? 333Inlinesix TJ Wrangler Technical Forum 5 03-28-2007 07:38 AM
What clutch assembly do I use? JOKER4INK YJ Wrangler Technical Forum 3 11-11-2005 09:20 AM
95 Clutch Cylinder Assembly? robzr YJ Wrangler Technical Forum 4 01-19-2005 05:16 PM
TJ pedal assembly (brake, clutch. gas) on a CJ? apachetech TJ Wrangler Technical Forum 0 08-12-2004 07:27 PM
93 Hydraulic Clutch Assembly Lopedog YJ Wrangler Technical Forum 1 10-06-2003 02:58 PM
