XJ 44 into a TJ - JeepForum.com
post #1 of 7 Old 11-12-2011, 11:09 PM Thread Starter
ManitobaTJ
XJ 44 into a TJ
I am putting in a XJ Dana-44 Limited Slip TruPosi 3.73 into my already Dana-44 3.73 (spyder gears) TJ and was just wondering if anyone knew if there was anything extra required or if that didn't work.
Any help appreciated
ManitobaTJ is offline
post #2 of 7 Old 11-13-2011, 12:48 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
You are simply replacing your open differential with a track-loc right?
You'll be doing a Full gear set up is all
Measure current gear back lash, and take a reference pattern.
Use your gears,start with the original (to your current tj axle) carrier shims with new bearings, measure backlash and take a pattern. If it matches the original numbers and pattern, tie it up and drive. If not you'll be doing a gear set up.
be sure you use new ring gear bolts and follow the spicer set up manual.
Never mix n match a different ring gear and pinon.
ratmonkey is offline
post #3 of 7 Old 11-13-2011, 10:24 PM Thread Starter
ManitobaTJ
Thank you man. It's arriving tomorrow. Stoked. I've been Jeep-less for a month.
post #4 of 7 Old 11-14-2011, 07:16 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Are you rebuilding the limited slip before you install it? I probably would.
Are you sure you do not already have a limited slip? Most TJ D44s do.
Wheelin98TJ is offline
post #5 of 7 Old 11-14-2011, 08:00 AM Thread Starter
ManitobaTJ
See that's what I thought too, but I have spider gears, not a spool. So I guess it could be limited slip just not a truposi (which is ironic because it is not an actual posi)
'99 TJ "Topless Sarah" - 4.0L ('01) NP231 AX15 D30/D44 (daily)
Check my build:
http://www.jeepforum.com/forum/f22/sarah-j250-1377179/
post #6 of 7 Old 11-14-2011, 08:06 AM
Wheelin98TJ
JEEP FREAK
A stock TJ limited slip (Dana/Spicer Trac Lok) has spider gears.
I'm not sure what you mean by truposi? Posi is a GM term for limited slip.
Maybe you mean Truetrac, the limited slip diff made by Eaton (formerly Detroit)?
post #7 of 7 Old 11-14-2011, 08:28 AM Thread Starter
ManitobaTJ
The guy said TruPosi but as you stated and on my own investigation of it I'd assume there is nothing special about it. I was confused at first cause I just started learning about rear ends when mine blew.
Check my build:
dana 44 , limited slip , rear end , tj , xj
