Xenon flat flare installtion ???'s - JeepForum.com
post #1 of 9 Old 09-27-2008, 01:35 PM Thread Starter
01amberfirewv
I have the rear inner gaurd off and all but the bottom two bolts out. Both of those seem to be turning on the inside. I can get to the back of the rear bolt but not the front. How do you remove it?
33x10.50 BFG MT KM2 on soft 8's , 4.88's Super35, D30ECTED, OME HD, AtoZ rockers, skid plates, custom rear bumper, Champion winch, SYE, Woody shaft, 4.0tb, Rocket parts intake, Magnaflow muffler
01amberfirewv is offline
post #2 of 9 Old 09-27-2008, 02:36 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I held mine with needle nose pliers while turning it.
TheBoogieman is offline
post #3 of 9 Old 09-27-2008, 03:11 PM Thread Starter
01amberfirewv
What about the front one? I can't seem to get to it
post #4 of 9 Old 09-27-2008, 05:24 PM
XXRider
I could get to all the nuts on the back but I had to pull the plastic in the wheel well down first.
XXRider is offline
post #5 of 9 Old 09-27-2008, 06:25 PM Thread Starter
01amberfirewv
Its already out. I am thinking about just cutting the bolts out and using some metal screws to hold the new flares in. I am not sure thats even going to work
post #6 of 9 Old 09-27-2008, 07:33 PM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
nut & bolt or get some nutserts from the dealer.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #7 of 9 Old 09-27-2008, 09:11 PM
dirtball28
I had to pry a few of mine out (pried out the nutserts) when I put on some crappy smittybilt flares. Once the smittybilts fell apart I decided on the flat xenons'. Since the holes that held the screws and nutserts that I pried out are now distorted due to prying out the old screws, the hardware would no longer fit the holes. For these I used drywall anchors, appropriately sized screws and some washers. Works good, cheap and easy. I also heard rubber well nuts work well but couldn't find any of those.
Of course if you just put a little pressure on them you should be able to get it out of the nutsert easily and wouldn't have to worry about any of that.
dirtball28 is offline
post #8 of 9 Old 09-28-2008, 05:49 AM Thread Starter
01amberfirewv
Already tried that
I may have to go with this
I just need to decide which is going to do the most damage
post #9 of 9 Old 09-28-2008, 10:28 AM
ptowntj
ptowntj's Avatar
I'm glad that I read this...the front of the rear wheelwheel seems that that you can't access it without drilling a hole to get a nut behind hit...the drywall deals seem like a good idea (better that my flares flapping everywhere).
8 lug xj.
ptowntj is offline
Xenon Flat Flare Install..Little Help Please!! finsout TJ Wrangler Technical Forum 5 02-09-2010 02:27 PM
Have your Xenon flat flare bowed? Benderff TJ Wrangler Technical Forum 10 10-19-2009 07:26 PM
Xenon 6" Flat Flare Question Welke TJ Wrangler Technical Forum 2 06-19-2009 11:11 PM
Xenon Flat Flare wiring Q. sprout929 TJ Wrangler Technical Forum 2 01-01-2009 07:41 AM
Cracked a Xenon Flat flare! distantdog TJ Wrangler Technical Forum 5 12-01-2008 08:33 PM
