Wub noise from front drivers side tire? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Wub noise from front drivers side tire?
Labor day sale @ rockridge 4wd! 8/29-9/1 site wide..promo Rough Country Deals at JeepHut.comShocktober is here! Get new shocks for your Jeep!!!!
Unread 08-30-2014, 08:00 AM   #1
Mudstick
Curious as to what could be causing it. Its not too loud and accelerates when the vehicle accelerates. The two tires in the front are new (goodyear wranglers) but I have had those tires before and have never heard them make that sound.
Could it be out of balance? Could it be the tire itself? Need some help to identify potential issues so I can check them. I'm not sure where to start.
Mudstick is online now   Reply With Quote
Unread 08-30-2014, 08:13 AM   #2
onemorejeep01
Mine was making a noise a while back, but it was the brakes sticking. By the way what is wub? Wheel unbalanced?
That's all it costs??
onemorejeep01 is offline   Reply With Quote
Unread 08-30-2014, 08:15 AM   #3
Mudstick
No its literately exactly what it sounds like, a constant deep wub wub wub noise
Unread 08-30-2014, 08:50 AM   #4
Leffnasty
My old truck did this, it was due to the tires not being balanced/rotated enough leading to uneven wear pattern. Went away when I put new tires on it.
Leffnasty is offline   Reply With Quote
Unread 08-31-2014, 03:42 PM   #5
oakmckinley
Could be a bad hub or u joint as well.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline   Reply With Quote
Unread 08-31-2014, 05:44 PM   #6
Mudstick
I will check the joints tomorrow. If its not then I will take it down to get the tires checked for balance.
Unread 08-31-2014, 05:50 PM   #7
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
I have resisted saying this until now, I can no longer resist... every time I think of your tire wub and the wub wub wub sound you described, I think of the old Elmer Fudd cartoons I grew up watching.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 08-31-2014, 06:34 PM   #8
onemorejeep01
Didn't hit me till you said it, I can't stop laughing now Jerry!
Unread 08-31-2014, 07:24 PM   #9
Mudstick
Ha!
Unread 08-31-2014, 08:53 PM   #10
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I'm Hunting Wabbits...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote
Unread 08-31-2014, 09:01 PM   #11
Jerry Bransford
Wascilly wabbit!
Getting Savvy...
Unread 08-31-2014, 09:53 PM   #12
hndswthtshdws
Could be a crack in a tire lug, something stuck between the lugs, uneven tire wear, bulge in the tire, etc.
Sounds dumb but a good burnout helps with that uneven tire wear :-)
If you filter out everything that has bad spelling and grammar, you can believe 95% of what you read on the Internet.
hndswthtshdws is offline   Reply With Quote
Unread Yesterday, 10:29 AM   #13
Mudstick
You guys are hilarious. Thanks for the support though, I'm going to get the tires looked at soon.
