WTF! Took all the bolts out of diff cover...tried hitting it, spitting at it, and... - JeepForum.com
post #1 of 7 Old 07-23-2006, 07:30 PM Thread Starter
JeepinYahoo
JeepinYahoo's Avatar
1977 CJ5
Yelling at it and it still wont come off. Any special trick to get it off there?
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100
JeepinYahoo is offline
post #2 of 7 Old 07-23-2006, 07:35 PM
dakuda
Admin
dakuda's Avatar
There is a gasket there. Probably RTV. Just pry it off.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
dakuda is offline
post #3 of 7 Old 07-23-2006, 07:42 PM
AlTheKillerr
AlTheKillerr's Avatar
i just use a paint can lid opener if it doesnt want to come off
Photographer
AlTheKillerr is offline
post #4 of 7 Old 07-23-2006, 07:46 PM
kaybone
What works good for me, is an old dull wood chisel. Tap it with a hammer and the wedgie part of the chisel will help pry the cover off. Move around the cover when you do this. Don't wail on the hammer and chisel, however. You don't want to make a big gouge in the face of the diff.
Gun Metal Blue Jeep Club Member #99
kaybone is offline
post #5 of 7 Old 07-23-2006, 07:53 PM
FL 4.0L
I used a putty knife and worked around the cover for the front and rear diffs. Didn't mar either surface. The front came off a lot easier after I loosened the bolt hiding behind a bar!
FL 4.0L is offline
post #6 of 7 Old 07-23-2006, 08:00 PM
jzmtl
jzmtl's Avatar
Leave the top bolt on but loose and hit it harder with a rubber maullet, unless it was glued on I don't think RTV is gona be tougher than that.
The funny thing about this signature is that by the time you realize it doesn't say anything, it's too late for you to stop reading it.
User CP > Options > Uncheck "Show Signatures"
jzmtl is offline
post #7 of 7 Old 07-23-2006, 08:02 PM Thread Starter
JeepinYahoo
1977 CJ5
Got it...Stu-offroad get credit here. Thanks Stu.
Inverted T steering hitting front diff cover! yippieayae TJ Wrangler Technical Forum 11 04-17-2011 07:09 PM
JKS adj trackbar hitting DANA 30 diff cover ! jeep2008 TJ Wrangler Technical Forum 36 02-25-2009 07:49 AM
Diff Cover bolts??? TrailWorthyFab YJ Wrangler Technical Forum 8 04-11-2007 02:27 PM
8.8 Diff Cover Bolts Twig TJ Wrangler Technical Forum 3 02-09-2007 03:32 PM
Diff cover hitting gas tank skid UCTJ TJ Wrangler Technical Forum 7 08-21-2005 10:04 PM
