Wrong Rotor Size Fix? - JeepForum.com
post #1 of 10 Old 09-12-2009, 12:06 AM Thread Starter
efr523
I have a 2001 tj sport and I just ordered some new rotors to do a brake job. I found out about the rotor size change a little late and ended up getting the rotors that are 1/8" deeper than i need. I was thinking about taking my cutting torch and cutting the middle out of my old rotors to make essentially about a 1/4" spacer and putting them on the inside of the new rotors to fill up the extra space so the wheel wont seize up. I got a really good deal on some drilled and slotted rotors and don't want to go through the hassle of returning them and ordering new ones. Can anyone see anything potentially harmful by doing this?
efr523 is offline
post #2 of 10 Old 09-12-2009, 02:16 AM
Boodyrider
What, other than dying? Nope, go for it.
No **** with the brakes to save on returning the wrong parts dude, you could break studs and kill someone.
Hey, swap in the matching unit bearings!!!
Seriously... send back the wrong, get the right. It's not JUST the depth, the other concern is real. Also, spacing like that will likely cause the calipers to hit on the other side.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Last edited by rustywrangler; 09-12-2009 at 08:31 AM. Reason: Language problem, this is your warning.
Boodyrider is offline
post #3 of 10 Old 09-12-2009, 03:05 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Return them and drilled rotors don't help on Jeeps.
TheBoogieman is offline
post #4 of 10 Old 09-12-2009, 03:32 AM
Boodyrider
Here's a thought, return them and buy decent blanks. Interestingly enough, Autostoned blanks (Duralast 'brand') are pretty good ones.
post #5 of 10 Old 09-12-2009, 07:13 AM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
You people are interfering with Darwins work.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #6 of 10 Old 09-12-2009, 08:42 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
As greatly as you need a severe amount of abuse for considering such a bad idea, there is a very real problem that you will encounter. It's critical to the function of the brake system that your rotor register perfectly on the pilot that sticks out of the unitbearing. If you examine that pilot carefully, you will find there are two different diameters to it with the larger one next to the flange for the rotor and just outside of that, another diameter for the OEM wheel to register on.
If you space the rotor outwards, it won't register correctly and can cause some issues you may not enjoy.
Just to satisfy my curiosity, but how long did you power through the grinding before you figured it out?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #7 of 10 Old 09-12-2009, 01:12 PM Thread Starter
efr523
to satisfy your curiosity 0 seconds i have not done this
efr523 is offline
post #8 of 10 Old 09-12-2009, 01:25 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Well, if you haven't run the rotors, take them back and swap them for the correct versions.
I am Savvy
mrblaine is offline
post #9 of 10 Old 09-14-2009, 07:28 PM
SHAKEnBLAKE
I had this same problem today, but I did not think about grinding anything and I called autozone and advance and they weren't picking up each others' part numbers, but both of them had rotors that would rub on the backing plate. They were sure that I had a freak jeep, or "maybe they used parts from the next model year"
but 97 and 99 jeeps had the same part number in their system. This month has been a 100% you get what you pay for kinda month.
Ohio4x4.com
SHAKEnBLAKE is offline
post #10 of 10 Old 09-14-2009, 07:47 PM
funshootin1
Ive got some cross drilled brake lines if you need em. ha
funshootin1 is offline
Front Rotor Size? DutchmanAZ TJ Wrangler Technical Forum 26 03-13-2011 11:25 PM
Pads rubbing after pad/rotor install...what did I do wrong? Copper RS TJ Wrangler Technical Forum 3 07-13-2008 07:27 PM
got wrong size shocks >_< b3nj4m1n TJ Wrangler Technical Forum 3 05-26-2008 02:28 PM
i think this is the wrong rotor button chriscisme YJ Wrangler Technical Forum 3 02-25-2008 09:25 AM
2000 SE Front Rotor Size als2000 TJ Wrangler Technical Forum 3 04-28-2006 04:17 PM
