Write up on Transfer case fluid change??? - JeepForum.com
post #1 of 11 Old 06-19-2006, 07:08 PM Thread Starter
((~JEEP~))
Is there a write up or link that could direct my to a DIY fluid change?
((~JEEP~)) is offline
post #2 of 11 Old 06-19-2006, 07:21 PM
keoki04
keoki04's Avatar
I hope this is what you are looking for!!!
http://www.4x4xplor.com/trannyservice.html
Current Ride:
97 TJ Sport 5spd
Check profile to see the mods!
Other mods to come...
Clicky
Clicky
keoki04 is offline
post #3 of 11 Old 06-19-2006, 07:32 PM
Walkersteelhead
Walkersteelhead's Avatar
I'm not trying hijack your thread but I was told in my 97 tj I was supposed to use gear oil is that right. Just want to make sure before I get to it this weekend.
Walkersteelhead is offline
post #4 of 11 Old 06-19-2006, 07:44 PM
daveg13
daveg13's Avatar
No, ATF. Any ATF will be fine.
'99 Sport
31X10.5-15 BFG AT, some Tuffy boxes, slowly being built.
daveg13 is offline
post #5 of 11 Old 06-19-2006, 08:39 PM
Walkersteelhead
Sorry misread thought we were talking about the tranny.
post #6 of 11 Old 06-19-2006, 10:28 PM
Moabntj
Fluid change
Hi.. fluid going to be synthetic or standard??
Transfer case, synthetic, completly empty transfer case dispose of properly, installl new fluid operate for 1 hour or days wheeling, drain and refill with synthetic, this operation cleaned all old fluid and put it in suspension, replaced with new and joined the ranks of the confident wheelers. I am running synthetic in all my reservoirs, brakes, transer, engine, diffs. Have fun, stay clean..
Moabntj is offline
post #7 of 11 Old 06-19-2006, 11:24 PM
paintballjerry
paintballjerry's Avatar
It took a D/C tech 15 min to convince me to put ATF in my t/c and gear oil in my tranny (5 spd). Who'da thunk it?
<=== My Specs are there in my Profile!!!
Co-Ed Naked Jeeper Club Member #69
Originally Posted by charlescho
don;t ask here what MPG you will get with what tires etc, you will get your butt raped by the forum bullies
paintballjerry is offline
post #8 of 11 Old 06-21-2006, 06:20 PM Thread Starter
((~JEEP~))
backwards???
post #9 of 11 Old 06-21-2006, 07:14 PM
RWB214
RWB214's Avatar
1. remove fill plug on t-case
2. remove drain plug on t-case
3. allow the red fluid (atf) to drain into a suitable container for disposal. Since it is red, pretend it is the Jeep's blood.
4. replace the drain plug on tcase.
5. use a hand pump (>$10 at parts store) to pump it full of ATF Dex II until it comes out the bottom of the fill plug and levels off (about 1.2 quarts +/-)
6. replace the fill plug.
7. Use a grease gun with a needle fitting to lubricate the shifting linkages, if desired.
8. Have a beer, but not before taking the Jeep on a test drive!
RWB214 is offline
post #10 of 11 Old 06-21-2006, 08:10 PM
Ballzy
Not to hijack, but I've seen some threads say use ATF +4 in the T/C, but the book says dex III. Does it matter for the T/C?
Ballzy is offline
post #11 of 11 Old 06-21-2006, 10:33 PM
EricsXJ
The Post man
EricsXJ's Avatar
The NP231 transfer cases are not that sensitive so either fluid will work fine. I use Dexron III just because thats the same fluid for my tranny so it makes it easy. I also run synthetic in the transfer case, just because that sucker gets hot.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
92 yj transfer case fluid change moparcas YJ Wrangler Technical Forum 1 09-25-2009 11:24 AM
Transfer case output seal leaking. Any write-ups on how to change it? TheMightyGoat TJ Wrangler Technical Forum 0 05-07-2008 05:36 PM
Transfer case fluid change drewdown97 TJ Wrangler Technical Forum 3 04-18-2008 05:17 PM
Transfer case fluid change? tj40 TJ Wrangler Technical Forum 3 08-03-2007 08:21 AM
Transfer Case Fluid change... Qwntm TJ Wrangler Technical Forum 0 12-09-2001 08:39 PM
