Write up needed for transmission fluid change - JeepForum.com
post #1 of 4 Old 10-13-2009, 03:00 PM Thread Starter
billabong266
I have used the search function and looked at other jeep sites and i could not find a write up for a fluid change for my 6 speed tranny. I would perfer one with pics since i have never done this before.
billabong266 is offline
post #2 of 4 Old 10-13-2009, 03:24 PM
Fropleyqk
Fropleyqk's Avatar
download the FSM in my sig.
Crap, just saw you said 6spd. My bad, I dont think thats in there.
Fropleyqk is offline
post #3 of 4 Old 10-13-2009, 03:27 PM
SHAKEnBLAKE
I don;t think you have the AX-15 but here's a writeup
AX-15 Manual Transmission Service
Ohio4x4.com
SHAKEnBLAKE is offline
post #4 of 4 Old 10-13-2009, 04:43 PM
Bufordray
Fluid Change
Just recently changed mind..You will need 2 Qts... I personally used Amsoil it cost $10 a qt...Will also need 17mm allen wrench..Loosen fill plug first..Drain plug second...I also purchased a little hand pump from Napa that does a good job when it comes to filling...
Buford
Bufordray is offline
How-To: BA-10/5 Tranny fluid change write-up. rustywrangler YJ Wrangler Technical Forum 34 10-25-2014 09:47 AM
NVG1500 Transmission. Fluid needed for change? BENGRFF TJ Wrangler Technical Forum 2 10-10-2008 06:01 PM
Write up on Transfer case fluid change??? ((~JEEP~)) TJ Wrangler Technical Forum 10 06-21-2006 10:33 PM
transmission fluid change?? UTmike TJ Wrangler Technical Forum 2 05-27-2006 02:22 PM
Transmission fluid change vato_loco_quas TJ Wrangler Technical Forum 5 10-07-2005 06:22 PM
