Quantcast Would you buy a home made BL for your TJ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Would you buy a home made BL for your TJ?
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 05-13-2007, 10:56 PM   #1
keoki04
I was searching around on Craigs list and came across someone locally who has a 1 inch BL for sale. So I inquired about it and received a response. Here is what the response was:
The body lift was something I did when I was a machinist. They are 1"
aluminum pucks with the hole drilled in them. Right now they are just plain aluminum color, but if you wanted, I could see and have them anodized black for you.
I put this on my jeep when I had it and really worked well. I have the bolts also. The total would be $35 with bolts.
This person does not have a MML for sale. Part of me says "The price is right! Go for it!" The other part of me says "You should really buy a whole kit from JKS, PA, Daystar, etc..."
What do you all think? Thanks in advance!
Current Ride:
97 TJ Sport 5spd
Check profile to see the mods!
Other mods to come...
My crazy dog!
Clicky You've gotta love days like this at work! Yes, I threw it...Clicky
keoki04 is offline   Reply With Quote
Old 05-13-2007, 11:08 PM   #2
jzmtl
I think there is a reason every other company make them out of plastic, not aluminum. But if they are cheap why not.
jzmtl is offline   Reply With Quote
Old 05-13-2007, 11:11 PM   #3
goldrush
do it on a dogsled
goldrush's Avatar
this my thought on any homemade mod on anything, If it fails who is libel??? if it doen't matter, then, no matter, but,,,, if what ever the home product is, if something does fail you have someone else to blame.
04 Black unlimited, 4"lift, 33" GY Silentarmors, OME shocks, stablizer
warn 9500ti winch,optima yellow top, full bottom armor
#200 v.2 black jeep club
goldrush is offline   Reply With Quote
Old 05-13-2007, 11:12 PM   #4
eclipse27
I could of sworn that i read somewhere on here that the aluminum ones give off more vibrations or something "ride alil rougher". But dont hold me to it.
eclipse27 is offline   Reply With Quote
Old 05-13-2007, 11:17 PM   #5
dirtbagofva
2010 JK Wrangler
go for it...aluminum is strong and more expensive than plastic. Alot of 3" lifts for pickups are made of aluminum. As for the MML, buy a name brand not a homebrew.
What did he use for the front bumper things (grill support)?
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word."
Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7
dirtbagofva is offline   Reply With Quote
Old 05-13-2007, 11:41 PM   #6
RockRunner85
You don't need to worry about transmitting vibrations as the body lift keeps the stock mount and you just add the lift puck in between. There are body lifts made out of aluminum as well.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
The Reptile File
A discussion forum on geckos, lizards, snakes, and other reptiles.
RockRunner85 is offline   Reply With Quote
Old 05-14-2007, 01:00 AM   #7
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
X's 2.....
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Old 05-14-2007, 01:07 AM   #8
Jeepinty
Mines aluminum.
Jeepinty is offline   Reply With Quote
Old 05-14-2007, 06:37 AM   #9
Erik T.
Bullet Sponge.
Erik T.'s Avatar
No.
A 1" BL isn't all that expensive, I'd rather buy something where I got someone to whine to if it goes bonkers on the road.
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline   Reply With Quote
Old 05-14-2007, 03:17 PM   #10
keoki04
Thank you all for your input! Anyone else have their two cents they would like to add? I figure at 1/3 the cost, why not? BL, usually cost $100 or so, plus shipping, right?
Thanks!
EDIT: I found a BL that uses aluminum pucks. Has anyone used this lift? http://www.redrock4x4.com/shop/products/715.html I assume this homemade one would be similar to it.
Current Ride:
97 TJ Sport 5spd
My crazy dog!
Old 05-14-2007, 04:26 PM   #11
Scotch740
Why is that, all the JKS BMML is a block of aluminum with 2 holes in it. Im making one with aluminum, 4 new bolts and 2 coupling nut. For less than $29 with parts shipped, not including wear on the drill bits, band saw blade, so maybe $30 after that. Saving 21 bucks to drill 4 holes and 2 cuts in 1x2 aluminum. Much easier than a BL.
Scotch740 is offline   Reply With Quote
Old 05-14-2007, 05:04 PM   #12
Pyroteknik701
Well me and my buddy made pucks for his Mada truck. The reason people make them out of Polyurethane is the cost, the aluminum ones tend to be more expensive and are just for the extra look. But black plastic works fine. The ones we made out of aluminum worked just fine. It was easy to bolt on and stayed great for the 2 years he owned that truck. So in my opinion go ahead and get them if the price is right, i have experienced building these and its really a simple make, im sure if he is a machinest he made them great quality.
2.25" budget boost, 1" Performance Accessories Body Lift, flowmaster 40 series, kenwood stero system, new front and rear bumpers,dual tops, and 33"x12.5" BFG All Terrains, on unique black steelies, Rubicon Express Steering Stabilizer
Pyroteknik701 is offline   Reply With Quote
Glock Forum
